Your more then welcome to see the performance specs for a T-arrow, they are here
http://www.turboarrow3.com/newplane/specs.html those are the book values tho and I havnt seen their speeds yet but I only fly at 65% power settings. Jeff http://www.turboarrow3.com Stu Gotts wrote: On Fri, 21 Nov 2003 23:16:33 -0800, Jeff wrote: I know a guy with a comanche 260, really nice plane, fast, good useful load. his will do 160 kts. Heck my 200 HP Turbo Arrow III typically does 150-155 kts. I guess these claims are correct. I was referring to a no tail wind situation!!! Jeff http://www.turboarrow3.com Stu Gotts wrote: On Fri, 21 Nov 2003 17:23:27 -0600, "O. Sami Saydjari" wrote: I am looking at buying one of two planes: a 1978 Mooney M20J or a 1965 Piper Commanche PA-24-260. I have test driven both and I like the handling of both. Both are about the same price. The avionics in the Mooney are slightly better. This is a tough choice. (1) Is there anyone out there that has flown both airplanes extensively and can give me pros and cons of each from their perspective? (2) Is there any other plane with similar price/performance capabilities (cruise at better than 160nts, 750+ range) in the same price range ($75K-$100K) that I should consider? (3) I heard Mooney is teetering on bankruptcy. Is this a real big downside? Has anyone experienced owning a plane with a manufacturer went bankrupt. Do parts become impossible to find? -Sami 1. Bonanza - there is no substitute. 2. Those speeds are vaporware, you'll never see them from either machine. 3. Mooney seems to be emerging from their financial troubles, and believe it or not, may own Beechcraft soon. Comanche parts are becoming a bit difficult to find and added to the fact that the aircraft is no being produced worries me. Also, a good Comanche mechanic is a must if you want to keep the aircraft in the air. Good luck. |
![]() "Jeff" wrote in message ... Your more then welcome to see the performance specs for a T-arrow, they are here http://www.turboarrow3.com/newplane/specs.html those are the book values tho and I havnt seen their speeds yet but I only fly at 65% power settings. Jeff http://www.turboarrow3.com Have you/are you going to install GAMI turbo injectors in that thing? |
O. Sami Saydjari wrote: I am looking at buying one of two planes: a 1978 Mooney M20J or a 1965 Piper Commanche PA-24-260. I have test driven both and I like the handling of both. Both are about the same price. The avionics in the Mooney are slightly better. This is a tough choice. I considered buying a Mooney (J or upgraded F) for a long time, but I ended up buying a 1965 PA-24-260. I've climbed all over an M20J, and flown one for about an hour. I've got about 50 hours now in PA-24s. Here are some tradeoffs I can think of: The Mooney cruises faster. The Comanche climbs faster. The Comanche has much more interior room and carries a greater load. The Comanche's baggage area is more accessible, especially in 260B+ models. I'm 6'4" and fit in both. The Mooney does it with a lot of legroom under the instrument panel, while the Comanche has a more typical upright seating posture. The Mooney has only 2/3rds as many cylinders to maintain. The Comanche doesn't have cowl flaps (unless retrofitted with an aftermarket cowling that requires them) or ram-air (though the M20J doesn't *need* the ram air as much as the F did). The Comanche's systems are easier to reach, in general. For example, the original cowling has two large doors. In contrast, the Mooney is "build around" some of the flight control torque tubes and avoinics access may have to be through a panel on the cowling. Both have reliable gear systems and simple mechanical manual extension systems. The Mooney's can be tested in flight and then retracted electrically. The Comanche technically has to be on jacks after a manual extension, though some claim to do it while airborn. The Mooney uses shock absorbing pucks of rubber in a trailing-link configuration, while the Comanche uses struts. The Comanche has greater prop clearance as well as the better shock absorbing which makes it more suitable for unimproved strips (though to be fair some Mooneys regulary fly out of such strips, and neither is as versatile as a C182, or for that matter a Cub). The Mooney's landing light is in the cowling, the Comanche's are in the wings. The Mooney has an all-flying tail (trim pivots the entire thing) while the Comanche has a stabilator. Both have very positive trim control at cruise. The travel on the trim control is excessive at low speeds in the Comanche, IMO. I haven't flown the M20J enough to recall. The Mooney has a wet wing which is prone to sealing problems (some have been retrofitted with bladders which reduce capacity a little and are better at trapping water) while the Comanche has bladders which can develop leaks (especially if tied down in the sun without full fuel). If the Comanche's bladders are original they're also very old. Most Comanches carry more fuel than most Mooneys, but also need it to get the same range (~13gph vs ~10gph). You can probably go a little farther (far far beyond my endurance!) in a 86gal (usable) Mooney than a 64gal M20J, and there are Comanches with tip tanks for a total of 116gal usable. Old Mooneys and Comanches both have atrocious panels. Some newer Mooneys have very nice panels. Some of both have been retrofitted. It does make them hard to compare. Well equipped examples of both are available, you just have to shop harder for a Comanche. Both have a loyal following of owners. Both were made by companies which have "gone out of business" several times, but parts availability is still reasonably good for both. (2) Is there any other plane with similar price/performance capabilities (cruise at better than 160nts, 750+ range) in the same price range ($75K-$100K) that I should consider? Maybe the Commander 112/114/115. I didn't really hear anything about them until after I bought my plane, though. -- Ben Jackson http://www.ben.com/ |
![]() "Ben Jackson" wrote in message news ![]() Both were made by companies which have "gone out of business" several times, but parts availability is still reasonably good for both. (2) Is there any other plane with similar price/performance capabilities (cruise at better than 160nts, 750+ range) in the same price range ($75K-$100K) that I should consider? Maybe the Commander 112/114/115. I didn't really hear anything about them until after I bought my plane, though. And the Commander Aircraft Comp. is just about out of business, too. I was thinking of a 114B recently, but declined when I was made aware of their financial situation. It might disrupt replacement parts and it might not. I'd hate to find out the hard way, though. Now, instead, I'm about 95% sure I'll be picking up an F33A right after New Years. |
On Sat, 22 Nov 2003 06:25:31 -0700, "Tom S."
wrote: And the Commander Aircraft Comp. is just about out of business, too. I was thinking of a 114B recently, but declined when I was made aware of their financial situation. It might disrupt replacement parts and it might not. I'd hate to find out the hard way, though. Now, instead, I'm about 95% sure I'll be picking up an F33A right after New Years. That's the spirit! You'll go farther and faster more comfortably on less fuel, and won't have to worry about stretching the numbers when bragging to your friends. Good man! |
LOL...Stu you kill me.
what plane do you own..just out of curiousty... you know there ways to see the book performance on any airplane, like the f33 is here http://www.risingup.com/planespecs/i...plane116.shtml its not that fast of an airplane. That's the spirit! You'll go farther and faster more comfortably on less fuel, and won't have to worry about stretching the numbers when bragging to your friends. Good man! |
Which kind to you think?
I've yet to see the majority of planes get the book numbers, so I'd say that's a bit aggressive. On Sat, 22 Nov 2003 19:04:07 -0800, Jeff wrote: LOL...Stu you kill me. what plane do you own..just out of curiousty... you know there ways to see the book performance on any airplane, like the f33 is here http://www.risingup.com/planespecs/i...plane116.shtml its not that fast of an airplane. That's the spirit! You'll go farther and faster more comfortably on less fuel, and won't have to worry about stretching the numbers when bragging to your friends. Good man! |
Ben, thank you so much. Your answer has been most helpful!
-sami Ben Jackson wrote: In article , O. Sami Saydjari wrote: I am looking at buying one of two planes: a 1978 Mooney M20J or a 1965 Piper Commanche PA-24-260. I have test driven both and I like the handling of both. Both are about the same price. The avionics in the Mooney are slightly better. This is a tough choice. I considered buying a Mooney (J or upgraded F) for a long time, but I ended up buying a 1965 PA-24-260. I've climbed all over an M20J, and flown one for about an hour. I've got about 50 hours now in PA-24s. Here are some tradeoffs I can think of: The Mooney cruises faster. The Comanche climbs faster. The Comanche has much more interior room and carries a greater load. The Comanche's baggage area is more accessible, especially in 260B+ models. I'm 6'4" and fit in both. The Mooney does it with a lot of legroom under the instrument panel, while the Comanche has a more typical upright seating posture. The Mooney has only 2/3rds as many cylinders to maintain. The Comanche doesn't have cowl flaps (unless retrofitted with an aftermarket cowling that requires them) or ram-air (though the M20J doesn't *need* the ram air as much as the F did). The Comanche's systems are easier to reach, in general. For example, the original cowling has two large doors. In contrast, the Mooney is "build around" some of the flight control torque tubes and avoinics access may have to be through a panel on the cowling. Both have reliable gear systems and simple mechanical manual extension systems. The Mooney's can be tested in flight and then retracted electrically. The Comanche technically has to be on jacks after a manual extension, though some claim to do it while airborn. The Mooney uses shock absorbing pucks of rubber in a trailing-link configuration, while the Comanche uses struts. The Comanche has greater prop clearance as well as the better shock absorbing which makes it more suitable for unimproved strips (though to be fair some Mooneys regulary fly out of such strips, and neither is as versatile as a C182, or for that matter a Cub). The Mooney's landing light is in the cowling, the Comanche's are in the wings. The Mooney has an all-flying tail (trim pivots the entire thing) while the Comanche has a stabilator. Both have very positive trim control at cruise. The travel on the trim control is excessive at low speeds in the Comanche, IMO. I haven't flown the M20J enough to recall. The Mooney has a wet wing which is prone to sealing problems (some have been retrofitted with bladders which reduce capacity a little and are better at trapping water) while the Comanche has bladders which can develop leaks (especially if tied down in the sun without full fuel). If the Comanche's bladders are original they're also very old. Most Comanches carry more fuel than most Mooneys, but also need it to get the same range (~13gph vs ~10gph). You can probably go a little farther (far far beyond my endurance!) in a 86gal (usable) Mooney than a 64gal M20J, and there are Comanches with tip tanks for a total of 116gal usable. Old Mooneys and Comanches both have atrocious panels. Some newer Mooneys have very nice panels. Some of both have been retrofitted. It does make them hard to compare. Well equipped examples of both are available, you just have to shop harder for a Comanche. Both have a loyal following of owners. Both were made by companies which have "gone out of business" several times, but parts availability is still reasonably good for both. (2) Is there any other plane with similar price/performance capabilities (cruise at better than 160nts, 750+ range) in the same price range ($75K-$100K) that I should consider? Maybe the Commander 112/114/115. I didn't really hear anything about them until after I bought my plane, though. |
"O. Sami Saydjari" wrote in message ...
I am looking at buying one of two planes: a 1978 Mooney M20J or a 1965 Piper Commanche PA-24-260. (3) I heard Mooney is teetering on bankruptcy. Is this a real big downside? So what? Piper has already been there. Take the Mooney, it is newer,faster and more efficient. |
how much money have you lost on the lottery? NOW GET THAT MONEY BACK! | shane | Home Built | 0 | February 5th 05 07:54 AM |
Start receiving MONEY with this simple system. Guaranteed. | Mr Anderson | Aviation Marketplace | 0 | February 2nd 04 11:55 PM |
