FAA Permanently Revokes Pilot's License over ADS-B
Old May 19th 21, 04:20 AM posted to rec.aviation.soaring
2G
Default FAA Permanently Revokes Pilot's License over ADS-B
On Tuesday, May 18, 2021 at 11:00:27 AM UTC-7, wrote:
On Monday, May 17, 2021 at 11:35:16 PM UTC-4, kinsell wrote:
The parrot wasn't squawking ADS-B, that's for sure. I see an occasional
C-17 transmitting it, but it seems most military traffic isn't equipped
even today.
On 5/17/21 12:35 PM, Dan Marotta wrote:
We only did that during certain mission profiles. Otherwise the parrot
was squawking.
Dan
5J
Become a military pilot...they will turn tracking off, when they
choose.
For obvious reasons I would think that most military traffic would not be ADS-B broadcasting. I certainly know the ones going into 2901 are NOT. There have been a couple of points here on this thread that are very interesting. One was that Ole Andy is clueless about Restricted Zone operation. The good point that Tony made was that ATC has the latest operational information on Hot or Cold for these restricted areas. Each Restricted area has an ATC zone that is responsible for that information, in our case it is Miami Center. That Center has a mission desk that receives operational status the day or afternoon prior as to the operational times for that specific RA.
For our area that information comes from MacDill AFB usually around 4pm, As Tony stated do not plan on using the NOTAM as the true determination as to whether the zone is HOT or Cold. These zones can change within a few hours notice. You can call the mission desk for that center and as in our case they are always very informative as to the operational hours. I my case I will call the Mission desk, get the current status of each area within that RA, there is usually a 4 hour window for a zone to become operational. I always check with the ATC to confirm the current status to double check the status, I do this by calling Miami ATC on the radio as I am approaching the RA. Keep in mind that these areas are multi purpose military training areas, aircraft, helicopter, artillery, and special warfare training takes place in some of these RA areas. I have has a F-18 circle me outside of the RA while in the MOA, we gave each other the thumbs up, it was great. Old Bob
Hey Robby, you, as usual, are totally confused. I was NOT referring to how you obtain permission to enter a restricted area, but how the FAA might react if someone files a complaint about your flight into a restricted area. And it WAS a question - not a statement.
And you might actually look into why most military aircraft aren't equipped with ADS-B. Hint: it is not for the reason you think it is. BTW, military aircraft are subject to ALL the rules that apply to non-government aircraft..
Also, some may interpret you derisive comments referring to Amos and Andy as being racist.
Tom
Old May 19th 21, 01:07 PM posted to rec.aviation.soaring
even today.
was squawking.
Dan
5J
choose.
Tom
Andy, you were totally clueless about the Restricted Area operation, you comment was ,"Is The FAA Going To Check And See If The Restricted Area Was Hot"? You of all people should know that the FAA knows when an area is hot or not, they issue the NOTAM and updates.
Now about Amos & Andy, it was hilarious comedy, along with All In The Family, The Jeffersons, and the Three Stooges, you fit the mold, I guess I could have called you Meathead, or Curley, but Andy fit you much better. Your buddy, The Purist! Old Bob
Old May 19th 21, 03:39 PM posted to rec.aviation.soaring
Tony[_7_]
even today.
was squawking.
Dan
5J
choose.
For obvious reasons I would think that most military traffic would not be ADS-B broadcasting. I certainly know the ones going into 2901 are NOT. There have been a couple of points here on this thread that are very interesting. One was that Ole Andy is clueless about Restricted Zone operation. The good point that Tony made was that ATC has the latest operational information on Hot or Cold for these restricted areas. Each Restricted area has an ATC zone that is responsible for that information, in our case it is Miami Center. That Center has a mission desk that receives operational status the day or afternoon prior as to the operational times for that specific RA..
Tom
My point about the real-time aspect of Special Use Airspace is that it can be NOTAMed hot all week and get used for 20 minutes. Sector knows even better than desk jockey.
Old May 20th 21, 06:57 AM posted to rec.aviation.soaring
2G
even today.
was squawking.
Dan
5J
choose.
Tom
Hey Robby, and you know the FAA knows HOW? ATC is one division, enforcement another. And you idiotically assume that they actually TALK to each other? Give me a break - you are more gullible than I thought!
Your comments might very well be considered racist by many these days, but you are not of a mind to see that. We might as well call you Black Face Bob..
Tom
Private pilot license [email protected] Piloting 84 July 7th 11 02:31 PM
Is the pilot license needed...? Externet Piloting 41 November 29th 06 10:57 PM
Private Pilot's License Vern Torino Piloting 22 September 23rd 05 09:07 PM
Sport Pilot license keepitrunning Home Built 48 July 25th 05 05:21 PM
What is this sports pilot license about? Frequent_Flyer Piloting 6 August 2nd 03 10:51 AM
