Cobra Trailer Fenders
Old November 25th 19, 05:42 AM posted to rec.aviation.soaring
Tim Taylor
Default Cobra Trailer Fenders
"The NHTSA recommends that tires be replaced every six years regardless of the number of miles driven. Proper inflation is the Holy Grail of tire maintenance. Too much or too little air in your tires is guaranteed to cause you trouble and uneven or excessive wear over time.Dec 17, 2013"
Old November 25th 19, 02:42 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Tim Taylor wrote on 11/24/2019 9:42 PM:
The current recommendation is not so strict (2017):
"As tires age, they are more prone to failure. Some vehicle and tire manufacturers
recommend replacing tires that are six to 10 years old, regardless of treadwear.
You can determine how old your tire is by looking on the sidewall for your DOT
Tire Identification Number (TIN)."
https://www.nhtsa.gov/equipment/tires#topic-aging
Old November 25th 19, 03:54 AM posted to rec.aviation.soaring
cdeerinck
Can anyone tell me the size of tire a Cobra trailer needs, to save me from having to wait until I can go out to check?
Old November 25th 19, 04:24 AM posted to rec.aviation.soaring
JS[_5_]
Are yours 13" or 14" wheels?
Mine are P175/70-R14
Old November 25th 19, 04:39 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
cdeerinck wrote on 11/24/2019 7:54 PM:
What size are your wheels? What is the loaded trailer weight? Maybe you should
just wait ...
Old December 29th 19, 11:03 PM posted to rec.aviation.soaring
Original fender used by Spindelberger:
https://www.hood.de/i/al-ko-plus-kot...m-84664337.htm
The manufacturer is 'Alko'
And the name of the part is 'Kotflügel plus'
A normal club star cobra has black fenders, a better equipped has blue or red ones.
I hope I could help you.
Lukas (LS6a)
Old January 1st 20, 06:45 PM posted to rec.aviation.soaring
Sorry about contributing to the thread drift but this exchange about the tires themselves is interesting and useful...
When I changed the tires on my Cobra trailer about 6 years ago (yeah, I'm due) I purchased trailer tires that were already mounted on wheels. When putting the tires onto the trailer the tires ended up sticking out a few inches from the fenders. That's when I noticed that the original Cobra wheel had a positive mounting offset while the new wheels had a zero offset. I decided to mount the new tires onto the old wheels. I've not had any problems so far but wondering about the criticality of the wheel mounting offset especially as I go shopping for new tires for the upcoming season.
From the etrailer.com website:
Trailer or automotive wheels can have a positive or negative offset. The offset refers to the distance between the mounting surface of the wheel that touches the hub and the center line of the wheel...
A positive offset will move the tire closer to the trailer, while a negative offset will push the tire further away.
Most of the trailer wheels we offer, including the Americana Aluminum Mod wheel you referenced, part # AM22327, have a zero offset, which means that the the mounting surface is on the same plane as the center line of the wheel. This is done to equalize the weight of the trailer load.
https://www.etrailer.com/question-44405.html
Danny Brotto
Old January 1st 20, 10:35 PM posted to rec.aviation.soaring
Danny,
You should be fine sticking with the same tire you have if that's worked. If you change, just make sure the overall diameter is about the same (that figure is available for most tires). I'm actually running slightly larger diameter tires intentionally to get more ground clearance at the rear of the trailer.
I'm still shopping for replacement wheels for my older Cobra. It's a 13 x 4 1/2 wheel with a 29 mm positive offset. The bolt circle is 4 holes on 100 mm and the centerbore is 57 mm. Mine are stamped K13S133 and FAD | 4 1/2 JX13H2, which seems to indicate this was a common wheel years ago (the original Komet trailers had wheels that fit the old Open Kadett imported from Germany).
I believe later Cobras went to a 14" wheel, which seems easier to find. I'd be fine with moving up; I'd just use a lower profile tire with about the same diameter as what I have now.
What's proven difficult is that the published wheel specs don't always include values for all of the above measurements. A wider rim would be OK (there's enough clearance between the tire and sidewall now) but as you found out, a significant change in the offset would not. Nor would different bolt circles or centerbores, although there are adaptors out there to shrink a larger centerbore to a smaller size.
I'd rather stay with a cheaper steel wheel since I have to buy three of them and since I've damaged two already in blowouts (the second one running a TPMS that didn't warn me properly--when the tire blew catastrophically and the sending unit got knocked off by flapping tread, the readout continued to provide the PSI/temp that was last reported.)
I suppose one solution is to go with a zero offset wheel if that's common and just get wider fenders. I intend to replace mine anyway.
Chip Bearden
JB
Removing oxidation from Cobra trailer trim rubber and plastic fenders Dave Nadler Soaring 11 September 25th 17 05:57 PM
FS Cobra Fenders Red NG Soaring 0 February 22nd 14 09:09 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 09:51 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
