FlywithCE Logger
Old July 3rd 19, 05:46 PM posted to rec.aviation.soaring
Default FlywithCE Logger
My club wants to use one logger in our training glider to log multiple flights with different pilots for the purpose of reviewing flights as well as post in OLC. Is it possible to change the pilot info in the logbook after a days flying and then upload each Pilot’s flight?
Old July 3rd 19, 07:44 PM posted to rec.aviation.soaring
After importing the day's flights into the Logbook application, you can modify each individual flight's pilot, aircraft, airfield, etc. and add free-form flight comments. However, and I suspect this may be what you're really wanting to understand, making those modifications does not change the actual info contained in the .igc log file for the flight. The .igc file will always contain the original configuration data you loaded into the FlyWithCE recorder. If a correct .igc file is the goal then you'd need to reconfigure the recorder with the right info before each flight.
I don't think OLC really cares, however, what pilots name appears in the .igc file. Rather, the flight will get credited to whatever pilot account is used to claim the flight. Same thing for the aircraft type.
Robert
Anyone used FlywithCE? smithcorp Soaring 42 June 7th 11 12:24 AM
Anyone used FlywithCE? rec.aviation.soaring[_2_] Soaring 0 June 5th 11 06:28 PM
flyWithCE tip #2: flyWithCE Flight Recorder and OLC urosp Soaring 0 February 16th 11 05:28 PM
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? urosp Soaring 0 February 11th 11 06:39 AM
FlyWithCE V2.1 SUA Ken Kochanski (KK) Soaring 1 June 14th 06 08:34 PM
