Don Tuite wrote in
news ![]() On Fri, 16 Jan 2004 03:49:16 -0000, Marty Shapiro wrote: The SOCATA Rallye does NOT have a stall warning device! It has automatic leading edge slats which will pop out at larger angels of attack, but you are still well above stall. A power off stall is very interesting in this aircraft. You start to get stall buffett and, if you simply hold the yoke all the way back, you descend a little over 1000 fpm with the nose level on the horizon. You can turn with just the ailerons as you are descending. What happens if you yank the sitck back? Or if you start to apply rudder to accelerate a turn and then apply opposite aileron to keep from banking too steeply and just keep on crossing the controls while you bleed off airspeed? Just curious. I'm sure the results in the Socata are benign. Don I've gotten a slight stall break in a 3/4 power on stall. Very benign with a slight fall off to the right which was easily countered with ruddder. With full power and no flaps, I've approached stall buffet, but at that point I was more than 30 degrees nose high and felt like I was going to tumble out of my seat backwards. And, at the onset of stall buffet, I was still climbing! The Rallye is a STOL aircraft with oversized control surfaces and Fowler flaps. I have done turns starting from a maximum forward slip and didn't notice any adverse behavior, but I was probably 10 knots above stall. I've done 45 degree banked turns at MCA and found the aircraft handling to be smooth and solid. One of my partners has gone to 60 degrees bank at MCA and said he had the same results. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
In article , Marty Shapiro
wrote: It has automatic leading edge slats which will pop out at larger angels of attack, but you are still well above stall. Those wouldn't be the angels of death, by chance, would they? |
EDR wrote in
: In article , Marty Shapiro wrote: It has automatic leading edge slats which will pop out at larger angels of attack, but you are still well above stall. Those wouldn't be the angels of death, by chance, would they? Only if I attach something to the 4 hard points standard on the Rallye 235E! -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
(Kees Mies) wrote in
om: The Socata Rallye has a stall warning! Their famous automatic leading edge slats are it. At least, that's what I use them mainly for. They are great speed brakes too. I do not pay much attention to the air speed at take off or on short final. When I see the leading edge go forward about 4 inches from the corner of my left eye, I know it is time to have a look at the dials. To my opinion these are the best stall warnings one can have. Instead of a lot of noise(a Rallye is noisy enough) and some red light, they keep the stall away for about 15 kts. This said, do not try to flare a Rallye at too high speed. The slats pop out and you go up again. And they keep the Socata leading-edge-slat-roller-division going. Regards, Kees MS880B Marty Shapiro wrote in message ... Roy Smith wrote in news:roy- : Researching a question from a club member, I read in the FAR's: §**23.207 *Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? The SOCATA Rallye does NOT have a stall warning device! It has automatic leading edge slats which will pop out at larger angels of attack, but you are still well above stall. A power off stall is very interesting in this aircraft. You start to get stall buffett and, if you simply hold the yoke all the way back, you descend a little over 1000 fpm with the nose level on the horizon. You can turn with just the ailerons as you are descending. Under the definition of stall warning in the US FAR §23.207 (which references §23.1185), the automatic leading edge slat deployment is NOT a stall warning. Although the automatic leading edge slat deployment meets the requirement of §23.207(c) where warning is required at least 5 knots above stall, it does NOT meet the requirement of §23.207(d) "When following procedures furnished in accordance with §23.1585, the stall warning must not occur during a takeoff with all engines operating, a takeoff continued with one engine inoperative, or during an approach to landing." 23.1585 refers to the required aircraft operating procedures which include Vx, Vy, etc. In the Rallye 235E, the slats will automatically deploy at rotation and remain deployed at both Vx and Vy. As you transition from Vy to cruise climb, they retract. They also deploy on landing at about Vref. At Vx, Vy, and Vref, the automatic deployment of the leading edge slats violate the FAR requirements for a stall warning. The slats will sometimes extend & retract in light chop at cruise speed (Va and above). I've never had a stall horn in a Piper or Cessna sound off in light chop. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
(Kees Mies) wrote in om: The Socata Rallye has a stall warning! Their famous automatic leading edge slats are it. At least, that's what I use them mainly for. They are great speed brakes too. I do not pay much attention to the air speed at take off or on short final. When I see the leading edge go forward about 4 inches from the corner of my left eye, I know it is time to have a look at the dials. To my opinion these are the best stall warnings one can have. Instead of a lot of noise(a Rallye is noisy enough) and some red light, they keep the stall away for about 15 kts. This said, do not try to flare a Rallye at too high speed. The slats pop out and you go up again. And they keep the Socata leading-edge-slat-roller-division going. Regards, Kees MS880B Marty Shapiro wrote in message ... Roy Smith wrote in news:roy- : Researching a question from a club member, I read in the FAR's: §**23.207 *Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? The SOCATA Rallye does NOT have a stall warning device! It has automatic leading edge slats which will pop out at larger angels of attack, but you are still well above stall. A power off stall is very interesting in this aircraft. You start to get stall buffett and, if you simply hold the yoke all the way back, you descend a little over 1000 fpm with the nose level on the horizon. You can turn with just the ailerons as you are descending. Under the definition of stall warning in the US FAR §23.207 (which references §23.1185), the automatic leading edge slat deployment is NOT a stall warning. Although the automatic leading edge slat deployment meets the requirement of §23.207(c) where warning is required at least 5 knots above stall, it does NOT meet the requirement of §23.207(d) "When following procedures furnished in accordance with §23.1585, the stall warning must not occur during a takeoff with all engines operating, a takeoff continued with one engine inoperative, or during an approach to landing." 23.1585 refers to the required aircraft operating procedures which include Vx, Vy, etc. In the Rallye 235E, the slats will automatically deploy at rotation and remain deployed at both Vx and Vy. As you transition from Vy to cruise climb, they retract. They also deploy on landing at about Vref. At Vx, Vy, and Vref, the automatic deployment of the leading edge slats violate the FAR requirements for a stall warning. The slats will sometimes extend & retract in light chop at cruise speed (Va and above). I've never had a stall horn in a Piper or Cessna sound off in light chop. Hi, Nice research. I did some myself. Under KEES' FAR §58112.fgg(c) is stated: The installation of a stall warning device has NO relationship with the pilots'/operator/owners' sense of humor. |
![]() "Roy Smith" wrote in message ... Researching a question from a club member, I read in the FAR's: § 23.207 Stall warning. [...] (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? My Aeronca 7AC has no mechanical stall warning device. Few aircraft of that vintage do. |
On Fri, 16 Jan 2004 04:21:48 GMT, "Steven P. McNicoll"
wrote: "Roy Smith" wrote in message ... Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? My Aeronca 7AC has no mechanical stall warning device. Few aircraft of that vintage do. The Citabria I learned to fly on (7ECA) was licensed under the same certificate as the 7AC, and it didn't have a stall warning device. They are certified, of course, but very few of the 25,000 homebuilts in the US have mechanical stall warning systems. Of course, the bracing wires of my Fly Baby sing "Nearer My God to Thee" when I get too slow.... :-) Ron Wanttaja |
In article , Roy Smith
writes: Every plane I've ever flown has a mechanical stall warning device (some visual, some aural), but apparantly it's possible to certify a plane without one. Does anybody know of any real life examples of planes certified without stall warning devices? The IAI 1124 Westwind jet I fly does not have any stall warning devices installed. I have not taken it to a full stall and break, but it does give plenty of warning, via buffeting, of an impending stall. G. Lee (If it ain't broke, don't fix it. If it ain't fixed, don't fly it.) |
certified without stall warning devices? Aeronca Champ 7CCM---so much as they are not "airplanes" I've not yet seen a sailplane with a stall warning device. Funny, considering how much time we spend banked to 45 degrees or more just above stall. Oh that's right, we become "one" with the plane, don't need no stinken stall warning. Mac |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 07:27 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
