More trailer tire/wheel issues
Old July 19th 19, 02:10 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Default More trailer tire/wheel issues
Clay
You should have your bearings/ brakes checked out by a mechanic if you can't do it yourself.
Getting hot like you describe is not right.
Your not going to get very far with them heating up on a flat short drive.
Old July 19th 19, 02:53 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
On Thursday, July 18, 2019 at 6:39:36 PM UTC-7, Clay wrote:
Thanks Richard do they get hot?
No they do not get hot. Hubs are not even warm to the touch on normal drives. I have not touched them after an extended down hill drive. I will try that in the future. The only time I lost a tire was I suspect from tire age 18 years.
Richard
www.craggyaero.com
Old July 19th 19, 03:45 PM posted to rec.aviation.soaring
AS
On Friday, July 19, 2019 at 9:11:01 AM UTC-4, Nick Kennedy wrote:
Clay
Your not going to get very far with them heating up on a flat short drive..
I cannot confirm any of these described design deficiencies! My ~2012 vintage Cobra dual-axle trainer got moved across the US from SC to NM now four times - 1,600 miles each way - plus once to CO and back over some pretty punishing road surfaces. I installed a TPM system and keep an eye on the pressure and temperature of each wheel. Even during the long descent on I-70 west of Denver or while doing the 'Million Dollar Hwy' did the tire temperature not increase notably. I always check the hubs during gas stops and never burnt my finger.
The only thing I need to change now is the damper in the over-running brake, which seems to have gotten weak.
Please note that these trailers in Germany are subject to a state inspection every two years, where the brake and light system is checked, so regular maintenance is advised and generally accepted for the sake of keeping them safe.
The argument 'they don't use large pick-ups and SUVs over there, so we don't need brakes on our trailers here' is laughable! Once the towing vehicle is no longer perfectly in line with the trailer, the trailer will try to pass you - no matter what you are sitting in. The 'Auflaufbremse' or overrunning brake system is designed to keep the trailer behind the towing vehicle longer.
Uli
'AS'
Old July 19th 19, 05:53 PM posted to rec.aviation.soaring
Clay
Uli
'AS'
I'm with Uli (AS). Knocking German enschineering is just not right, you hear that, Chip? You all should learn German anyway, would help when you study our "Auflaufbremse".
Herb, J7, flying and trailering in Tscherman Enschineered machines.
Old July 20th 19, 12:10 AM posted to rec.aviation.soaring
I've trailered my 1992 Cobra back and forth myriad times from NJ to Hobbs, Uvalde, Nephi, Cordele, TSA, etc. Most of the time everything is fine. The hubs are barely warm and everything works right.
But once in a while, from when the trailer was a few years old, a hard stop (not a locking-the-wheels, screeching-tires panic stop but just when someone cuts in front and you have to brake suddenly), the surge brake locks up and won't release. And with no backup cam, I can't see it. I just know to pull over and check right away. And now I watch the TPMS: the temperature rise seems to give me a heads up that it's happening.
I'm a mechanical engineer originally. I've been doing brake work for almost 50 years on my vehicles. I worked for 10 years for a company that made OEM and aftermarket brake parts. IMO, there's some vulnerability in the Al-Ko system that--when triggered--causes bad things to happen. As I detailed before, I've tried nearly everything this time. It locked up on the way back from TSA/Dallas last summer so I did a lot of maintenance/adjustment/replacement then and thought I had it fixed. And apparently I did--for a while. But on the way back from Columbus, OH last month (after the Stds. were postponed), I had to brake hard. I pulled over a few miles later and, sure enough, same problem. I just disconnected the brake system then to get home (I've had a lot of practice). More work after that. Last week on the way to and from Blairstown, the same problem. I'm running out of things to do.
There's a problem. I'm sure something is out of adjustment or alignment or something somewhere. And when that happens, disaster. As much as I love [most] German engineering, I shouldn't have to ship the trailer back to Germany to get it to work right!
Chip Bearden
Old July 20th 19, 12:34 AM posted to rec.aviation.soaring
JS[_5_]
Chip, if it started after Dallas perhaps a bullet from the "Who shot JB?" incident got lodged in the brakes.
Old July 20th 19, 01:53 AM posted to rec.aviation.soaring
Too cruel!
UH
Old July 20th 19, 03:08 AM posted to rec.aviation.soaring
Dan Marotta
JR...
Dan, 5J
Old July 20th 19, 04:35 AM posted to rec.aviation.soaring
AS
Chip Bearden
Chip,
don't get me wrong - that has nothing to do with waving the German engineering flag! I am a ME too and deal a lot with complex mechanical systems.
Your brake system is purely made up from levers, cams, pull-rods, bell-cranks and maybe a set of Bowden-Cables. Somewhere in that system is one element, which - when you brake hard - goes into a lock-up condition and won't release. It could be a cam that rotates too far or a pull rod, which gets hung up somehow. I found a few YouTube videos showing how to adjust an ALKO Auflaufbremse but they are all in German.
Have you contacted Spindelberger (or W&W) to get a schematic for your axle and brake set-up? I am sure they can provide you with a trouble shooting guide and an adjustment instruction. With some additional info, you can return the system to function properly - it's not rocket surgery!
Uli
'AS'
Old July 20th 19, 05:37 PM posted to rec.aviation.soaring
OK...general tire info from someone that does PT work in a tire shop.....
BTW....I did a real long reply to this thread.....whatever reason it evaporated.......
Tires....age is a killer.
On pretty much ANY tire is a mold date. Shop should NOT sell as new beyond 3 years from mold date.
Period.
At least in the US (likely other locations), should be a molded oval about 1"X1/2"...,,(metric.....figure it out....inches landed on the moon...nuff said.....yes, biased....).
There should be a 4 digit number......first 2 is week of the year .....0-52, last 2 is last 2 of year........
So.....a "4217" is......42'nd week of the year 2017.
"Thou shall not sell as new beyond 3 years from mold date".
Period. I believe US law.
Prime reason, from decades of dealing with tires,.....age....usually UV aging added to low pressure. Ramy does a lot of travel....so he is on the good side. He checks pressures, does miles, a perfect tire/I'm loses some pressure over time....not counting the "rule of thumb" that tire pressure changes about 1 PSI/*F change in temp. Metric guys.....figure it out...
Sitting on low/flat tires does NOT help.
Old tires lose their flexing, thus overheat and tread thrown.
Yes, US is usually longer trips at higher speeds.
No slight on other regions.
I see more blown tires from trailers sitting for years, likely low in pressure, then subjected to high highway speeds with aged tires.
Discuss......
FS - New Tost Brass 200 x 50 Tail Wheel with tire and tube Dave Springford Soaring 1 June 26th 18 11:12 AM
Tost brass tail wheel, tube, tire for sale: USA Barny Soaring 2 August 12th 11 10:43 PM
Spare wheel/tire Steve Freeman Soaring 0 August 12th 10 11:21 PM
looking for wheel/tire/brake Brad[_2_] Soaring 1 July 29th 10 02:56 AM
Wheel pants for 6.00 x 6 wheel/tire Wallace Berry Home Built 2 January 23rd 04 04:22 AM
