Cobra Trailer Fenders
Old November 24th 19, 09:07 PM posted to rec.aviation.soaring
Tom BravoMike
Default Cobra Trailer Fenders
On Sunday, November 24, 2019 at 11:16:47 AM UTC-6, Patrick McMahon wrote:
A few items, the tires were considered in the purchase, I think 5 years old, pressure checked, sat on concrete patio stones with UV covered when not in heated storage. They were replaced as blown with 155/80/R13's to ensure I maintained a spare - which, will also be upgraded as we get to work with the ship.
The fenders were metal, did have the Cobra mudguard but did not have the wheel chock holder.
This is our most promising solution which would be an upgrade from the rounded metal fenders, and save us some cash toward neo wingtips - https://www.amazon.ca/Mudguard-Trail...omotive&sr=1-5
The trailer has been updated to LED lights, although my vehicle detected a fault which I could not immediately location (both side markers on both sides and all functions of the taillights worked). Now that I think about it, maybe the bulb for the license plate...
T8 - your math is bad, and your comment is insulting
Thanks Tom, but we'll be looking to replace both for less than the shipping of the one you have
Dan, 5J - seems like it, not much value on the juice:squeeze ratio
Thanks glidergeek, that's the kind of sense I'm aligned with
Sorry I asked.
Patrick, don't be sorry you asked. Your question gives us all in the soaring community a good opportunity to discuss and get cautioned about how important our trailer tires are, and to get a good advice based on the others' experience(s). I may have a Cobra trailer similar to your 1984, metal fenders), generally well maintained by previous owners. Goes beautifully behind my Mazda CX-5, manual gear. An incident I had with fenders was when one of them was hit by a tire debris on the expressway (saw it too late to dodge it). The fender got bent. An auto-body shop was able to fix it in a great way, and both fender got a nice new red paint. What I noticed, however, is that the paint gets hit by usual gravel and tiny stuff on the roads (have done thousands of miles across the US several times) and gets dented. I think I will put some temporary soft covers for next trips to protect them. Plastic fenders will be less trouble in that respect.
Old November 25th 19, 07:47 PM posted to rec.aviation.soaring
Tango Eight
It would be interesting to know what your tire pressure was.
Useful to know: all tires have a date code molded in.
155s are marginal. Most are SL or 79 load index and that's not enough for the application unless you are going to drive slow (60 mph). If you have enough clearance (almost certainly yes) and 4.5" rims (maybe) you could switch to 175/70-13 (same OD) which will give you a better selection to choose from. I would recommend at least 1100# load rating, at least 50 psi max, S or T speed rating would be good.
North American drivers in 2019 expect performance that wasn't on Cobra's map when your trailer was new.
T8
Old November 24th 19, 10:35 PM posted to rec.aviation.soaring
Tim Taylor
On Saturday, November 23, 2019 at 3:43:09 AM UTC-7, Patrick McMahon wrote:
Hey all, I trailered a (new to me and a partner) glider from Ontario to Alberta last week and through the trip blew out both trailer tires on the late-80's aluminum Cobra trailer and destroyed the fenders on the trailer through the event.
The first blowout (1:15am east of Madison, Wisconsin) contorted the right fender, the second (10:15pm north of St. Paul, Minnesota) cleared the left fender clean off - not recovered.
We've found the Cobra fenders on W&W, but at $135 per side, shipping and CAD conversion it seems fairly ridiculous. We've found some options on Amazon for off-brand fenders, has anyone used these? Or, are there any used Cobra fenders around? Or other suggestions?
Thanks in advance,
Patrick (LS6-b EH)
https://www.etrailer.com/Trailer-Fen...n/F008553.html
Old November 25th 19, 12:29 AM posted to rec.aviation.soaring
It hurts to replace tires that look like new, but....
Just buy new tires every five years.
Rubber rots.
All tire manufacturers advise replacing tires at five years.
Much cheaper than new fenders and possibly a new trailer.
Trailer wreck stories are endless and epic.
Sadly most are true and were preventable.
Old November 25th 19, 01:51 AM posted to rec.aviation.soaring
Tom BravoMike
Rubber rots.
It is not my in intention to argue about the usefulness or necessity of changing tires every 5 or 6 years - sounds reasonable - but I would like to hear from some independent source, maybe an automobile club like AA or RAC or similar, provided not corrupted by lobbyists. Maybe the German 'Stiftung Warentest'?
https://www.test.de/
Don't smartphone manufacturers suggest we should buy a new phone every 2 years, a new TV set every 4 years. Shouldn't houses be built for just one generation so that the construction industry can go on and on? Isn't it farmers who advertise: Drinka pinta milka day?
Old November 25th 19, 02:02 AM posted to rec.aviation.soaring
Tom BravoMike
Rubber rots.
It is not my in intention to argue about the usefulness or necessity of changing tires every 5 or 6 years - sounds reasonable - but I would prefer to hear from some independent source, maybe an automobile club like AA or RAC or similar, provided not corrupted by lobbyists. Maybe the German 'Stiftung Warentest'?
I've just taken a look and found this interesting (German) court decision:
https://www.test.de/Mogelpackung-Autoreifen-1215549-0/
but also this:
https://www.test.de/Autoreifen-Alter-erkennen-17311-0/
I hope Google can help you with translation.
Old November 25th 19, 06:30 AM posted to rec.aviation.soaring
2G
Rubber rots.
I did post such a reference - go back and read it.
Old November 25th 19, 02:47 PM posted to rec.aviation.soaring
I shattered a plastic Cobra fender when my ASW 24 was less than a year old. Not impressed. I replaced them with galvanized steel fenders from (then) Northern Hydraulics. Salvaged the mud flaps from the plastic junk and tossed the wheel chocks in the front of the trailer where no one would walk away with them in a parking lot. I've since lost two tires (we've had the tire discussion many times so do what you like) and damaged a fender both times. I just banged it back out. I do need to replace them now (they're 25 years old and stained/bent) but I'll just get another set of cheap metal fenders. You'll probably have to drill a few holes but no big deal.
Just my opinion. But $300 for a set of plastic fenders that will break the first time you hit debris or blow a tire? Please. I'm willing to baby the glider. The trailer I want to be bulletproof. Poor choice of words.
Chip Bearden
JB
Old November 25th 19, 04:23 PM posted to rec.aviation.soaring
Tom BravoMike
So I did go back and read your posts. I found this link you left:
https://www.discounttire.com/learn/tire-aging
You don't consider this to be an independent source, do you? I apologize if I'm missing something. Please help.
Happy Thanksgiving, anyway!
Removing oxidation from Cobra trailer trim rubber and plastic fenders Dave Nadler Soaring 11 September 25th 17 05:57 PM
FS Cobra Fenders Red NG Soaring 0 February 22nd 14 09:09 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 09:51 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
