Trigg- TT 22 problem
Old September 3rd 19, 02:51 AM posted to rec.aviation.soaring
Default Trigg- TT 22 problem
Hi, I have Trigg- TT 22 installed this spring and after about 70 flight hours I am getting warning message on display : WARNING DPSK UNLOCK. After pressing ENT button normal 1202 squawk reappears for about only a minute . Public ADS-B performance report from my flight is fine. Anyone had similar warning? What does DPSK stands for? There is no help in user manual on this issue. Thank you. Pavel
Old September 3rd 19, 03:17 AM posted to rec.aviation.soaring
Darryl Ramm
DPSK would mean Different Phase Shift Keying, which is the data modulation used in Mode-S transponders to generate the message packets.
To me "Unlock" makes it seem more likely a internal clocking or digital related problem. Lik
Trig has pretty responsive customer support, through Mid Continent in the USA and email support from Trig HQ. In this case I suspect you'll need to get the unit to Mid Continent for some quality time on a repair bench.
https://www.mcico.com/medias/Trig%20...20Radios .pdf
Old September 3rd 19, 05:09 AM posted to rec.aviation.soaring
Darryl Ramm
s/Different/Differential/
Old September 4th 19, 12:30 AM posted to rec.aviation.soaring
Thank you very much , I will check all cables and connections again before sending unit to service center.
RAS Problem? John Dezzutti[_3_] Soaring 7 June 9th 09 05:28 PM
Contact Info for Trigg Adams sisu1a Soaring 1 March 13th 09 04:10 AM
ADF Problem tony roberts Instrument Flight Rules 14 May 12th 04 03:59 AM
do I have an ADF problem ? Dave Jacobowitz Instrument Flight Rules 6 April 1st 04 01:58 AM
KY 97A problem Continental Bill Piloting 0 October 18th 03 09:20 PM
