Guidelines or formulas for how much water to dump in narrow or weakthermal racing?
Old May 16th 20, 03:13 AM posted to rec.aviation.soaring
Tango Eight
Default Guidelines or formulas for how much water to dump in narrow orweak thermal racing?
On Friday, May 15, 2020 at 9:26:29 PM UTC-4, Charles Ethridge wrote:
...and so it begins :-)
The important bit, of course, is to learn how to make the glider go, without water.
T8
Old May 16th 20, 03:39 PM posted to rec.aviation.soaring
Roy B.
Ben:
The best advice I ever got on the subject was, "If you are thinking about dumping the water, DUMP IT!" And that has remained pretty good advice.
The question you have to ask yourself is "why am I thinking about dumping water?" Is it because the last few thermals were weaker? (Dump it). Or, "I am perilously low and I need to float to a save?" (Dump it) Or, "The guys without water are seriously out climbing me and running away" (you guessed it - start dumping).
I think the only time to hold on to the water (when doubts emerge about its helpfulness) is when you are reasonably certain that you will get back to better conditions. This may be because you have started early in the morning before it cooks up or when you have drifted down to the weak area of the height band and can climb back up to the strong lift. But it's not a science - it's an educated guess about the future.
ROY
Old May 16th 20, 05:09 PM posted to rec.aviation.soaring
Charles Ethridge
I understand...BUT...the leading pilots in Condor simulator racing are all, as best I can tell, holding onto their water as long as possible, i.e. they aren't leaning toward the conservative side. This is probably because it is virtual racing, and no one is going to break a real glider (or their real bodies) if they make a water mistake. If I dump water and they don't, they invariably beat me in the cruise segments and especially in final glide..
That's why I was looking for rules of thumb and formulas when racing, as opposed to cross-country.
Ben
Old May 16th 20, 11:45 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Ben
While Condor is an Excellent tool, many people, fly different on Condor than they would or could in real life!
Old May 18th 20, 01:31 PM posted to rec.aviation.soaring
Andreas Maurer[_2_]
Default Guidelines or formulas for how much water to dump in narrow or weak thermal racing?
On Sat, 16 May 2020 09:09:22 -0700 (PDT), Charles Ethridge
Ben
Condor is great, but its thermal model isn't correct at low altitudes
(thermals don't get a lot weaker or tighter close to the ground),
therefore there's hardly any penalty if you get very low.
I once got a 6 kts thermal after (!) an outlanding when I bounced back
into the air... and completed my 150 miles task.
Cheers
Andreas
Old May 17th 20, 02:43 AM posted to rec.aviation.soaring
Dave Nadler
On Friday, May 15, 2020 at 1:18:47 PM UTC-4, Charles Ethridge wrote:
Hi, all.
When racing a typical 1-2 hour flatland race in, say, a Diana2 or Ventus3-15 (15 meter ships with water ballast and flaps), are there any guidelines or formulas for how much water to dump, particularly when thermals are weak or narrow?
Here are the parameters I'm thinking would apply (but I'm no expert yet- thus the question):
1. Average thermal strength
2. Average thermal width
3. Average distance between good thermals
4. Height band for the day
I was hoping to find something on this subject in a glider racing book or the Diana2 flight manual, but no luck so far finding either googling.
Ben Ethridge
If your chronic leecher is underneath you, dump.
Old May 17th 20, 04:07 AM posted to rec.aviation.soaring
As long as you are happy with your climb rate then keep the water. The advantage in the cruise of flying heavy requires no skill or effort but achieving the advantage of lower wing loading in the climb does and it is easy to throw it away through lack of technique or lapse of concentration. As soon as you are unhappy with your climb rate, and don't expect better conditions ahead, then dump it bit by bit until you are. The happiness factor includes things other than theory or algorithm such as comparison with other gliders (if any), conditions ahead, current altitude, terrain below, pilot risk aversion level etc. Stuff that may not seem so important in simulation as in real life.
Old May 17th 20, 02:25 PM posted to rec.aviation.soaring
It build character to climb heavy and then decide to dump just as you head out in cruse ;-)
Old May 17th 20, 04:10 PM posted to rec.aviation.soaring
Jax
Here is a paper about flying with water, it is for lower performance gliders but the concepts remain the same.
https://keepitsoaring.com/wp-content...er_ballast.pdf
Other interesting articles by the same author
https://keepitsoaring.com/the-speight-papers/
Old May 18th 20, 03:58 PM posted to rec.aviation.soaring
Charles Ethridge
Wow! Excellent article! Adds a lot of "why" to the "what". I need to re-read it a few times to fully absorb. I will read his other articles you link as well.
Thanks!
Discus CS wing water dump seats (seals) [email protected] Soaring 5 August 6th 19 01:54 PM
SZD 55 water dump valve sticking. Mark B[_2_] Soaring 0 February 1st 19 10:15 PM
ASG-29 water dump rates Jonathan St. Cloud Soaring 9 June 10th 16 04:37 PM
Chapstick In Water Dump Valves Dan Marotta Soaring 4 June 21st 12 01:16 AM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
