Wing Drop, Aerotow vs Winch, Grass vs Pavement.
Old March 22nd 21, 04:50 PM posted to rec.aviation.soaring
Aldo Cernezzi
Default Wing Drop, Aerotow vs Winch, Grass vs Pavement.
I suggest everyone have a look at this accident report from France.
It is significant and unusual, as a tow operation lead to a violent groundloop with the sailplane landing inverted, as in a classic and tragic winch accident.
The reason is most probably to be found in the strong headwind.
The accident started with a wing drop, and was irrecuperable within 3 seconds.
The French text shouldn't be a big issue, as the photographic sequence illustrates the event very well and is self-explanatory (especially if you look at the time stamp of each picture.
https://www.bea.aero/uploads/tx_elyd...f-dd140430.pdf
Safe flights,
Aldo Cernezzi
www.voloavela.it
Old March 23rd 21, 04:30 AM posted to rec.aviation.soaring
Brian[_1_]
Safe flights,
Aldo Cernezzi
www.voloavela.it
Very interesting and worth translating.
This data point would seem to indicate higher energy tows are a higher risk of having an issue wshould a wing drop occur. In this event it appear the strong headwind made it an even higher energy tow.
With that much headwind I would not have expected a wing drop as I would have expected to have good aileron and rudder control immediately. But as the report hints to, the combination of a gust and the prop wash may have overpowered the controls.
Thanks for posting.
Brian
Old March 22nd 21, 08:03 PM posted to rec.aviation.soaring
Accounts Receivable
On the winch, if the wing drops, release immediately, you don't have time to consider your options. There's a good chance you can't do it fast enough, and it's going to hurt.
The wing runner isn't going to do a lot of running, if they start you from a balanced position, (which might be slightly different than wings level), and your control inputs are neutral, you will have aileron control and flying speed very quickly after the "All Out" calls.
Old March 23rd 21, 12:41 AM posted to rec.aviation.soaring
waremark
At my club we try to emphasise that the wing runner should not allow the launch to start if there is a significant up or down force on the wingtip.
Someone mentioned water ballast - I think that is very significant, as a low wing allows water to flow towards the tip and make that wing heavier, making recovery less likely.
Old March 23rd 21, 12:57 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
wingtip.
Same at my club. In addition, if there's a cross wind for a winch launch
and the pilot is using aileron to hold the downwind tip up rather than
leaving the stick central while the wing runner moves the tip up or down
to zero the force he's feeling, the wing runner is encouraged to stop the
launch until the stick is centralised.
This is safer because the pilot can't feel what the up- or down-force of
the wingtip is - only the wing runner knows that. And so, if the
balancing is left to the pilot, the chances of an immediate tip drop is
raised.
Agreed.
Martin | martin at
Gregorie | gregorie dot org
Old March 23rd 21, 04:34 AM posted to rec.aviation.soaring
Brian[_1_]
wingtip.
raised.
Agreed.
Martin | martin at
Good point about wing runners. What I teach wing runners is if the wing wants to go up, to let it go up as high as you can reach. If it goes low, let it go as low as is practical, as this will signal the pilot to put the correct input in to correct for wing low or wing high condition.
Brian
Old March 23rd 21, 04:20 PM posted to rec.aviation.soaring
Dan Marotta
Not so much if the wing tanks are full and not interconnected.
Dan
5J
Old March 23rd 21, 05:28 PM posted to rec.aviation.soaring
John Sinclair[_5_]
Dan
5J
I believe a nose tow hook reduces lateral excursions, but not all ! There was a Genesis-2 take off accident where the slack was not all taken out before starting tow. This resulted in glider pitching down on the nose wheel which is mounted on a 36” fiberglass shock strut which then sprung the nose up! It’s called the Hobby-horse effect which is annoying, but not all that dangerous, unless a wing tip touches the ground as the fuselage is pitching down. This can (and has) resulted in the glider cartwheeling and ended up inverted!
If you’d ship doesn’t have a nose tow hook I’d investigate having one installed!
Be safe out there and keep a hand on the tow release during takeoff!
JJ
Old March 24th 21, 12:34 PM posted to rec.aviation.soaring
Tango Eight
It's true that at the very beginning of the launch, the nose hook improves tracking. It's also true that once aerodynamic control is achieved that the rudder works better with a CG hook, and the rudder often (this is type dependent) works better for picking up a low wing than aileron input.
In all cases, the only thing that beats pilot skill is pilot judgement.
The release knob is the most under rated control in the cockpit.
T8
Vought F4U Corsair pics [05/11] - A United States Navy F4U-5NL Corsair equipped with the air intercept radar (right wing) and a 154-gallon drop tank in the Geneseo Airshow, in July 9, 2006.jpg (1/1) Miloch Aviation Photos 0 March 3rd 18 03:04 PM
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
landing on pavement Mark IV Piloting 15 December 3rd 10 08:11 PM
Aerotow Fuel Costs & Winch Launching Derek Copeland[_2_] Soaring 2 May 26th 08 03:14 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
Copyright 2004-2025 AviationBanter.
