Refinishing ASW24
Old September 9th 20, 02:42 AM posted to rec.aviation.soaring
Default Refinishing ASW24
On Tuesday, September 8, 2020 at 12:12:37 PM UTC-4, wrote:
I recall UH years ago telling me sanding German sailplane gel coat is like trying to smooth out a piece of jagged granite with wet toilet paper.
Never forgot that one. LOL
I heard the same thing from the same person over 40 years ago.....I tend to stick to final sanding and polishing.....
Old September 8th 20, 09:24 PM posted to rec.aviation.soaring
On Monday, September 7, 2020 at 5:40:31 PM UTC-4, wrote:
I have been working on the horizontal stab and the two elevators for the past two weeks. I have never seen such difficult gel coat to remove. I am no rookie at gel coat, have done many boats and a bit of glider repair, but this is a beast to remove. It took me six full days to remove the gel coat from the stab. Just today I did one elevator and will do the other tomorrow..
I am bringing it back up with acrylic urethane, so far so good, just a lot of work and a few drinks of rum. Bob
Scales tell the tell of the removed gelcoat. Before weight of the stab with the elevators removed was 11 pounds 13 .8 oz. after removal of the gel the weight was 10 pounds 12.8 oz or a net loss of 1.lb, are you surprised??
The elevators weighed 1.91 and 1.95 respectfully, left and right. after removal of the gel the weights were 1lb 6.9 oz and 1 lb 7.0 oz. I have completed gel removal on the stab and elevators and are now rebuilding the surfaces. Only used two boxes of band-aids on my fingers and drank two bottles of good Cuban rum.
Old September 9th 20, 02:14 AM posted to rec.aviation.soaring
So, can we assume that the R/B ratio of one bottle of rum to one box of Band-Aids can be used as a measure of performance? Try three bottles of rum and report back with the results. If you end up needing a tourniquet, please let us know.
Old September 9th 20, 02:30 AM posted to rec.aviation.soaring
Mark, the ratio is consistent with the measure of pain! I liken this ordeal to a couple of other projects that I have tackled in the past, I basically said to myself ,"What the hell did I do this for". The tourniquet suggestion is a great idea, not sure that it would stop the flow, but certainly would prolong the suffering.
On to the next step in this ordeal, will be building back up with filler and primer and on to the final coat or two or three of acrylic urethane then sanding down to 3000 grit and buffing, I might need more rum.
Old September 9th 20, 03:05 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
If a low number grit does not easily take off the hard finish use a finer grit until it cuts easily then move to a 80 or 65 grit. An electric grinder with adjustable speed is what I have used. In my opinion an orbital is not needed. Use no pressure on the sander let the paper cut.
http://www.craggyaero.com/ventus.htm
Richard
www.craggyaero.com
Old September 9th 20, 09:44 AM posted to rec.aviation.soaring
Colin Roney
Rum? Can`t stand it. It`s like drinking liquid rubber. Why not try a good
Scottish single malt whisky. Your working progress will benefit.
wro=
te:
wro=
te:
of=
good Cuban rum.
of=
ru=
ple=
ase let us know.
orde=
basical=
sugges=
w=
ould prolong the suffering.=20
filler
the=
g=
grinder=
no=
Richard
www.craggyaero.com
Old September 20th 20, 09:09 PM posted to rec.aviation.soaring
After countless hours of removing gel coat and filling , priming, sanding, sanding, sanding and then painting only to sand down, repaint and sand to 3000, I have finished! The scotch did not budge the gel coat, my fingers need rest, and my spray gun is finally clean again. I spent the last day buffing and doing a bit of sanding and buffing again. Now comes the fun part, putting it back together so my wife can have her ASW24 back.
Old September 20th 20, 09:17 PM posted to rec.aviation.soaring
Dan Marotta
How about posting some pictures, Bob.Â* Of the '24, not you... :-D
Dan
Dan, 5J
Old September 20th 20, 11:20 PM posted to rec.aviation.soaring
On Sunday, September 20, 2020 at 4:18:06 PM UTC-4, Dan Marotta wrote:
How about posting some pictures, Bob. Of the '24, not you... :-D
Dan
Dan, 5J
Dan, let me see what I can do, Eileen is nagging me to death about not being able to fly her 24. Just today she told me that I should re surface the entire glider, I need more rum. Bob
Old September 22nd 20, 04:42 PM posted to rec.aviation.soaring
Colin Roney
I humbly stand corrected! Clearly the `Juice of the Caribbean Gods`is far
superior to a rotten old Scottish Malt Whisky. Sounds like you`ve achieved
the impossible. Well done. I presume the glider is now up for sale.
How about posting some pictures, Bob. Of the '24, not you... :-D=20
=20
Dan
On 9/20/2020 2:09 PM, wrote:=20
wrote:=20
t=
a=
b=
co=
tomor=
row.=20
a=
lot of work and a few drinks of rum. Bob=20
sandi=
sand
fingers=
b=
part=
--=20
Dan, 5J
bein=
e=
ASW24 - electric valve system Norbert Gulczynski Soaring 1 January 25th 15 01:13 PM
1998 ASW24 water bag leak where bag meets PVC valve Barny Soaring 2 April 4th 11 04:57 AM
ASW24 Left aileron needed Barny Soaring 0 October 18th 10 12:09 AM
Looking to Purchase used ASW24 Right Aileron Robert Fidler Soaring 0 August 3rd 07 09:11 PM
Waterbags for the ASW24 Udo Rumpf Soaring 0 October 4th 03 03:54 PM
