Ventus rigging advice, please?
Old July 21st 19, 07:12 PM posted to rec.aviation.soaring
John McLaughlin
Default Ventus rigging advice, please?
Thanks everyone - I think I've got it cracked now - right wing first, tape
it.
Then, the big thing I've learnt is to feel inside the battery rack below
spars. I can now tell, by feel whether the second wing is too high or too
low
and knowing that makes all the difference.
  #32
Old July 21st 19, 07:27 PM posted to rec.aviation.soaring
John McLaughlin
And maybe next time, I should proof read my posting!
  #33
John McLaughlin
  #34
Old July 22nd 19, 02:44 AM posted to rec.aviation.soaring
Steve Bralla
it.
low
Not the way I do it but if it works for you.... Practice is the most important thing. Enjoy your Ventus. I'm enjoying mine.
Steve
  #35
Old July 22nd 19, 05:00 PM posted to rec.aviation.soaring
2G
it.
low
I put reference marks on the spar butt ends and inside the fuselage that indicate when the correct dihedral angle is achieved. I also using my index finger to feel for a mismatch between the main pin bushings while adjusting the height of the fuselage jack (start low and gradually go up). You can feel even the slightest misalignment.
Tom
  #36
Old July 22nd 19, 07:35 PM posted to rec.aviation.soaring
John McLaughlin
'Not the way to do it'
Why not?
  #37
Old July 22nd 19, 09:04 PM posted to rec.aviation.soaring
He said not the way "I" do it. Quite a difference.
Dan
Why not?
  #38
Old July 22nd 19, 09:49 PM posted to rec.aviation.soaring
Paul Hodgetts
..... Or you could swap it for a K6e, John. Never a problem to rigg, and
you
would get some change.
Keep smiling, Paul H
  #39
Old July 22nd 19, 10:35 PM posted to rec.aviation.soaring
John McLaughlin
Apologies to Steve and thanks for your wise words Dan and Paul.
  #40
Old August 3rd 19, 10:05 PM posted to rec.aviation.soaring
On Tuesday, June 25, 2019 at 5:00:05 AM UTC-4, John McLaughlin wrote:
I've recently started flying a Ventus2. I can't rig the thing without a lot
of
struggle. The trouble is, there's a cover above the spars and you can't see
anything once the first wing is in.
I struggle to get the second wing to fit, never knowing whether it's a bit
too
high or a bit too low. The ground is uneven and sloping, which doesn't
help.
I hope some Ventus owners can give me some tips, please?
ventus rigging visual clues [email protected] Soaring 13 May 3rd 18 12:08 PM
Ka-6 Rigging vontresc Soaring 19 August 14th 08 04:55 AM
Ventus C rigging James Hamilton Soaring 8 July 7th 06 08:30 AM
Ventus C rigging James Hamilton Soaring 0 July 6th 06 07:41 PM
ski rigging Drew Dalgleish Home Built 3 December 3rd 03 04:16 AM
