what is that noise?
Old July 26th 19, 04:57 AM posted to rec.aviation.soaring
Default what is that noise?
I've heard that in hundreds of videos, more often in two seaters. Watch a few Duo Discus vids, you'll see what it mean. I believe it's almost certainly the spar stubs rubbing.
Old July 27th 19, 02:32 PM posted to rec.aviation.soaring
gregv
Le lundi 22 juillet 2019 12:39:11 UTC+2, gregv a Ă©critÂ*:
Hello, I fly a 1979 Nimbus 2 carbon, and since a few years I hear a cracking noise behind me. That noise occurs more often after a few hours of flight, maybe related to temperature change with altitude. You can hear the cracking noise in this video:
https://www.youtube.com/watch?v=pke-...ature=youtu.be
Did you already hear that noise? how do you think I can fix this ? do you think it is dangerous?
Thank you for help and advice
Ok so I checked carefully the glider on the ground and I seems I could reproduce the noise.
Lift Pins and bearings are ok, no rubbing clue on the spar neither on the fuselage. The noise is not related to outer wings.
When the airbrakes are open, there is no more noise... so it must be related to airbrakes... I can hear the noise coming from the airbrakes / flaps, and if I put my hand on them as they are closed and that I put the wing for and aft I can hear and feel the noise with my hand. When I inspect the airbrakes mechanism everything seems ok. Strange thing is that the noise is symetrical on both wings.
Old July 27th 19, 04:15 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
If that was my glider (I'm in the UK) I'd being asking the inspector who
does my Annual Inspection to take a look at it. Doing that in the past
has both found problems I've missed and shown that things I asked him
about were non-problems.
Martin | martin at
Gregorie | gregorie dot org
  #24
Old July 28th 19, 01:35 PM posted to rec.aviation.soaring
I'm reading this as you pull/push the wing tips for and aft and feel the noise in the airbrake system. If so, how much force, how much do the wing tips move and is there a spec limit for this in the poh or maint manual?
  #25
Old July 30th 19, 05:00 AM posted to rec.aviation.soaring
Charlie Quebec
On my DG200 fore and aft play in the wings is eliminated by shimming the lift pins. If a shim has come loose, and dropped of it could cause such issues.
  #26
Old July 30th 19, 01:53 PM posted to rec.aviation.soaring
What, if anything is supposed to hold the shims in place when the glider is in the unassembled state?
  #27
Old July 30th 19, 02:52 PM posted to rec.aviation.soaring
Gliders with removable lift pins have the shims under the shoulder of the pin.
UH
  #28
Old July 31st 19, 05:05 PM posted to rec.aviation.soaring
John Wells[_2_]
My Mini Nimbus creaks on hot days -- more if it's been left out in the sun
before launch. It sounds like flexing plastic to me, and I've always put it
down to the canopy expanding/contracting a different amount to the fus. I
think it goes away eventually in flight (or at least, I tend to only notice
it at
first).
Your video sounds more like a banging noise, but it's hard to tell from the
video... it could be the same creaking perspex noise I hear.
J
glider
shimming
such
issues.
pin.
UH
  #29
Old July 31st 19, 05:34 PM posted to rec.aviation.soaring
I agree with a earlier poster that I would look in the airducting system Sounds like a vent cover or something hard but loose in the airflow.
  #30
Old August 1st 19, 02:51 PM posted to rec.aviation.soaring
The howling in the tail boom might be from air pressure coming in and it doesn’t have a escape.
You can try leaving the wing tape off at the trailing edge about one inch. It helped on my Lak.
W7
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
noise G.A. Seguin Soaring 2 August 27th 03 01:57 AM
Com noise Hankal Piloting 0 July 21st 03 12:54 AM
