Wing wheel from Craggy Aero
Old May 3rd 20, 04:48 PM posted to rec.aviation.soaring
jfitch
Default Wing wheel from Craggy Aero
On Sunday, May 3, 2020 at 6:17:40 AM UTC-7, wrote:
Scrubbing is what happens when you turn a tire on a radius.
If the wing wheel is biased forward, so that it is inline with the main gear axle, there will be no scrubbing as the geometry is correct for any radius turn.
Ignoring who said and did what, I just learned a useful geometry lesson.
Assuming 'scrubbing' is when the rubber on a tire rubs instead of rolls over the pavement.
Another symptom is 'hopping' where the wheel tracks wrong and rolls out of position flexing the mount. Eventually, there is enough force from the flex to make the wheel hop back into position. Definitely some 'scrubbing' involved as well. Definitely a worrying situation because the flex is putting weird loads on the flying parts.
If the wing wheel is vertical and in line with the line of travel, why would there be scrubbing when you are going straight?
If in addition, the axle of the wing wheel points to a line directly above the main wheel, why would there be scrubbing when the glider makes a turn?
Maybe in the limit, neither one of these can be aligned perfectly, but if you put the wing wheel in the right place it ought to work pretty good.
That explains why my old wing wheel still hopped on curves even after I adjusted it so it points straight ahead. Also why the new MM one doesn't.
Guess a swivel might be another out of the hole, but not the only way.
To be correct geometry for a specific radius turn, the wing axle must point towards center of the turn radius. The axle lines of the main and wing wheel intersect at this center. If the main wheel is the center, then the wing axle must point towards it. A swiveling wheel will align itself to this geometry. For a non swiveling wheel to be correct geometry for *any* radius, the axles have to be in line (more specifically their projection to the ground plane has to be on a line), guaranteeing that both axle lines intersect at the circle center regardless of radius. The wing wheel will then not scrub, even if it is the center of the turn. It will turn about its vertical axis, just as the main gear (or indeed the swiveling wheel) must, in other circumstances. That is not "scrubbing" as the term is usually applied.
And now, back to the popcorn....
Old May 3rd 20, 12:14 AM posted to rec.aviation.soaring
Andrzej Kobus
On Friday, May 1, 2020 at 12:08:20 PM UTC-4, 2G wrote:
On Friday, May 1, 2020 at 4:09:16 AM UTC-7, Andrzej Kobus wrote:
On Friday, May 1, 2020 at 1:31:09 AM UTC-4, 2G wrote:
On Thursday, April 30, 2020 at 7:20:25 PM UTC-7, Andrzej Kobus wrote:
On Thursday, April 30, 2020 at 7:38:39 PM UTC-4, 2G wrote:
I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel:
http://www.craggyaero.com/ground_handling.htm
And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it.
Tom
The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons.
That wheel does not swivel, so it will suffer from the same scrubbing problem that the Cobra wheel has.
Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type. This is why it sits on the wing perfectly and it does not move at all. I am a very happy customer!
While the clamping of the Mark's wing wheel is better than Cobra's, scrubbing is inevitable because of the geometry of towing. I actually tried to buy Mark's wing wheel and even mailed him a check after he complained about others cancelling orders, but he still didn't want to make it. The CA wing wheel works better, is adjustable, has a shock absorber, is well made and is cheaper. And it was in stock.
Tom
No offense Tom, but you are coming across as you know best. I have been using his wing wheel for four season on the 31 Mi with excellent results without any "scrubbing" as you put it.
Old May 3rd 20, 02:04 AM posted to rec.aviation.soaring
2G
Tom
Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type. This is why it sits on the wing perfectly and it does not move at all.. I am a very happy customer!
Tom
Andrzej,
That's because I do my research and I gave my fair evaluation, nothing more.. Mark is basically calling me a liar. I could publish the proof that he is blowing smoke, but why bother - he isn't going to change. The scrubbing DOES occur, you are not witnessing it because you may be too far away in your tow vehicle. Anytime you force a tire to go in a different direction to which it is aligned (i.e. a turn) the tire WILL scrub as it realigns to the new direction. just google "tire scrubbing" to learn more than you will ever want to know. There is nothing inherently wrong with Mark's wing wheel. Hell, I tried to buy one buy Mark proved to be more difficult to work with than most.
Tom
Old May 3rd 20, 02:49 AM posted to rec.aviation.soaring
OK. Enough is enough. Tom, you ARE a liar. Below is the entire email string between us. You indicated the delivery time was unacceptable for the wing wheel, but you would send a check for the tow bar. I have no record in my bank statements from 2019 that indicate a payment from you, nor is there any evidence that I received one or refunded your money.
What this shows is that you NEVER paid for a wing wheel, and probably not the tow bar either. You are a bombastic, pontificating asshole, an opinion shared by several other pilots who know you and have responded to me privately.
If I ever decide to resume production of wing wheels and tow bars, rest assured that your requests will be denied.
Hi Mark,
I would like to order:
Tow out bar
Pair of wing cuffs
Wing wheel
These are for a ASH31Mi.
Need pricing for the lot plus shipping.
Thanks,
Tom
Sent: Tuesday, February 26, 2019 12:29 PM
To: Mark M
Subject: Tow out dolly
Hi Mark,
The delivery is ok for the tow-out bar, but not for the wing wheel. I will send you a check for $275. What is the price for a wing cuff?
Tom
Sent: Tuesday, February 26, 2019 6:46 AM
To: Tom S---
Tom-
Price on the tow bar is $200. The optional tail lifter is $50. An ASH-31 wing wheel is $700. Shipping on both is $75.
I am out of stock on the tow bars, and wing wheels are each custom fabricated. Delivery is generally 4-6 weeks after receipt of payment, but I am involved in a really big project right now, so my time is limited. It might take a bit longer unless I can squeeze them in.
Best regards,
Mark M
On 2/25/2019 1:06 PM, Tom S--- wrote:
Hi Mark,
I just called you about a tow-out dolly for an ASH-31Mi. I also need a wing wheel. Please respond with price and delivery costs for both. My address is:
Tom S---
Thanks.
(Email and physical addresses deleted. Last names also deleted, but you can read between the lines.)
Your interpretation of "scrubbing" is based on your experience with the Cobra wing wheel, probably the flimsiest, mass produced, doesn't-fit-anything piece of junk I have seen. It can't be properly aligned with the direction of travel because it doesn't clamp to the wing securely and it flexes so much that the alignment changes when it is in motion. The cheap-ass foam rubber padding slips, dries out and then crumbles into dust.
When I bought my first glider in 2000, I used one a couple of times and immediately started work on a design that evolved into a product that had over 300 buyers, many of them repeat customers. Is it the best? Maybe not, but it evidently satisfied the needs of the customers. I am very glad that you were not one of them.
(And it's not physics, it's simple geometry.)
Old May 3rd 20, 07:19 AM posted to rec.aviation.soaring
2G
Hi Mark,
Tow out bar
Pair of wing cuffs
Wing wheel
Thanks,
Tom
To: Mark M
Hi Mark,
Tom
To: Tom S---
Tom-
Best regards,
Mark M
Hi Mark,
Tom S---
Thanks.
Mark,
OF COURSE you don't have a record in you bank statements, I told you to SHRED the check that I sent you after you told me you had NO IDEA how long delivery would be, if ever. Presumably you did that because the check was never cashed. A week after I told you that you called me back and told you had a break in your schedule and could do the job, but I was DONE with you by that time. Your memory of this is appalling, but mine is perfectly clear - you just don't fantasize sending a $1,200 check to someone. Here is the purchase order I enclosed WITH the check dated 3/6/19:
PURCHASE ORDER
To: MM Fabrication
PO Box 1623
Moriarty, NM 87053
Mark,
Per your previous quotes by email and telecon I am placing an order for the following items:
1 Single-place tow out bar $200
1 ASH31Mi wing wheel $700
2 ASH31Mi wing cuffs $250
1 Shipping $75
Total $1,225
Enclosed is a check for the total amount. Please contact me if the shipping costs exceed $75 and I will pay the difference. I will forward a tracing of the inner panel cross section as soon as available.
The shipping address is:
xxxx
xxxx
xxxx
xxxx
Thanks,
Tom
Scrubbing is a fact of life because of the geometries involved. The forces exerted on the wing wheel are the same, but the Cobra deals with it far worse than your wing wheel.
Old May 3rd 20, 08:34 AM posted to rec.aviation.soaring
krasw
All wing wheels scuff when glider turns if the wheel axel cannot turn. If the wheel fits wing very well this not a problem and you really notice it only when turning the glider while it's stationary.
Cobra, Schempp and many other older "unisex" wheels don't fit anything. Using them is based on trial and error, you learn to fit it to correct direction and then it sort of works, maybe 60% of the time.
SoarinXX wheel is huge improvement in design. I just wished the would have used real bearing on svivel joint instead of that flimsy plastic bearing. That has to carry wing full of water on uneven ground.
Craggy Aero Navigation unit 4 sale [email protected] Soaring 0 March 21st 14 08:18 AM
Brand New Craggy Aero Ultimate LE for sale [email protected] Soaring 0 December 27th 13 11:12 AM
Big thanks to Richard at Craggy Aero Bruce Barnard[_2_] Soaring 4 February 15th 12 03:55 PM
Craggy Aero Ultimate & SeeYou Mobile Richard[_1_] Soaring 2 October 29th 08 06:45 PM
Craggy Aero Introduces the Ultimate Flight System Richard[_1_] Soaring 18 August 14th 08 04:56 AM
