Schempp Hirth Airbrake is partially not flush when locked
Old August 12th 19, 06:16 PM posted to rec.aviation.soaring
Default Schempp Hirth Airbrake is partially not flush when locked
Hi,
A small part of My Ventus C airbrake, in the middle of the brake, is protruding above the wing when locked, enough to annoy me.
The 2 ends of the brake are fine, a small part is sticking slightly above the wing surface when the brakes are locked.
Any ideas ?
Dan
Old August 12th 19, 07:01 PM posted to rec.aviation.soaring
Bob Kuykendall
On Monday, August 12, 2019 at 9:16:30 AM UTC-7, wrote:
Any ideas ?
Start by checking freedom of motion in the suspension between the airbrake cap and the upper paddle. Make sure the springs pull it all the way down onto the top of the upper paddle, and that there aren't sticky spots within its range of motion. Resist the temptation to tighten the springs, that often just makes other things worse.
If the cap and springs are OK, check how the cap fits into the recess in the wing. Look for something in there that interferes with the cap.
Beyond that, you pretty much need a borescope to see what's going on.
--Bob K.
Old August 13th 19, 12:04 AM posted to rec.aviation.soaring
Any ideas ?
--Bob K.
Also look for interference between the front or rear faces of the cap and the wing pocket. If you lock the spoilers and you can seat the cap with a smack of your hand, you have a bind.
UH
Schempp-Hirth 2a/2b cockpit fit vs ASW-20? [email protected] Soaring 14 April 9th 12 02:46 PM
schempp-hirth shk-1 shkdriver Soaring 3 September 5th 08 04:38 AM
FS: Schempp-Hirth Discus A Tim Hanke Soaring 0 February 19th 06 03:16 PM
Schempp-Hirth Mel Dawson Soaring 0 February 15th 06 05:08 PM
Schempp Hirth or its Representatives... Chris OCallaghan Soaring 11 September 23rd 03 10:28 AM
