Powersonic "Smart Battery" tested
Old September 10th 20, 12:08 PM posted to rec.aviation.soaring
Default Powersonic "Smart Battery" tested
, I use a charger that tells me how much charge (amp-hours) go into the battery, and it should correspond to how long I used it in the glider.
What charger do you use??
Thanks
Kevin
92
Old September 10th 20, 02:32 PM posted to rec.aviation.soaring
Thanks
Kevin
92
Imax B6. There are various versions, you can find one on ebay for $30 or so. It is a very versatile device, can handle batteries of various chemistries, test discharge capacity, etc. Thanks T8 for the tip.
Old September 10th 20, 05:19 PM posted to rec.aviation.soaring
Dan Marotta
Hook up one of THESE
https://www.wish.com/product/5e1eb742b6c86d0bc080c119?hide_login_modal=true&fro m_ad=goog_shopping&_display_country_code=US&_force _currency_code=USD&pid=googleadwords_int&c=%7Bcamp aignId%7D&ad_cid=5e1eb742b6c86d0bc080c119&ad_cc=US &ad_lang=EN&ad_curr=USD&ad_price=9.00&campaign_id= 7203534630&guest=true&gclid=CjwKCAjwnef6BRAgEiwAgv 8mQZC-b0Lg-t09eDW0sx1O1DnE4m2w3fiw-ptr5D44NUoo20ds7aOxwxoCiroQAvD_BwE&share=web
in series with your charger.Â* I use a Wattsup meter which cost about 5
times as much but that was all that was available at the time I bought it.
Thanks
Kevin
92
Dan, 5J
Battery Charger for PowerSonic SLA/AGM batteries John Foster Soaring 9 May 23rd 20 02:52 AM
Wellington bombers being tested after returning from the raid on Heligoland in 1939 - Wellington bombers being tested.jpg Miloch Aviation Photos 0 August 7th 18 03:06 AM
Werker SLA batteries? (... better than PowerSonic?) 2NO Soaring 29 May 13th 16 03:46 PM
Interesting behavior from PowerSonic battery Steve Leonard[_2_] Soaring 14 May 24th 13 05:38 PM
SMART-1 Mission robert arndt Military Aviation 0 September 28th 03 05:05 AM
