#41
"Pete" wrote:
"Gord Beaman" wrote On current aircraft, the fail mode is safe. The arming solenoids need power to energize and retain the clip and wire. The ejector carts run on different, multiple circuits. Pete Thanks Pete, I didn't know that, I wonder what the rationale would be for the change?... Could it be that during WW2 they considered it more important to avoid a failed bomb run than they do now?. Interesting indeed. -- That's probably the case. Peacetime vs WWII mindset. Better design and greater reliability reduces the chance of the mechanism failing, so we can default to the 'safe' mode, and arm only on request. Consider a training mission, with live ordnance. Aircraft has a problem, and the pilot has to jettison the munitions. Do we jettison safe or armed? Since we are always over friendly territory, defaulting to safe mode would be preferable. Pete Certainly sounds plausable... -- -Gord. |
#42
"Gord Beaman" ) writes: (Peter Stickney) wrote: I was able to make out the serial on the aft fuselage. It's definitely a Lanc. (Although if it _were_ a Manchester, that would explain the lack of engine noise. ![]() Sure...two engines vice four... I have to agree with you, Gord. While I don't have any flights in a Lancaster, I've seen and heard one, and I've flown/ridden in teh C-47, C-123, C-131 (Recip Cosmo), and C-118 (DC-6), and the one common denominator is the constant noise and vibration. Even when the noise is cut back by the headsets, the vibration's always there. I can't see any sort of the disk-cutters they used back then being isolated from that. While the Germans had made an early form of tape recorder, it wasn't a practical or portable system, using what were essentially bandsaw blades moved at high speed as the recording medium. Quite true, and here's another possibility(?) for a recording medium...The Lancs that we had in the early/mid fifties were equipped with a 'magnetic wire recorder'. They were used to record the sonobuoys audio output of underwater sounds. Do you suppose they may have had those during the war years?...Ours was a cute lil guy about 1,5 feet long, 8 inches high by 4 inches wide. You could see the two wire spools through the glass in the front loading door, The wire looked very thin and looked like shiny steel. (be aware that the memory of those measurements etc is some 50 years old!) Sorry for taking so long, but... I did some checking, and I'd be very surprised if any airborne audio recordings from that era were made on Wire Recorders. While the basic idea of Wire Recorders had been around since the 1920s, the recorders were refrigerator-sized monstrosities that had really lousy frequency bandwidth, and horrible signal/noise ratios. Some were built and sold as telephone messaging systems, and some were used for dictation. None were remotely portable. In mid 1943, advances in low-noise amplifiers, and miniaturized vacuum tubes (valves) allowed Marvin Camras, of the Armour Research Foundation to build a portable, reliable wire recorder. The U.S. Navy ordered 1,000 ARF Wire Recorders, to be lisence-built by G.E. http://www.videointerchange.com/wire_recorder1.htm is a good place to start. It seems that wire recorders had one advantage over tapes - splicing was done with a square knot. These military recorders were used as audio and analog data recirders in large ASW and ELINT (Ferret) aircraft, and are, no doubt, the direct ancestor of teh unit in your P2V. I'm willing to bet Local Currency vs. Local Breakfast Pastry that there wasn't one used in a Bomber Command Lancaster to record a Night Raid for the BBC. As to the comment from another post in this thread, yes, lip mikes existed, but that theory falls down on two points. If I'm remembering things correctly, you can't just plug one into a system intended for Carbon mikes - As I Seem To Recall, there are impedance matching issues that require some manner of additional circuitry. It wouldn't have been impossible, but I can't imagine the RAF restringing the interphone system on a single Lancaster just to accomodate the Propaganda Campaign. The other factor is that lip mikes and Oxygen Masks don't mix. Bomber Command Lancs spent their missions at night up past 18,000', and supplemental Oxygen is necessary t those heights, and very useful at much lower altitudes. (The extra O2 increases night vision). There should be 8 or 9 guys on that airplane, all waring Oxygen masks, and all, at som epoint, talking on the intercom, with the mask microphones. We ought to hear _somebody_ breathing, dagnabbit! -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#44
In message , Peter Stickney
writes snip As to the comment from another post in this thread, yes, lip mikes existed, but that theory falls down on two points. If I'm remembering things correctly, you can't just plug one into a system intended for Carbon mikes - As I Seem To Recall, there are impedance matching issues that require some manner of additional circuitry. It wouldn't have been impossible, but I can't imagine the RAF restringing the interphone system on a single Lancaster just to accomodate the Propaganda Campaign. The lip mic would have fed the small mixer unit at the recorder. The a/c intercom would be another input, suitably padded down. The other factor is that lip mikes and Oxygen Masks don't mix. Yes, I imagined WVT using an oxygen mask until he wanted to speak then unclipping, saying his stuff, then clipping back up. d Bomber Command Lancs spent their missions at night up past 18,000', and supplemental Oxygen is necessary t those heights, and very useful at much lower altitudes. (The extra O2 increases night vision). There should be 8 or 9 guys on that airplane, all waring Oxygen masks, and all, at som epoint, talking on the intercom, with the mask microphones. We ought to hear _somebody_ breathing, dagnabbit! Was it common practice to stay switched off until you wanted to say something? In my recording, there is no breathing audible. Everyone was 'off' until speaking. Mike -- M.J.Powell |
#45
"M. J. Powell" wrote:
Was it common practice to stay switched off until you wanted to say something? In my recording, there is no breathing audible. Everyone was 'off' until speaking. Mike Yes Mike, that's the drill, although for take-off and landing on some aircraft the pilots and engineers are supposed to go to 'hot mics'. I never liked hot mics much, lets too much noise into the intercom. The left seat on The Argus was always on for landing though and it was easy to see how hard he was working by the sound of his breathing...kind of funny at times, nobody seems to know how he sounds himself. That's another reason that the audio sounded unreal, no mic clicks and 'hiss' indicating an open mic. -- -Gord. |
#46
Quote:
Rear gunners don't give the instruction to weave, they give the instruction to corkscrew. 2. As above, its an area bombing mission. No issues called by more revs. Pilot will be thinking about climbing away once the photorun has finished. 3. As long as they stay on course, weaving is not a problem. 4. The mid upper gunner got the kill, but even The sound is recorded from the crew's microphones, which picksup engine noise and the brownings. But most of all the picks up the voice of whoever is speaking into them, otherwise, what good do they serve? Recording or no recording. |
| King KMA 20 TSO Audio Input | tony roberts | Home Built | 10 | November 20th 04 07:06 AM |
| Audio recording of RAF Lancaster under nightfighter attack | Stolly | Military Aviation | 65 | October 8th 03 02:54 AM |
| Bu$h Jr's Iran-Contra -- The Pentagone's Reign of Terror | PirateJohn | Military Aviation | 1 | September 6th 03 11:05 AM |
| Lancaster returns to AWM | Graeme Hogan | Military Aviation | 2 | July 24th 03 02:08 PM |
| Letter from USS Liberty Survivor | Grantland | Military Aviation | 1 | July 17th 03 04:44 PM |
