Affordable Oxygen
Old January 23rd 20, 01:15 PM posted to rec.aviation.soaring
Default Affordable Oxygen
...calibrated to deliver 15 -20 psig of dynamic pressure"
Any pressure regulator supplying a constant pressure...
There is definitely a potential surge problem there.
The EDS regulator is special in being designed to switch from no flow to lots and back while keeping the output pressure reasonable.
If you wish to gamble with yourself, then perhaps a surge tank after the regulator to improve the odds. A pulse-ox to keep an eye on the contraption might also be a good idea. But the words 'good idea' might not fit the situation?
Old January 23rd 20, 07:03 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
John
If you need O2 you need it to be reliable.
I personally would only use a MH regulator with a MH EDS.
I would also send that unit and regulator back to MH and have it checked out, they recommend doing that every so often.
When you go over 12-14k up to 18k you've got other things to worry about than a cobbled together O2 system.
Easy and affordable IGC logger Senna Van den Bosch Soaring 26 May 1st 18 09:05 AM
Looking for an affordable glider.... xTrainwrecKx Soaring 4 August 17th 11 12:03 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 1 August 9th 11 05:07 PM
Affordable Glider K Smith Soaring 20 July 23rd 09 07:13 AM
Affordable planes Tom Home Built 4 November 6th 08 08:59 PM
