Anybody able to recommend a USA company that can do automated panel
cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! |
Have you talked to Rex?
On Tuesday, January 26, 2021 at 5:56:13 PM UTC-8, wrote: Anybody able to recommend a USA company that can do automated panel cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! |
Anybody able to recommend a USA company that can do automated panel cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! I recently created a panel design for a Cessna using Solidworks. I've done other panels and found it important to model the instruments and components to avoid interferences as many are larger behind the panel then they are in front. We used a nearby water jet shop to make the 5052 Aluminum panel that had to be bent. Waterjet can cut shapes that are difficult to do with round cutters. You may be able to get them to cut a preformed fiberglass panel. I have plans to make new panels for my motor glider. |
On Tuesday, January 26, 2021 at 8:56:13 PM UTC-5, wrote:
Anybody able to recommend a USA company that can do automated panel cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! Try Rex Mayes at Williams Soaring. I understand that they have a source. UH |
On Wednesday, January 27, 2021 at 5:32:34 AM UTC-8, Hank Nixon wrote:
On Tuesday, January 26, 2021 at 8:56:13 PM UTC-5, wrote: Anybody able to recommend a USA company that can do automated panel cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! Try Rex Mayes at Williams Soaring. I understand that they have a source. UH Ditto what Doug said, the panel on my Ventus B is quite different in the back than the front, and different from the available template as well as far as mounting instruments is concerned. It's not even symmetrical left to right. If your install has some tight tolerances you will need to consider this. |
Rex cut my panel for my 27b. I too recommend modeling the instruments in 3D, especially near the edges of the panel, and for depth behind the panel. I discovered many issues prior to cutting the final panel. Also, you can cut a test panel from clear 1/8" plex, and assemble instruments into that so you can see where you might have cable access issues, crashes, etc. That will catch CAD layout mistakes, too. also good for testing visibility and front access while sitting in the cockpit.
Matt On Wednesday, January 27, 2021 at 9:47:37 AM UTC-8, Me wrote: On Wednesday, January 27, 2021 at 5:32:34 AM UTC-8, Hank Nixon wrote: On Tuesday, January 26, 2021 at 8:56:13 PM UTC-5, wrote: Anybody able to recommend a USA company that can do automated panel cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! Try Rex Mayes at Williams Soaring. I understand that they have a source.. UH Ditto what Doug said, the panel on my Ventus B is quite different in the back than the front, and different from the available template as well as far as mounting instruments is concerned. It's not even symmetrical left to right. If your install has some tight tolerances you will need to consider this. |
Waterjets work well for that, google it there's a good chance a shop
in your hometown has one. |
On Wednesday, January 27, 2021 at 3:39:00 PM UTC-8, joesimmers wrote:
Waterjets work well for that, google it there's a good chance a shop in your hometown has one. The water jet shops I've worked with use DXF files to generate their cut paths. Many CAD programs generate DXF files. I don't think the water jet shop wants to work with paper drawings or sketches. |
Exactly Doug, you can either pay them to generate a .dxf file from paper sketch, or provide your own to save cost. The labor to generate the .dxf will likely be higher than the waterjet work but both should be very affordable. |
On 1/26/2021 8:56 PM, Dave Nadler wrote:
Anybody able to recommend a USA company that can do automated panel cutting (from CAD)? Or maybe in Canada? Fiberglass panel, typical glider panel overall size, flat surface with uniform depth flange. Thanks! Geeze guys, CAD does not mean Carbon-pointed-pencil Aided Design. Yes, I do have 3D CAD model to ensure no interferences... Thanks Hank and JFitch for reminding me to try Rex, who sent the reply below. Large-bed CNC router might make nicest result. Dave, Water jet has a delamination problem with wet layed up fiber glass structures like the Shempp panels. (so I am told. I have no direct experience.) The laser does a nice job but it burns the material and leaves a charred edge. This is fixed with a bit of touch up sanding. The thick Shempp panels require 2-3 passes of the laser so the there is a bit of finish work after the cut. CNC mill does a nice job but my table does not have enough travel to cut a panel with out repositioning the work. Let me know if I can help. Rex |
| Thread Tools | |
| Display Modes | |
| Some LiFePO4 Battery Testing Results Manual and Automated | John DeRosa OHM Ω http://aviation.derosaweb.net | Soaring | 32 | October 20th 19 04:26 PM |
| automated flap setting | Wallace Berry[_2_] | Soaring | 16 | September 26th 16 05:03 PM |
| Cutting 57mm holes in the instrument panel.....how to? | John Bojack[_2_] | Soaring | 20 | November 12th 10 10:15 PM |
| Automated Assisted Flight System | James Long | Home Built | 2 | March 5th 06 10:58 AM |
| FAI/IGC/CAI File Name Decoding - Automated!! | ContestID67 | Soaring | 9 | September 24th 05 10:26 AM |
