At 09:09 04 October 2019, Tango Whisky wrote:
Le jeudi 3 octobre 2019 22:30:05 UTC+2, Jonathon May a =C3=A9crit=C2=A0: At 18:22 03 October 2019, Eric Greenwell wrote: Jonathon May wrote on 10/3/2019 9:55 AM: =20 I have been using a Dive type cylinder because they are easier=20 to get re filled. Last Saturday I was flying with the bottle on but the regulator=20 off above a ridge trying to connect to the wave system. About 1 hour in and 2700ft asl there was a loud pop and bottle pressure O2 started blowing into the cockpit . I could not turn the bottle off so I opened the DV window put a Pan call out and got it back on the glider field in about 3=20 minuets . I have never been so scared ,and I have loads of field landings=20 and thousands of hours in gliders. I had a similar experience thus summer - the connector on the MH regulator = obviously had worn out over the about 20 years of use and decided to let go= the connecting hose to the EDS unit. I can't reach the cylinder inflight without an immense effort of wiggling m= yself, and as I was close to the rocks trying to get the first climb of the= day, I just kept on flying. The oxygene pressure on the outlet of the regu= lator is 2 bars or less, so it can't do any harm. That seems reasonable,I had 200Bar bottle pressure. |
Le vendredi 4 octobre 2019 14:45:05 UTC+2, Jonathon May a écritÂ*:
That seems reasonable,I had 200Bar bottle pressure. That's what I figured. Freeflowing oxygene at 200 bars is no place to be. It would spontaneously combust any grease in its reach. |
LXNav V7 Setup | svelusive | Soaring | 9 | February 22nd 15 04:29 PM |
A-37 Dragonfly smoke setup | Glenn[_4_] | Aviation Photos | 0 | December 27th 12 03:00 AM |
Vario setup | brianDG303 | Soaring | 1 | April 3rd 08 05:20 PM |
FS 2004 setup | Dave Hetteen | Simulators | 4 | June 25th 04 10:40 PM |
WX Works setup | Paul Tomblin | Piloting | 16 | December 8th 03 04:23 AM |
