iGlide functionality
Old July 13th 20, 02:45 AM posted to rec.aviation.soaring
MMOORE
Default iGlide functionality
So I'm still using the "lite" version (because I'm cheap), and this year, I have found that none of my flights are logged in the "log book". This was a feature of the Lite version last year, but something has changed and it is no longer logging my flights. What's up with that?
I had the same issue, support said to delete the app, wait some minutes then reinstall. Worked for me
Old July 15th 20, 02:00 AM posted to rec.aviation.soaring
Hightime
Save your important waypoint coordinates before you do reset or all is lost
NATS to enable ADS-B transponder functionality for GA WaltWX[_2_] Soaring 30 February 3rd 15 12:25 PM
When will my portable powerFLARM have its logger functionality? Sean F (F2) Soaring 40 March 18th 13 06:49 PM
Elevation info for Garmin Glide Ratio functionality Jack Glendening Soaring 1 July 30th 07 04:49 PM
Roll-based AP of same functionality as STEC-30 Andrew Gideon Owning 3 August 25th 05 06:57 PM
Roll-based AP of same functionality as STEC-30 Andrew Gideon Products 3 August 25th 05 06:57 PM
