Altimeter in Millibars Wanted
Old July 30th 19, 05:31 AM posted to rec.aviation.soaring
slbair
Default Altimeter in Millibars Wanted
Looking for a 57 mm altimeter in millibars.
Old July 30th 19, 07:16 AM posted to rec.aviation.soaring
got 80 mm
Old July 30th 19, 01:01 PM posted to rec.aviation.soaring
slbair
Only 57mm will work, but thanks anyway.
Old July 30th 19, 05:52 PM posted to rec.aviation.soaring
Dan Marotta
I have one, but I'd need one of the same size in inches to trade. Are
you in the US?
Dan, 5J
Old July 30th 19, 06:42 PM posted to rec.aviation.soaring
slbair
Yes. I have a four year old Winter. I'm selling my glider to someone in New Zealand who need a mm instrument. I'm in Alabama. What do you have available?
Old July 31st 19, 03:28 AM posted to rec.aviation.soaring
I have a Winter 4FGH40 with altitude in feet and barometric setting in millibars.
Old July 31st 19, 03:33 AM posted to rec.aviation.soaring
slbair
Thanks but I need altitude in meters.
Old July 31st 19, 04:11 AM posted to rec.aviation.soaring
son_of_flubber
The gliders that I flew in NZ in 2017 used feet for altitude (as did the aeronautical charts and airspace definitions). Distances on the ground were measured in kilometers. Airspeed in knots. Vertical speed in Meters per second.
Have the Kiwis switched over to measuring altitude in Meters?
Old July 31st 19, 07:41 AM posted to rec.aviation.soaring
Ross[_3_]
Buy an ACD from Air Avionics.
It is a TSO approved digital altimeter and at the press of a button you can change from feet to meters and back.
It is also clever enough to be used as a head unit for a radio and transponder.
It is also cheaper than a new winter altimeter.
Old July 31st 19, 01:07 PM posted to rec.aviation.soaring
Jim White[_3_]
Sorry, mine is in hectopascals!
Wanted used 3 1/8 in Altimeter [email protected] Soaring 7 January 8th 17 09:29 PM
Winter altimeter exchange wanted [email protected] Soaring 0 November 6th 14 05:49 PM
WTB: used 57mm Altimeter OR swap for 80mm Altimeter joesimmers Soaring 0 November 3rd 09 11:59 AM
Inches of Mercury or Millibars / Hectopascals Cockpit Colin Piloting 1 May 1st 04 02:03 AM
Electronic Flight Computers that work in Millibars Cockpit Colin Piloting 3 April 19th 04 08:23 AM
