Engine bay fire detection with video camera
Old October 11th 20, 12:03 PM posted to rec.aviation.soaring
Ian Molesworth
Default Engine bay fire detection with video camera
You can buy a car reversing camera that will run off a USB-to-go connector on just about any modern phone.
Install the cable ( usual 4mm USB size ) into the engine box to the cockpit. Perhaps low down and angled up. Plug in to your phone. If it's right you could even see the engine erect so leave it out if there's something wrong.
Some even have an LED light to illuminate a dark engine compartment.
Old October 11th 20, 01:47 AM posted to rec.aviation.soaring
Dave Nadler
On Saturday, October 10, 2020 at 12:54:55 PM UTC-4, Eric Greenwell wrote:
I don't trust the heat sensor on the right side of the engine bay...
Nor should you, it didn't go off in at least one fire I discussed in Feb.
It'd be easy to install a small video camera at the front of the engine bay...
More likely to let you know somethings wrong.
Paul Mander had this setup in his ASH-25J, but obviously it wasn't enough.
An inerting system is a great idea, except the airflow through the engine bay...
I don't know if there's a really good solution.
Fires are bad.
Best HD Video Camera for Flight Videos KiloKilo[_2_] Soaring 66 February 15th 14 07:20 PM
Video camera mount(s)? Terry Pitts Soaring 9 October 26th 13 07:41 AM
Another video using the cheap '808 Keychain camera' Grider Pirate Soaring 12 November 19th 10 02:37 AM
Very Nice Camera for Glider...Stills or HD Video [email protected] Soaring 17 June 16th 09 10:28 PM
Apache gun camera video Andrew Military Aviation 34 January 17th 04 02:48 PM
