Howdy!
In article 01PLc.162096$XM6.47385@attbi_s53, William W. Plummer wrote: Capt.Doug wrote: [snip] Other planes break apart in different ways. The T-34 has been in the news quite a bit lately because of wings falling off. It appears that the tail isn't breaking. The cause is attributed to metal fatigue from repeated large No. I've seen discussion that suggests the problem is operator error. Rolling pullups can, apparently, generate excessive g-loads with remarkable ease. [snip] Metal fatigue, cracks and construction defects are not caused by turbulence although turbulence may be the straw that breaks the camel's back when those problems exist. IIRC the Convair Electra was the first plane that metal fatigue was determined to be the cause of its wings coming off. And, it took years. What caused the fatigue? Gyroscopic motion of the wings. Not quite. Damage to engine mounts would lead to whirl mode oscillation of the engines, which would resonate with the wing, inducing flutter, leading to wing coming off. yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/ |
"William W. Plummer" wrote
Metal fatigue, cracks and construction defects are not caused by turbulence although turbulence may be the straw that breaks the camel's back when those problems exist. IIRC the Convair Electra was the first plane that metal fatigue was determined to be the cause of its wings coming off. And, it took years. What caused the fatigue? Gyroscopic motion of the wings. Turbulence most certainly is the cause of fatigue in the wing structure of aircraft. I would suggest that you read FAR Part 25 to understand how the nature of the Standard Atmosphere and the cruise speed is used in designing a "fatigue life" in transport category aircraft. "Convair Electra"??? No way...my Electra time was flown in a Lockheed Electra..L-188 and it's US Navy derivitive the P-3 Orion. The civilian L-188s failed early in their service life, Braniff's Flight 542 crashed in 1959, only two months after it's delivery from Lockheed. The Northwest Flight 710 crashed in 1960 after only one year in service. It was not "gyroscopic motion of the wings" nor "fatigue"....... "On May 12, 1960, Lockeed President Bob Gross announced that both airliners broke-up due to an undampened propeller whirl mode that produced destructive flutter of the wing." This from the "Great Airliners Series, Volume Five, Lockheed 188 Electra" by David G. Powers. You disappoint me William. Bob Moore Air Florida L-188 1973 VP-46 P-3B 1965-67 |
The design limit is not really lower for negative G. Remember that you are
starting at +1G so, if the limits are +3.8G and -1.8G, the limits are both 2.0g away from steady state flight. Mike MU-2 "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. |
Mike Rapoport wrote:
The design limit is not really lower for negative G. Remember that you are starting at +1G so, if the limits are +3.8G and -1.8G, the limits are both 2.0g away from steady state flight. Mike has the idea. You need to look at a V-g/V-n diagram for your aircraft to see where the load limits lie for a given airspeed. This is how Eckalbar explains it. |
... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. There was a long thread in January, "Va and turbulent air penetration speed" which you ought to be able to find on Google. The short answer is that flying below Va (even at max weight) doesn't guarantee that the wing will stall before exceeding the load factor. Va is defined in terms of what control surfaces can handle, not when the wings will fall off; see for example FAR 23.423 and 23.335. |
![]() Tony Cox wrote: "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. There was a long thread in January, "Va and turbulent air penetration speed" which you ought to be able to find on Google. Can I suggest that avoiding turbulent air is simply the most pragmatic approach? It's broken enough airliners for starters ! Graham |
Weapons of Mass Destruction | running with scissors | Instrument Flight Rules | 23 | April 24th 04 02:00 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
Budgets of Mass Destruction | B2431 | Military Aviation | 4 | February 4th 04 04:38 AM |
please stop bashing France | Grantland | Military Aviation | 233 | October 29th 03 01:23 AM |
How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 05:30 PM |
