Future of aviation, or flash in the pan??
Old February 1st 20, 01:25 PM posted to rec.aviation.soaring
Default Future of aviation, or flash in the pan??
On Friday, January 31, 2020 at 7:27:53 PM UTC-5, Eric Greenwell wrote:
Dave Nadler wrote on 1/31/2020 12:15 PM:
On Tuesday, January 28, 2020 at 9:59:56 AM UTC-5, wrote:
How hard could it be?
Here's an update from another skilled practitioner:
http://www.streifly.de/news-e.htm
Any idea what the "electromagnetic disturbances" are disturbing?
Some controllers use Hall sensors for position sensing and phase control.
Others sense back EMF generated by the motor to do the controlling. If those signals aren't "clean", not so good stuff happens.
That is the "simple" explanation.
UH
Old February 1st 20, 03:23 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
control.
UH
Indeed, two problems: the above and what seems to have been an
overheating problem with the original controller.
A later post explains that they are switching to a better, heavier duty
controller, but it is physically bigger and/or needs a different mounting
system, so they have to redesign the system almost from scratch to fit
everything into the fuselage. Watch this space...
Martin | martin at
Gregorie | gregorie dot org
Old February 1st 20, 04:25 PM posted to rec.aviation.soaring
control.
UH
Martin | martin at
I have gone through the same thing, abandoning one controller for another and then doing all the integration again.
You can't buy experience, but you DO pay for it.
UH
Old February 1st 20, 04:43 PM posted to rec.aviation.soaring
kinsell
control.
UH
Martin | martin at
UH
The folks on the Islander conversion project say they're doing
everything with off-the-shelf components. Can't you just run down to
Grainger and pick up something suitable? Heck there may still be one in
an attic in Connecticut you could use.
Aviation Future garcia95127 General Aviation 2 January 31st 11 08:30 AM
Future in Aviation for my Son? Jay Honeck Piloting 77 October 18th 07 06:10 PM
Aviation Radio on Compact Flash Card? Will Piloting 1 August 27th 05 11:05 PM
