Transponder installation article- Soaring Magazine
Old December 16th 20, 01:56 AM posted to rec.aviation.soaring
Default Transponder installation article- Soaring Magazine
On Tuesday, December 15, 2020 at 1:34:24 PM UTC-5, Dan Marotta wrote:
On 12/15/20 10:15 AM, wrote:
On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote:
On 12/15/20 3:02 AM, wrote:
A few random notes from my TT22 installation:
- From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power."
-- A proven hazard demonstrated (luckily) by someone else
- Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on.
- If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed.
-- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers.
Good information about the firmware. I had to send the control head for
the TT22 in the Stemme to the avionics shop for upgrade. There was no
charge for the service IIRC.
Dan
5J
Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article.
Thanks
If your DG303 is experimental, then get the TN72 GPS and TA50 antenna.
Those are what I installed in my gyro and they work perfectly. No need
to buy the gigantic TA70 antenna which is a pain to mount and costs a
bunch more. I mounted my TA50 antenna on the glare shield of the gyro
using the sticky back tape that came with it. It hasn't moved in 150
hours of flying plus ground ops.
Dan
5J
Yes, our 303 is experimental so the trig22 seems like the best way to go. I imagine we'll be also opting for the ADS-B option given the relatively low cost and ease to do so.
Maxim Magazine soaring article [email protected] Soaring 15 April 1st 17 05:40 PM
October Soaring magazine OLC League article Mark628CA Soaring 22 October 11th 14 05:51 PM
Need help locating article from Soaring Magazine Tim Taylor Soaring 1 March 26th 10 10:57 AM
Need help locating article from Soaring Magazine Tim Taylor Soaring 0 March 24th 10 01:20 AM
Subaru magazine soaring article JS Soaring 9 March 21st 08 03:41 AM
