Battery switching without tears
Old April 15th 20, 05:12 PM posted to rec.aviation.soaring
NM
Default Battery switching without tears
On Tuesday, April 14, 2020 at 9:28:12 PM UTC-4, 2G wrote:
On Tuesday, April 14, 2020 at 6:38:00 AM UTC-7, wrote:
On Tuesday, April 14, 2020 at 9:31:13 AM UTC-4, wrote:
On Tuesday, April 14, 2020 at 1:25:55 AM UTC-4, Andy Blackburn wrote:
I used Shottky diodes plus power resistors plus capacitors. I'm no EE but I took enough circuits courses to handle this problem. The Shottky diodes keep the batteries from cross-discharging each other, the capacitors keep the instruments powered when the switch is disconnected from battery 1 and before it is connected to battery 2 and the resistors keep the capacitors from drawing too much current when you power them up since they make the circuit (even with the diodes) look like a direct short initially.
Andy
KISS. Just the two diodes (and no switch) should be enough. Whichever battery is stronger (higher voltage) would take the load. Automatically.. No switching needed. With the higher voltage of LiFePO4 batteries (relative to lead-acid) the voltage drop in the diode is acceptable, especially if it's the Schottky type.
Or, if you really want to remove the voltage drop in the diodes, add an SPDT switch (perhaps one with also a center-off position) IN PARALLEL to the diodes. No matter which position that switch is in, both batteries will still be connected. But the battery the switch leads to will feed the avionics with no voltage drop since the switch bypasses the diode on that side. The other diode will meanwhile prevent current from going INTO the other battery. The middle-off position (or no switch at all) is the safest though, since if either battery develops a shorted cell (or shorted or loose wiring, blown battery fuse, etc) without your knowledge, it won't affect the other battery and the avionics, thanks to the two diodes.
- Clarification: I meant a diode between each battery and the avionics bus as a whole. Not separately for a specific instrument.
I measured the inrush current once again and found that the vertical of the scope was set for a 1X probe instead of the 10X actually being used. This meant that the peak current was 90A instead of 9A, which is a bit high. I added a 1.1 ohm resistor and the peak current dropped to 6A. A simulation shows that a 2 ohm resistor drops it to 3A. This is a good value to use if you have a 1A current drain as the voltage drop will be 2V. The wattage of resistor is unimportant because so little energy is being dissipated by the resistor. The energy transferred remains constant regardless of the resistor value as it is the energy required to charge the capacitor (the current pulse lengthens for larger resistor values).
Tom
Tom,good plan to increase the value of the resistor to limit the current inrush. One could even make the resistor 100 ohms and have a reversed diode in parallel with it so that when the capacitor is needed to sustain the instrument during switching, the current would flow in the reverse direction through the diode, bypassing the resistor. You now have the best of both worlds - slow charge of the capacitor when the power is turned on, and a fast discharge to support the instrument without IR drop across the resistor, instead the drop would just be the bias voltage of the diode.
Old April 15th 20, 06:25 PM posted to rec.aviation.soaring
I've seen a lot of recommendations to keep both batteries connected and not bother with switching. One reason I don't want to do that is that I have a couple of slim 2.3 Ah SLA batteries in the tail of my ASW 24 as a backup (yes, they fit--barely) and the usual LiFePO4 battery up front for the primary source. Ignoring the issues of batteries with different capacities and chemistries running in parallel, pulling out the tail battery pack every night and charging it is just another chore. At a contest, I never do unless I've had to go to it (only a few times in many decades). I'm lazy.
Chip Bearden
JB
Old April 15th 20, 07:58 PM posted to rec.aviation.soaring
Chip how much loss do you experience getting that juice from the tail all the way up to your panel?
Old April 15th 20, 09:00 PM posted to rec.aviation.soaring
Chip Bearden
JB
Chip, your situation sure does call for a switch. Or two switches. Or two diodes. But certainly not simply in parallel. Note that with two diodes the "switching" would be automatic: as long as your LiFePO4 battery up front is not almost completely discharged, there would be no draw on the tail batteries since the diode between them and the "bus" would have a voltage on it in the "wrong" (non-conducting) direction.
Old April 16th 20, 12:08 AM posted to rec.aviation.soaring
Dan Marotta
Chip,
I solved that problem in my LAK-17a by tapping a charging pigtail into
the wire from the tail battery.Â* The charging connector (power pole) was
in the baggage compartment.Â* It was simple to charge it without removing
it.Â* It was a pain to access the wires to do that, but I only had to do
it once.
Chip Bearden
JB
Dan, 5J
Old April 16th 20, 12:05 AM posted to rec.aviation.soaring
Dan Marotta
This whole discussion is a living example of the old saw:Â* Better is the
enemy of good enough.Â* I flew for years with two batteries, two fuses,
and two switches.Â* When battery 1 gets low, flip on battery 2 then flip
off battery 1.Â* Never had an issue.
Andy
KISS. Just the two diodes (and no switch) should be enough. Whichever battery is stronger (higher voltage) would take the load. Automatically. No switching needed. With the higher voltage of LiFePO4 batteries (relative to lead-acid) the voltage drop in the diode is acceptable, especially if it's the Schottky type.
Tom
Dan, 5J
Old April 16th 20, 05:48 AM posted to rec.aviation.soaring
krasw
Less components means less problems with bad components, less solder joints that eventually break with vibration, all of this is better than good. I run same setup, on-off switch for both batteries, usually only one of them online, except when getting my engine (turbo) out in case battery runs out of juice right then. Zero problems ever. Glider came out of factory with both batteries wired parallel btw.
Old April 16th 20, 07:38 AM posted to rec.aviation.soaring
2G
Andy
I measured the inrush current once again and found that the vertical of the scope was set for a 1X probe instead of the 10X actually being used. This meant that the peak current was 90A instead of 9A, which is a bit high.. I added a 1.1 ohm resistor and the peak current dropped to 6A. A simulation shows that a 2 ohm resistor drops it to 3A. This is a good value to use if you have a 1A current drain as the voltage drop will be 2V. The wattage of resistor is unimportant because so little energy is being dissipated by the resistor. The energy transferred remains constant regardless of the resistor value as it is the energy required to charge the capacitor (the current pulse lengthens for larger resistor values).
Tom
Dan, 5J
Yeah, until you get the sequence backwards.
Old April 16th 20, 07:36 AM posted to rec.aviation.soaring
2G
Andy
Tom
I don't really think that the resistor is necessary, but offer it to those that are overly concerned about the inrush current. The bottom line is the energy that is transferred from the battery to the capacitor heating the switch contacts. Switches have current ratings to limit the temperature rise to tolerable levels when the current is flowing continuously; this short current pulse will not raise the switch contact temperatures to any significant level. Remember, the SAME amount of energy will be transferred between the battery and the capacitor REGARDLESS of the resistor value (joules = C * V). This translates to the SAME amount of switch contact heating. If you make the resistor insanely large so the time constant is on the order of minutes, the heat will dissipate and lower the maximum temperature. A better approach is to use a smaller capacitor that still maintains voltage during switching.
Tom
Old April 16th 20, 05:29 PM posted to rec.aviation.soaring
jfitch
Andy
Tom
Tom
The concern isn't heating in the switch contacts due to their specified resistance. It is high current arcing during switching. This can cause erosion of the contacts, in more extreme cases welding them together. A 12V battery is quite capable of generating a vey high energy arc, one can be used to arc weld steel. Arcs are peculiar phenomena with negative resistance, not easy to measure their presence or characteristics. All DC switched arc on make, the current of the arc is limited by the impedance of the circuit - in this case very low.
There is little mortal danger, the switch isn't going to catch fire or explode. It probably will have a markedly shorter life. In the worst case it may weld itself on one day. The capacitor may be the easiest solution, but not the most elegant, and it may not be without tears. The best solution is to parallel the batteries always so that routine switching is unnecessary. This has higher reliability, will result in longer battery life, and requires no operator action. If circumstances make that impossible then as suggested above a select switch shunted with diodes, followed by an on-off switch is safe, zero energy loss, and keeps all components in spec.
Airplane tears off winglet on jet bridge a[_3_] Piloting 0 July 8th 10 08:06 PM
Tears in the eyes, - 1 attachment RobG Aviation Photos 4 June 17th 08 10:51 AM
The Tears Of Finding The Truth algaga Piloting 9 January 3rd 08 04:33 PM
“Particularly on May 19th”— with the tears of his father X98 Military Aviation 0 May 18th 04 10:34 AM
