The aerodynamics of a towplane in a kiting glider situation
Old May 21st 20, 03:27 PM posted to rec.aviation.soaring
Hightime
Default The aerodynamics of a towplane in a kiting glider situation
On Sunday, May 17, 2020 at 4:48:22 PM UTC-6, Tom BravoMike wrote:
I know there is a thread going on about and around the latest tragic accident from 5-9-2020 and I preferred to start a new thread as I felt uncomfortable going into a dry technical discussion in the context. So the issue is:
I would like to know more about the aerodynamics of the towplane in all those accident situations (and I mean above certain altitude minimum): Statistically, do they crash being stalled or in a deep dive? What is the usual reaction to the tail being pulled up - does the towpilot try to overrule the pulling glider and he gets into a stall? He cannot dive until the rope breaks. Recovering from a stall he has to get out of a dive anyway. So it seems that pushing down into a dive instead of trying to pull up would result in a smaller loss of altitude (and cause the rope to break earlier), rather than in the sequence: struggle to overrule the pulling glider - stalling (loss of height) - pulling out of a dive (loss of height).
Just thinking loud, curious if any research has been done and if so, to what conclusions? Does anybody know?
Dont forget people Towing is not that dangerous and there are plenty of Happy towpilots out there and not just happy helicopter pilots
Old May 21st 20, 03:47 PM posted to rec.aviation.soaring
Folks
If anyone thinks getting an STC is easy or even moderately difficult you are badly mistaken. Having gone thru the attempt on two separate occasions, I can tell you unless an STC has been approved year’s previously addressing a similar application, your chances of getting an approval are next to nil! The dirty little secret is, the FAA is not interested in helping the process. In fact, they do not want to involve themselves at all. Maybe if you have a very friendly fsdo, you could possibly get a one time field approval but those are even very difficult to obtain nowadays.
Is the schweizer hook an issue? Possibly but Karl Streideck addressed the modifications suggested in a very succinct post earlier. Or switch to a tost hook and move on. We’ve been towing for decades now and once again it comes down to proper airmanship. Get the idiots be they experienced or not OUT of the cockpit or beat some sense into them. As a tow pilot, insist on a release that is easy and immediately at hand, be ready to pop it the very MOMENT someone starts a kiting action. Absolute diligence is required from both glider guy and tow pilot the first 1,000 ft of a tow.
Dan
Old May 21st 20, 06:55 PM posted to rec.aviation.soaring
Tom BravoMike
On Thursday, May 21, 2020 at 9:47:42 AM UTC-5, wrote:
Folks
Dan
It almost sounds like we are orphans here in the US, no SSA, no AOPA, no EAA - of which many of us are members and pay the dues. Is there any support and lobbying on part of those organizations when dealing with the FAA? Don't the other countries' national gliding organizations take care of talking to their aviation administrations in similar cases? BGA, DAeC, FFVP ...
Old May 21st 20, 04:05 PM posted to rec.aviation.soaring
The loss in airspeed during a kiting incident must be significant. Chris Rollings notes that a 'marked deceleration' was observed by the towpilot in his report from kiting tests in 1978 and 1982, but focusses on the pitch down. I've had two kiting incidents as an aerotow pilot, both above 2000agl, when the glider didn't release as desired. In both cases it felt like a mild aerobatic maneuver, not alarming to me due to the safe altitude, and my attention was so focussed on the pitch-down that I didn't notice any airspeed decrease, although it probably occurred. In those experiences, the kiting did not seem at all dangerous to me, at altitude, and might even be a good thing for all aerotow pilots to experience, at altitude and intentionally, as part of training. It would be best if the towpilot was comfortable with mild aerobatics before trying it however. Chris Rollings did not mention any danger in his kiting tests. Such intentional kiting might build up a better body of knowledge, and would increase the awareness of tow and glider pilots to the danger.
Reducing the towrope breaking tension seems desirable. I don't know the reason for the FAA 80% rule, maybe that should be reduced. Most glider manufacturers only specify a maximum breaking tension.
Another interesting consideration is the time taken for rope tension to rise to breaking tension. The tension in the rope will probably rise gradually during kiting, probably over a few seconds. The rise in tension is probably non-linear, and at some angle, but its easier to do a calculation if the rope tension is assumed to rise linearly and to act directly backwards. If the rope tension builds up linearly to 1800lbs (a typical rope break strength) and then breaks, a Pawnee with full tanks (say weighing 1800lbs) will decelerate linearly, reaching a maximum deceleration of 32ft/sec2 ie about 20kts per second, at the instant the rope breaks. The longer it takes for the rope tension to build up to breaking, the greater the total Pawnee airspeed loss will be, since the rope forces on the Pawnee will be the same but last for a longer time. Calculation shows the Pawnee total airspeed loss varies as t^2, where t is the time taken for the rope tension to rise to the breaking point. If the rope breaks in 1 sec, the Pawnee in this example would slow by about 10kts by the time the rope breaks. If the rope takes 2 secs to break, the Pawnee airspeed loss would be about 40kts. In a non-kiting rope-break, eg due to a slack line suddenly snatching tight, the time t would be very short, maybe 0.1sec, and the airspeed loss probably unnoticable.
The full analysis should consider both pitchdown and airspeed loss, and perhaps negative g effect on the pilot, and then the height needed to recover. This might be too complicated, and be too dependent on particular towplane types. Maybe intentional practice at altitude might give practical data more quickly.
Old May 21st 20, 09:30 PM posted to rec.aviation.soaring
Hightime, you're kidding right? Towing is not that dangerous? Please tell that to the poor chap who died recently in California. Or to the tow pilot at Front Royal Virginia or any of the tow pilots who have perished due to a mistake on the part of the glider pilot in tow only to then be amplified by the failure of a device meant to save their life. Towing is not "that" dangerous until it become THAT dangerous.
It's not THAT dangerous until someone in back of the tow plane makes a big, stupid mistake. It's not THAT dangerous until a poorly trained student (in my case) or an inattentive, distracted instructor or one of the many squirrels who abound in the soaring community SCREW UP. Then it becomes THAT dangerous and for the record, how do you define "that?"
Plenty of Happy tow pilots? I'm sure there are and they will be happy until the s--t hits the fan and they find themselves a second or two from the end of their life, happy will go out the window. The fact of the matter is we don't know what we don't know and what we don't know can kill us. Every tow has the potential to end in disaster. Towing
Towing is not that dangerous, what a dumb f--king statement to make. Flying helicopters is dangerous too but not THAT dangerous? The difference is that I am responsible for my mistakes.
Walt Connelly
Former Tow Pilot
Now Happy Helicopter Pilot
Old May 21st 20, 11:43 PM posted to rec.aviation.soaring
Hightime
Walt Connelly
Former Tow Pilot
No Its not dangerous, I have been part of a club for many years , we have high standards of training, so no student or pilot ever does this, its trained out of them from a very early on . When I solo them Im confident in their abilities. Sure it can happen by a pudknoker but its not statistically "dangerous" to tow a glider. Its statistically dangerous to fly helicopters , come back to towing you will be much safer
Old May 22nd 20, 01:17 PM posted to rec.aviation.soaring
Walt Connelly
Former Tow Pilot
I remember well my first day sitting in a college statistics class, the Prof said he could make any group of numbers mean anything he wished them to. To say that flying tow is "statistically" not dangerous denies the fact that each tow brings with it the potential for disaster.
Tell the chap who died recently about your "statistics." I'm sure he would feel better or perhaps better still, tell his family. Curious as to how you would word that.
I'm always amused when "instructors" claim how well their students are prepared. As my dad would say, if you do something long enough, bad things will happen. I knew a guy in Vietnam who was shot down on his first mission and another guy who was shot down on his last. You never know when your number is up.
Helicopters have their own "dangerous" characteristics, difference is I'm not dependent on another pilot hooked up to me not making a mistake. If I screw up it's on me. I'm willing to take that chance.
Walt Connelly
Former Tow Pilot
Now Happy Helicopter Pilot.
Old May 22nd 20, 01:53 PM posted to rec.aviation.soaring
Walt, no offense friend, but I would rather take my chances as a tow pilot than fly in choppers lol. Way too many moving parts. Last time I was in one they kicked me out on a zip line (army rotc).
Old May 22nd 20, 06:33 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Walt Connelly
Former Tow Pilot
I would like to see the citation on that statement. I have over two thousand hours in helicopters and felt safer than in my own home. I am a commercial, instrument rated helicopter pilot and the only people I knew that were killed were airplane pilots and glider pilots. Helicopters do have a high incident of incidences, like roll over accidents, but I have never known anyone hurt in a helo crash.
Old May 22nd 20, 09:46 PM posted to rec.aviation.soaring
I have twice experienced LTE in the Guimbal Cabri G2 down low, real low. The folks at the plant will tell you that it will not LTE....WELL, when I find myself with the right pedal all the way to the stop and still rotating I call that LTE. All you can down is turn the throttle all the way off and try to stay level while your rectum sucks the seat up into the distal portion of your alimentary canal. I have gone back and forth with the manufacturer and have discovered things they have not been very open about....shame on them. While I was getting my rating there were no accidents at the helicopter school but the local fixed wing school destroyed two 172's.
Walt Connelly
Former Tow PIlot
KGARS - Kiting Glider Automatic Relase System Wit Wisniewski Soaring 2 May 19th 20 01:04 AM
KGARS - Kiting Glider Automatic Relase System AS Soaring 0 May 15th 20 02:46 PM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
