Scary story about landing on a Lake Tahoe golf course
Old August 3rd 20, 05:02 AM posted to rec.aviation.soaring
Default Scary story about landing on a Lake Tahoe golf course
re https://youtu.be/BBpqvPujZgM
In my opinion, this video shows the difference in training between a power pilot and a glider pilot. A glider pilot in a similar situation (eg being low and not finding lift) would have remained close to one of the excellent large grass fields immediately visible in the video. A glider pilot would not have attempted to continue further without keeping another good field within reach. Once close to a airport, a glider pilot would not have attempted to fly a normal pattern, once a runway could be reached with an early turn in. A glider pilot would not have chosen to extend his downwind, for no obvious purpose, to place a highway between him and the runway. To summarize: a glider pilot would have calmly landed in a large grass field, and would not have made a panicky gear-up landing in a crop field.
Old August 3rd 20, 10:01 AM posted to rec.aviation.soaring
Rakel
With the engine only partly running, how long will it take the P-51 to lower the landing gear? How long to lower the landing gear manually?
Old August 4th 20, 01:39 AM posted to rec.aviation.soaring
Andreas Maurer[_2_]
On Sun, 2 Aug 2020 21:02:36 -0700 (PDT), wrote:
re
Jut out of interest:
How many hours in the P-51D do you have that you are able to transfer
glider tactice to a fighter aircraft?
I have none, but I am extremely sure that you don't simply land a
P-51D on a field with extended gear without damage...
Cheers
Andreas
Old August 4th 20, 07:30 AM posted to rec.aviation.soaring
This discussion is useful, and should not be regarded as a criticism of the pilot. Such discussions remind me of the description of an accident enquiry, as "six people taking six months to decide what the pilot should have done in six seconds".
Old August 4th 20, 02:38 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Sun, 02 Aug 2020 03:39:34 -0700, Paul B wrote:
Great video, there are couple of questions I would ask though.
1) Why did he not turn much tighter to return to the airfield, one
looses much less height in a tight turn that a shallow one? From a tight
turn he might have been able to land downwind. Of course I do not know
what the winds were, or how feasible is to land P-51 downwind.
2) Why did he cross the highway, surely he could have turned base
halfway down the strip and have enough runway to stop.
I thought I'd posted this a day ago, but it evidently didn't make it to
the newsgroup somehow.
I've been to airshows at Duxford, flown gliders past it, flown from there
in a Tiger Moth, and driven past it on the M.11 many times, so I have
some small knowledge of the area. Here's my take:
The formation was joining up on the far side of the motorway when the
P-51s engine had its tizzy. Look at a map or a satpic of the airfield -
the M.11 is almost glued to the east (departure) end of the runway. When
that part of the M.11 was built they chopped 1200ft off the Eastern end
of the runway to keep the road straight.
From the vid it looks as though the formation was joining up a bit North
of the centre line, possibly somewhere near Wittlesford, so when the
engine hiccuped the second time, setting up a left-hand circuit on the
north of the airfield must have looked good. The south side has no
obstacles but (a) it makes the circuit quite a bit longer and (b) it
would have meant crossing the departure end of an active runway.
Turning in early: that would have meant crossing a row of large hangars
and the airshow spectators, which were all along the northern side of the
airfield. In the UK at least, the rules are clear: you DO NOT overfly a
crowd of people below 1000ft AGL under any circumstances - and the P-51
was below that with a dead engine by the time he was past the M.11.
As I said: bring up Duxford Airfield on Google Earth or Google Maps,
compare that with the video shot from the P-51 and draw your own
conclusions.
Martin | martin at
Gregorie | gregorie dot org
Old August 4th 20, 02:54 AM posted to rec.aviation.soaring
2G
conclusions.
Martin | martin at
What does a P51 have to do with soaring? There are other newsgroups that deal with warbirds.
Old August 4th 20, 04:18 AM posted to rec.aviation.soaring
Scott Williams[_2_]
conclusions.
Martin | martin at
O.P. of the P51 video clearly stated this might be useful to Tow Pilots "power loss in a tug" Also, I understand sometimes gliders are equipped with engines, which sometimes fail. I found the video useful as a cautionary tale of procedures and pilot responses to a rapidly deteriorating flight event.
I know that I will not live or fly long enough to learn these lessons on my own.
I'm happy to learn from pilots regardless of what they may have been flying..
Thanks to all the Tow Pilots and their contribution to Soaring.
Respect,
Scott
Lake Elsinore, 1-26 crash landing video David Reitter Soaring 2 July 13th 12 09:33 PM
Short field landing Lake Providence LA (0M8) with ATC COMS - Video A Lieberma[_2_] Owning 0 July 21st 09 12:06 AM
South Lake Tahoe Class D Ray Piloting 2 May 15th 05 03:31 AM
Lake Tahoe Ross Richardson Owning 5 March 28th 05 07:04 PM
DONNER LAKE TAHOE 2005 TRUCKEE,CA PHOTOS DONNER LAKE 2005 Piloting 3 January 16th 05 08:06 AM
