Electronic TE compensation, will this work?
Old February 13th 20, 02:27 AM posted to rec.aviation.soaring
Darryl Ramm
Default Electronic TE compensation, will this work?
On Wednesday, February 12, 2020 at 5:23:35 PM UTC-8, Dave Nadler wrote:
On Wednesday, February 12, 2020 at 4:07:53 PM UTC-5, soaringjac wrote:
https://photos.app.goo.gl/wu5LUibL2KpF9eWZ6
I have no idea what im looking at...
Clearly a Dr. Who rerun.
Attack of the o-ring men?
The Three o-rings?
It's likely an o-ring. But so what. Looking in the hole may not tell you much, well not from a single photo.
Again, take this to an experienced glider A&P and get help. Especially because you are working on a type certificated aircraft and I am guessing you are not qualified to. A competent glider A&P will be able to determine exactly what is going on, what's leaking or cross leaking and then spend time trying to find out where. They should be very experienced at trying to work out if it's a faulty o-ring or probe or mount connection, or whatever and have the right tools to pick out and replace o-rings. maybe correct o-rings on hand, able to cut out and replace the probe mount if that is needed, etc. etc. etc.
You fix problems by fixing them, ideas of leaving TE lines faulty and trying to use them as static are a waste of your time. "running out of time" is the entirely wrong attitude here.
Lx9070 V80 and Butterfly electronic and pnuemantic compensation Jonathan St. Cloud Soaring 2 May 5th 16 06:47 PM
Electronic versus Pneumatic compensation (conclusions) [email protected] Soaring 0 September 26th 05 05:02 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 4 September 20th 05 06:21 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 2 September 20th 05 06:04 AM
Electronic versus Pneumatic compensation in LX7000 [email protected] Soaring 8 September 15th 05 02:49 AM
