Powersonic "Smart Battery" tested
Old September 9th 20, 02:30 PM posted to rec.aviation.soaring
Default Powersonic "Smart Battery" tested
I've been flying with the Powersonic PSL-BTL-1290 Iron Phosphate battery for about 6 months now. Same size as a 9 AHr Lead Acid battery so it fits in a Dittel battery box. It's rated at 9 AHr but tested on a Western Radio battery tester it achieves 10.4 Ahr (which is what the battery is reporting.) I especially like that it can measure and report discharge rate so you can anticipate run time. You can give each battery a unique name so that when using the app, you can select your battery from the others on the line. I've set 2 of our club gliders up with these batteries and a number of club members are beginning to use them. The battery uses a TI Bluetooth system (as determined by the MAC address) and likely a TI Battery Management Unit. As reported it the measurement system seems to be quite accurate.
Danny Brotto
LS-8/18 "P6"
Battery Charger for PowerSonic SLA/AGM batteries John Foster Soaring 9 May 23rd 20 03:52 AM
Wellington bombers being tested after returning from the raid on Heligoland in 1939 - Wellington bombers being tested.jpg Miloch Aviation Photos 0 August 7th 18 04:06 AM
Werker SLA batteries? (... better than PowerSonic?) 2NO Soaring 29 May 13th 16 04:46 PM
Interesting behavior from PowerSonic battery Steve Leonard[_2_] Soaring 14 May 24th 13 06:38 PM
SMART-1 Mission robert arndt Military Aviation 0 September 28th 03 06:05 AM
