"K. Ari Krupnikov" wrote in message
... Isn't there some sort of "standard DP" that says you need to climb at a certain gradient (250fpnm or so?) absent specific published DP for the airport? Are you saying that gradient would have taken you into terrain? If there is no published DP then a 200 feet per nautical mile gradient should clear the terrain. In this case, there was a published DP with an initial climb to the right. However, ATC gave me alternate takeoff instructions with a turn to the left, and looking at the approach chart to MGW you can see that a left turn off of runway 18 does indeed come uncomfortably close to terrain. MGW Tower seemed unaware of the departure procedure, and in fact when I specifically requested it I was told "Unable due to traffic -- Cleared for takeoff, Climb on runway heading"; that procedure ALSO comes uncomfortably close to terrain. The published procedure with a turn to the right is indeed the only rational procedure for departing this airport, even if that means (as in my case) volunteering to delay an IMC departure until the conflicting traffic is clear. Incidentally, this is a really helpful concept to teach on an instrument proficiency check. I have a routine clearance from "Kaplan Approach" which I give to pilots during an instrument proficiency check which takes a pilot straight into a mountain below the MEA when there is no radar vectoring and thus terrain clearance is entirely the pilot's responsibility; very, very rarely do pilots pick up on this, and instead almost everyone sets up course to fly right into the mountain until at an appropriate time I say "Take off the hood and tell me what is wrong with this picture." This is a terrific attention-getter for a post-flight talk about CFIT avoidance. -- Richard Kaplan, CFII www.flyimc.com |
![]() "K. Ari Krupnikov" wrote in message ... Isn't there some sort of "standard DP" that says you need to climb at a certain gradient (250fpnm or so?) absent specific published DP for the airport? Are you saying that gradient would have taken you into terrain? Yes, but it applies only at airports with SIAPs. If no specific DP is published, then the "standard DP" will ensure obstacle clearance to the minimum IFR altitude; cross the departure end of the runway a minimum of 35 feet AGL, climb at least 200 feet per nautical mile, and climb to 400 feet above field elevation before turning. |
![]() Richard Kaplan wrote: 2. At JST on an ILS approach with weather intermittently below approach minimums when I was inside the final approach fix I was given the instruction "Alternate Missed Approach Instructions -- Proceed Direct MGW" -- I was unable to confirm terrain clearance at such a busy time of flight and the controller would not verify terrain clearance either (note I was not on a vector and was below the MEA so he had no responsibility for terrain clearance at that point if I accepted the instructions). After some on-air discussion, the controller finally gave me a "Center assigned heading" which reflected that Center verified terrain clearance. Where do you learn this stuff? If ATC says to proceed direct to some fix they damn sure do assume terrain separation responsibility. |
"Newps" wrote in message
.net... Where do you learn this stuff? If ATC says to proceed direct to some fix they damn sure do assume terrain separation responsibility. ATC assumes terrain separation if they provide navigational guidance in the form of radar vectors but not if they instruct a pilot to Proceed Direct. See AIM 5-2-6: "ATC may assume responsibility for obstacle clearance by vectoring the aircraft prior to minimum vectoring altitude by using a diverse vector area (DVA). The DVA has been assessed for departures which do not follow a specific ground track. ATC may also vector an aircraft off a previously assigned DP. In all cases, the 200 FPNM climb gradient is assumed and obstacle clearance is not provided by ATC until the controller begins to provide navigational guidance in the form of radar vectors." -- Richard Kaplan, CFII www.flyimc.com |
![]() "Richard Kaplan" wrote in message s.com... 1. At MGW on an IMC day on takeoff from Runway 18 with terrain obscured I was given the instruction "Cleared for Takeoff -- Turn Left on Course" which is clearly contrary to the published departure procedure and would take me into terrain. They probably just said that because whatever you filed would mean a left turn from a south departure to proceed on course. Turn left on course doesn't mean you have to start a left turn as soon as your wheels are off the runway. They can't deny you the DP, if a published IFR departure procedure is not included in an ATC clearance, compliance with such a procedure is the pilot's prerogative. 2. At JST on an ILS approach with weather intermittently below approach minimums when I was inside the final approach fix I was given the instruction "Alternate Missed Approach Instructions -- Proceed Direct MGW" -- I was unable to confirm terrain clearance at such a busy time of flight and the controller would not verify terrain clearance either (note I was not on a vector and was below the MEA so he had no responsibility for terrain clearance at that point if I accepted the instructions). After some on-air discussion, the controller finally gave me a "Center assigned heading" which reflected that Center verified terrain clearance. Did they arbitrarily send you to MGW, or did you tell them at some point that you'd like to proceed to MGW in the event of a miss? Again, "proceed direct MGW" doesn't mean you must start a left turn to MGW at the MAP. |
k.net... the runway. They can't deny you the DP, if a published IFR departure They did deny me the DP until I volunteered that I would delay my departure, and they still seemed puzzled as to why I wanted to wait. Did they arbitrarily send you to MGW, or did you tell them at some point that you'd like to proceed to MGW in the event of a miss? Again, "proceed direct MGW" doesn't mean you must start a left turn to MGW at the MAP. MGW was not an arbitrary destination; I had requested to fly the published missed at JST and then proceed to MGW. "Proceed direct MGW" was indeed the proposed alternate missed approach procedure; the missed approach procedure needs to be executed at the missed approach point. Indeed, I again requested the published missed and was denied it. -- Richard Kaplan, CFII www.flyimc.com |
"Richard Kaplan" wrote in message ws.com...
"Byron Miller" wrote in message ... Nicest controllers, safe airport and friendly skies. They're not any more incompetant than a "guvenment" controller and most certainly they enjoy aviation and the lifestyle just as much as anyone else could! Well this may be just coincidence and in any event when n=2 not all that much can be concluded, but for what it is worth I have had two experiences when controllers gave me instructions while low altitude in IMC which could have resulted in a controlled flight into terrain accident, and both situations occurred at a non-towered field -- once at Morgantown WV KMGW and once at Johnstown PA KJST. Richard, Perhaps I'm not following the juxtaposition. Are you saying that contract tower controllers gave you these instructions, or that FAA controllers gave you these instructions whilst you were operating at a non-towered airport for which they provide approach/departure services? I have to admit the "proceed direct MGW" part might have caught us. Thanks very much for the heads-up, we'll be on alert for that kind of thing. Cheers, Sydney |
![]() "Snowbird" wrote in message om... Perhaps I'm not following the juxtaposition. Are you saying that contract tower controllers gave you these instructions, or that FAA controllers gave you these instructions whilst you were operating at a non-towered airport for which they provide approach/departure services? The instructions were from a controller at a non-federal control tower. So it was a controller who was not an FAA employee. When I mentioned "non-towered" that was my error; I meant "non-Federal towered". I have to admit the "proceed direct MGW" part might have caught us. Thanks very much for the heads-up, we'll be on alert for that kind of thing. Yes, very subtle and very scary.. and I am convinced the controller used the terminology precisely because when he finally assumed terrain responsibility he said "Fly Heading XXX, Center Assigned Heading". I interpret that to mean "I check with Center and I am stating for the tape that Center is responsible for terrain if you hit something on that heading." -- Richard Kaplan, CFII www.flyimc.com |
![]() "Richard Kaplan" wrote in message s.com... The instructions were from a controller at a non-federal control tower. So it was a controller who was not an FAA employee. When I mentioned "non-towered" that was my error; I meant "non-Federal towered". My A/FD is almost two years old, but it indicates MGW is an FAA Contract Tower and JST is still an FAA tower. |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
MN Airport Closure Notification Legislation (S.F. 2178/H.F. 2737) | Dan Hoehn | General Aviation | 1 | May 25th 04 01:52 PM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 04:02 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! | Bill Mulcahy | General Aviation | 3 | October 1st 03 05:39 AM |
