Blade type VHF antenna?
Old December 7th 03, 02:14 PM
JFLEISC
Default Blade type VHF antenna?
Can anyone tell me if there are any significant electronic performance
differences in those "shorter blade type" (just over a foot) VHF com antennas
from the standard length stainless whip?
Old December 7th 03, 07:01 PM
Jim Weir
It depends ENTIRELY on how they are foreshortening the antenna. If they are
using super-wide conductors (the entire width of the blade) to get the
foreshortening, then it is a very efficient antenna. If they are using loading
coils inside with a relatively narrow antenna diameter, it is a very inefficient
antenna.
The only way to know for sure is to ask the manufacturer for a data/spec sheet
or cut the antenna open.
(JFLEISC)
-Can anyone tell me if there are any significant electronic performance
-differences in those "shorter blade type" (just over a foot) VHF com antennas
-from the standard length stainless whip?
-Jim
http://www.rst-engr.com
Old December 8th 03, 12:17 AM
JFLEISC
loading
inefficient
antenna.
sheet
Will one of those SWR meters tell you anything?
Old December 8th 03, 06:26 AM
Jay
No, it just tells you how good the impedance match is. A good match
is a necessary, but not sufficient condition, to a high efficiency
antenna installation. However, a power meter in the far field will
tell you how good your antenna is and give you a relative indication
of how adjustments are effecting your ability to reach out and touch
someone.
(JFLEISC) wrote in message
Old December 9th 03, 02:42 AM
Peter Dohm
someone.
Very true, and the efficiency may depend on the surface used as a
ground plane as much as anything else.
Peter
P.S.: It is also usefull to check more than one frequency!
Old December 12th 03, 11:58 PM
smithxpj
antenna.
I tried that stunt back in the early 80's out of interest.
The couple of manufacturers that I asked were very coy about parting
with detailed information about what was inside their antennas. It was
very generic stuff like..."a printed circuit etched radiator with
double sided etched capacitors and inductors appropriately tapped to
the radiator to achieve optimum matching" !!!
I once managed to get access to an industrial X-ray machine and got a
picture of the innards of a Collins military VHF-UHF blade antenna.
Eye opening stuff, indeed...but trying to reproduce it? It would
hardly be worth the manhour effort compared with knocking up a 26"
piece of 1/8" brazing rod into a 1/4 wave radiator.
Old December 13th 03, 04:28 AM
Roger Halstead
On Sat, 13 Dec 2003 10:58:17 +1100, smithxpj
antenna.
If it's a blade type, why not put in a flat piece of brass or copper
stock and trim for resonance, or use a matching network?
I'd think something that large (length to width) wouldn't take much
loading. OTOH I guess linear loading could be used. Double sided
circuit board with the back a thin ground....maybe widening out to
provide more capacitance near the end... It'd take some
experimenting, but I'd think it'd work.
I know...Lots of weasel words, but I haven't actually tried it so it's
more thinking out loud.
(N833R, S# CD-2 Worlds oldest Debonair?)
www.rogerhalstead.com
Return address modified due to dumb virus checkers
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
Marker Beacon Antenna - Paging Jim Weir. Bart D. Hull Home Built 1 November 27th 03 10:31 PM
Type of wing carrythrough? Toks Desalu Home Built 0 October 30th 03 08:35 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 05:21 PM
