Help with LX7000 pro IGC
Old January 24th 20, 02:09 PM
Martin DG100 Martin DG100 is offline
Junior Member
First recorded activity by AviationBanter: Jan 2020
Quote:
Originally Posted by Paul Remde View Post
Hi Dan,
The error message below means that you haven’t installed the database that is tied to LXe. The latest one is from 2009 – unfortunately. You run the install program from the link below after installing LXe.
http://static1.squarespace.com/stati...77/usa_L09.exe
Once you get LXe running it is possible to use their LXAsBrowser to create new airspace files. It is not easy, but I have created many of them for customers. You use LXe to transfer the airspace file to the LX7000.
Unfortunately, .cub file created for and with SeeYou can’t be used in the LX7000. Only LXAsBrowser can create the files. It is available he
http://www.lxnavigation.com/software/
Give me a call sometime and we can setup a support session. I can help you get it working.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Dan, 5J
Hello Paul,
I am faced with the problem that I am unable to generate airspace files for my LX7000. The basis is airspace data in open air format. Unfortunately it is not possible for me to open the data in the LXasbrowser. Do you have a hint for me, what I have to consider to open the data in the LXasbrowser?
Best Regards,
Martin
LX7000 igc-Pro altitude reading Heinz Soaring 3 May 1st 11 11:58 PM
Wanted: LX7000, LX7007 or LX8000 Erich Soaring 1 September 21st 09 05:42 PM
Wanted LX7000 or LX7007 Erich Soaring 1 December 24th 08 01:58 PM
LX7000 with 302 experience Tuno Soaring 0 March 12th 07 04:52 PM
SeeYou to LX7000 Waypoint Task Files Ken Kochanski (KK) Soaring 1 May 28th 05 01:22 AM
