On Sun, 5 Sep 2004 15:29:00 -0400, "George Z. Bush"
wrote: Thomas J. Paladino Jr. wrote: And for the record, when a proposal was floated to send F102s to Vietnam, Bush put his name in as a volunteer, however the powers that be decided not to use the plane. For the same record, when he first applied for flying training, he indicated on his application that he did NOT desire an overseas assignment. That's no smoking gun. I did NOT desire an overseas assignment when I entered the USAF. I did NOT desire an overseas assignment when I chose the F-105 (there were four wings in the US flying the airplane at the time.) I did NOT desire an overseas assignment when I got one to Korat Thailand. I did NOT desire an overseas assignment when I returned from Korat. In fact, I was in the AF for almost eight years before the first time I checked that box on the AF form 90. A lot of folks with and without families for a wide variety of reasons don't indicate a preference or desire for overseas assignment. And he had only 300 flying hours in the F-102 when he volunteered for overseas duty after he had been told that they wouldn't consider anybody with less than 500 hours. It was a pretty safe thing to do.....asking for something you knew in advance they weren't going to give you. And, when I went to war in the F-105 I had 120 hours in the airplane. When I went to war in the F-4 I had 28 hours in the type and ZERO hours in the model to which I was assigned. My first flight in an F-4E was a combat mission. So, there's not much "safety" in volunteering with a few less hours than required. That's just for the record, of course. This is just for the record as well. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Phantom Flights, Bangkok Nights" Both from Smithsonian Books ***www.thunderchief.org |
![]() "George Z. Bush" wrote in message ... Thomas J. Paladino Jr. wrote: And for the record, when a proposal was floated to send F102s to Vietnam, Bush put his name in as a volunteer, however the powers that be decided not to use the plane. For the same record, when he first applied for flying training, he indicated on his application that he did NOT desire an overseas assignment. Duh. He was in a National Guard unit. He could have put a big smiley face in the other block and it would have made no difference. His duty assignment was already set in concrete--he was going to return to his unit, the same one that sent him to flight school in the first place. You are incapable of understanding the differences between ANG and active component operations, aren't you? And he had only 300 flying hours in the F-102 when he volunteered for overseas duty after he had been told that they wouldn't consider anybody with less than 500 hours. Nope, he first asked about Palace Alert, and was *then* told they were then using the 500 hour limit; you have it all basackwards, as usual. It was a pretty safe thing to do.....asking for something you knew in advance they weren't going to give you. Wrong again. You have been told this before, so I guess your continued use of this tack is just your usual dishonest nature coming through again...Palace Alert did not maintain a set-in-concrete 500 hour experience requirement. The required experience level fluctuated based upon the pool of volunteers they then had--which is why later, as the program wound down, a mere junior LT found himself flying Palace Alert duty out of Iceland and participating in one of the USAF's last F-102 intercepts of a Soviet aircraft. That's just for the record, of course. Then your records are all screwed up. Brooks George Z. |
Date: 9/5/2004 4:03 PM Central Daylight Time Message-id: Subject: Why did Bush join the national guard? From: "Kevin Brooks" Date: 9/5/2004 1:18 PM Pacific Standard Time Message-id: "George Z. Bush" wrote in message ... Thomas J. Paladino Jr. wrote: And for the record, when a proposal was floated to send F102s to Vietnam, Bush put his name in as a volunteer, however the powers that be decided not to use the plane. For the same record, when he first applied for flying training, he indicated on his application that he did NOT desire an overseas assignment. Duh. He was in a National Guard unit. He could have put a big smiley face in the other block and it would have made no difference. His duty assignment was already set in concrete--he was going to return to his unit, the same one that sent him to flight school in the first place. You are incapable of understanding the differences between ANG and active component operations, aren't you? And he had only 300 flying hours in the F-102 when he volunteered for overseas duty after he had been told that they wouldn't consider anybody with less than 500 hours. Nope, he first asked about Palace Alert, and was *then* told they were then using the 500 hour limit; you have it all basackwards, as usual. It was a pretty safe thing to do.....asking for something you knew in advance they weren't going to give you. Wrong again. You have been told this before, so I guess your continued use of this tack is just your usual dishonest nature coming through again...Palace Alert did not maintain a set-in-concrete 500 hour experience requirement. The required experience level fluctuated based upon the pool of volunteers they then had--which is why later, as the program wound down, a mere junior LT found himself flying Palace Alert duty out of Iceland and participating in one of the USAF's last F-102 intercepts of a Soviet aircraft. That's just for the record, of course. Then your records are all screwed up. Brooks George Z. We are talking about military flying. A subject in which you have no experience whatever and therefore no right to comment. Arthur Kramer It's an off topic anti Bush rant started by YOU. It has nothing to do with military aviation so you have no right to tell others they can't comment. I don't get the impression you are trying to change anyone's mind. You are obviously posting for your own jollies. Tell me, do you masturbate when you spew this stuff? Dan, U.S. Air Force, retired |
![]() "ArtKramr" wrote in message ... Subject: Why did Bush join the national guard? From: "Kevin Brooks" Date: 9/5/2004 1:18 PM Pacific Standard Time Message-id: "George Z. Bush" wrote in message ... Thomas J. Paladino Jr. wrote: And for the record, when a proposal was floated to send F102s to Vietnam, Bush put his name in as a volunteer, however the powers that be decided not to use the plane. For the same record, when he first applied for flying training, he indicated on his application that he did NOT desire an overseas assignment. Duh. He was in a National Guard unit. He could have put a big smiley face in the other block and it would have made no difference. His duty assignment was already set in concrete--he was going to return to his unit, the same one that sent him to flight school in the first place. You are incapable of understanding the differences between ANG and active component operations, aren't you? And he had only 300 flying hours in the F-102 when he volunteered for overseas duty after he had been told that they wouldn't consider anybody with less than 500 hours. Nope, he first asked about Palace Alert, and was *then* told they were then using the 500 hour limit; you have it all basackwards, as usual. It was a pretty safe thing to do.....asking for something you knew in advance they weren't going to give you. Wrong again. You have been told this before, so I guess your continued use of this tack is just your usual dishonest nature coming through again...Palace Alert did not maintain a set-in-concrete 500 hour experience requirement. The required experience level fluctuated based upon the pool of volunteers they then had--which is why later, as the program wound down, a mere junior LT found himself flying Palace Alert duty out of Iceland and participating in one of the USAF's last F-102 intercepts of a Soviet aircraft. That's just for the record, of course. Then your records are all screwed up. Brooks George Z. We are talking about military flying. No, you are engaging in your usual political bashing attempt. A subject in which you have no experience whatever and therefore no right to comment. Translation of the above: "I can't address your specific comments, so I'll try to bluster my way out of the crap pile I again find myself in." What a sad little demented creature you have turned into in your old age--or were you always such an idiot? Brooks Arthur Kramer |
From: (B2431) Date: 9/5/2004 4:08 PM Pacific Standard Time Message-id: From: "Kevin Brooks" Date: 9/5/2004 3:18 PM Central Daylight Time Message-id: "George Z. Bush" snip the usual george z manure That's just for the record, of course. Then your records are all screwed up. Brooks First thing you have to understand is george z is a manure salesman with a mouthful of samples. The second thing is he was never in the military and has never bothered to figure out how the military actually works. Dan, U.S. Air Force, retired I think Geoirge Z flew C-47's in WW II as a troop carrier pilot. It's about time you told us what you did instead of attacking everyone while you conceal your great combat experiences. You get more like Bush every day. .. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
![]() From: (ArtKramr) Date: 9/5/2004 11:59 AM Central Daylight Time Message-id: Why did Bush join the National Guard instrae do the Army, Navy or Air Force? why? Arthur Kramer He DID go into the Air Force. The ANG is a component of the USAF. Now why do you insist on posting off topic rants about a better man than you? Dan, U.S. Air Force, retired |
From: (B2431) Date: 9/5/2004 11:53 AM Pacific Standard Time Message-id: From: (ArtKramr) Date: 9/5/2004 11:59 AM Central Daylight Time Message-id: Why did Bush join the National Guard instrae do the Army, Navy or Air Force? why? Arthur Kramer He DID go into the Air Force. The ANG is a component of the USAF. Now why do you insist on posting off topic rants about a better man than you? Dan, U.S. Air Force, retired He pulled strings to avoid combat. He is not much of a man. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
"ArtKramr" wrote
He pulled strings to avoid combat. He is not much of a man. Why join the military if you want to avoid combat? Your juvenile logic makes no sense to adults. |
Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 12:38 AM |
Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 09:38 PM |
George W. Bush Abortion Scandal that should have been | Psalm 110 | Military Aviation | 0 | August 12th 04 09:40 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
