On Saturday, December 7, 2019 at 5:12:08 PM UTC-6, soaringjac wrote:
Any recommendations on what to use to fill small holes in an aluminum panel? My preferred method is to make a new panel. at least as long as the original was flat plate aluminum. The classic gliders I can afford (SHK, Std Cirrus, Phoebus, Grob 103) all have had aluminum plate panels, usually pretty ragged from multiple instrument changes over the years and making a new one only takes 3 or 4 hours and I can put the instruments where I want. Of course a band saw and drill press make this possible in my case. Good Luck, Scott |
How to determine if your ASG29 has the large or small panel? | Sean Fidler | Soaring | 37 | November 19th 14 06:50 PM |
Trying to fill some holes in the instrument panel | [email protected] | Soaring | 2 | February 12th 14 02:55 AM |
Cutting 57mm holes in the instrument panel.....how to? | John Bojack[_2_] | Soaring | 20 | November 12th 10 09:15 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
