Ventus rigging advice, please?
Old August 3rd 19, 11:08 PM posted to rec.aviation.soaring
Default Ventus rigging advice, please?
On Tuesday, June 25, 2019 at 5:00:05 AM UTC-4, John McLaughlin wrote:
I've recently started flying a Ventus2. I can't rig the thing without a lot
of
struggle. The trouble is, there's a cover above the spars and you can't see
anything once the first wing is in.
I struggle to get the second wing to fit, never knowing whether it's a bit
too
high or a bit too low. The ground is uneven and sloping, which doesn't
help.
I hope some Ventus owners can give me some tips, please?
Having read the entire string of postings I am surprised to see that nowhere is lubrication mentioned. All the tips are great, but a little grease goes a long way in taking a little of the hassle out of rigging S-H sailplanes.
  #42
Old August 4th 19, 05:47 AM posted to rec.aviation.soaring
A clean set of pins and some lube goes a long way in rigging......period......
  #43
Old August 6th 19, 10:46 PM posted to rec.aviation.soaring
2G
of
too
help.
Cleaning and greasing is always recommended (and I assume he already did this), but no amount of grease can overcome misalignment. And if the glider can be assembled with wings misaligned, the fittings are shot.
Tom
  #44
Old August 7th 19, 06:09 PM posted to rec.aviation.soaring
On Saturday, August 3, 2019 at 9:47:38 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
+1 for my Ventus B. I spent a year or two trying to figure out why, with all things to the best of my knowledge the same, sometimes the wings would protest and sometimes not. Fresh lube each rigging has provided the answer.
  #45
Old August 7th 19, 07:50 PM posted to rec.aviation.soaring
See this video.
https://www.youtube.com/watch?v=Em7MtTdx_Uo
Note: align vertical to be vertical
right wing first
and.....don't expect it to be that easy.....
Dan
of
too
help.
  #46
Old August 8th 19, 03:02 AM posted to rec.aviation.soaring
2G
....and you simultaneously figured out how to align the wings to the fuse. Don't believe me? Misalign the wings and see if they still go on. Alignment is the key (I have had no problem assembling gliders w/o ANY lube)...
  #47
Old August 8th 19, 03:19 AM posted to rec.aviation.soaring
2G
On Wednesday, August 7, 2019 at 10:50:16 AM UTC-7, wrote:
See this video.
right wing first
Dan
of
too
help.
I own an IMI electric rigger and it is clearly the best one-man rigger out there. It isn't cheap, but it is well-built. My only advice is to get a spare battery. Somehow my power switch got turned/left on and the battery was totally flat when I wanted to rig. I had to add FASTON connectors to make a battery change quick.
Tom
  #48
Old August 8th 19, 05:30 PM posted to rec.aviation.soaring
Nope. Rather, I'm sure it is that you mistakenly attribute your success in rigging to alignment rather than that you're now properly lubing (see how useless a comment like that is? We could go back and forth forever...)
  #49
Old August 9th 19, 06:43 AM posted to rec.aviation.soaring
2G
Bottom line: I have rigged plenty of gliders WITHOUT any lubing WHATSOEVER. Period.
  #50
Old August 9th 19, 02:33 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Somehow Tom, this must be a metaphor for your life.
ventus rigging visual clues [email protected] Soaring 13 May 3rd 18 01:08 PM
Ka-6 Rigging vontresc Soaring 19 August 14th 08 05:55 AM
Ventus C rigging James Hamilton Soaring 8 July 7th 06 09:30 AM
Ventus C rigging James Hamilton Soaring 0 July 6th 06 08:41 PM
ski rigging Drew Dalgleish Home Built 3 December 3rd 03 05:16 AM
