C-182 or C-1820RG, or C-210....
Old December 4th 03, 05:25 PM
Dick Meade
Pat,
E-mail me for some info on 182 vs 260 SE. Your e-mail bounces.
Dick Meade
"Pat Thronson" wrote in message
t...
Check out the 260se 182.... anybody comment on the negatives of this mod?
price/performance/ comparably priced different aircraft?
http://www.260se.com/features.html
Pat Thronson 260se 182 wanabe owner
Old December 4th 03, 07:09 PM
Montblack
("Dick Meade" wrote)
mod?
Dick, Please post the info here too. I am curious about the 260SE (canard)
182 Peterson conversion.
Here's a 260SE canard question:
High wing Cessna 182.
Canard conversion wing is set up "inches" from the prop. :-)
How does that darn canard work?
I (somewhat) understand a Burt Rutan design - smaller area canard, losses
lift before the larger aft wing, nose drops first, etc.
On this 260SE (Cessna 182) design, doesn't the prop wash do nutty things to
the air over that (very close) canard wing?
Wouldn't the prop'd air, moving over this small canard wing, fool the canard
into thinking it's flying at (maybe) 65k, while the large high wings on a
182 (mostly out of the prop wash) are actually only in the 55k range?
(I just pulled some numbers out of the air)
If the forward canard on the (Cessna 182) 260SE is for extra lift only, then
I guess that Rutan stuff doesn't apply to this design - nose stalls (and
drops) first, etc.
Web page does use this phrase: "stall-resistant attitude"
[Just reread my post]
Maybe the canard wing gets extra lift by being close to the prop. Maybe it
is *supposed* to get extra lift from its placement near the prop. Maybe it's
ALL about extra lift, and nothing about anti-stall. Hmm??]
Montblack
http://lumma.de/mt/archives/bart.gif
Old December 5th 03, 08:11 PM
Dick Meade
"Montblack" wrote in message
(canard)
Detailed questions about canards snipped
Sorry if I mislead you, Montblack. I'm no expert on this conversion. My
info is based on observations of a 260 SE based at my local airport, and a
comparison of that plane to my 182 with a Pponk conversion (520 cu. in, 260
hp), flap and aileron gap seals, and mild droop tips. .
The Peterson conversion is expensive. The aerodynamic clean-ups seem to be
offset by the increased drag of the canard, as there is virtually no
difference in speeds between the planes. Relative climb rates are tough to
quantify, but gut feeling says they are pretty similar. I can peg the VSI
on climb out without doing anything heroic. The 260 may have an edge on
stall speed; I'm not certain. Mine stalls somewhere below 45 mph indicated,
no doubt helped by the gap seals. I can't speak to any change in the 'feel'
of the plane, as I haven't flown the 260.
The canard adds complexity under the cowl. To clarify, I should mention
that the canard is not stationary, it moves in concert with the elevators.
Thus, more pushrods, bellcranks, bearings, etc. I imagine rigging is also
somewhat more complicated. The airflow over the canard (I guess) gives the
plane a unique sound as it goes overhead, lending credence to your thought
about the airflow doing "nutty things".
My plane was (re)built to operate from short fields in Montana, although it
is far from Montana now. That's pretty much the mission of the 260 SE.
It's just 2 different ways to approach the same problem. Supporters from
both camps are almost religious (sorry Jay) in their support of the "best"
solution. Maybe slightly more so for the Petersonites. Both are
improvements to an already very capable aircraft, but the Pponk is
considerably less expensive.
Dick
Old December 4th 03, 10:02 PM
JerryK
I saw about the same numbers when I had a TR182. It is a great plane, but
it is better sized for 3 adults and luggage vs 4 adults and luggage for a
fixed gear 182.
"Michael 182" wrote in message
news:Wpzzb.414152$Tr4.1191400@attbi_s03...
'79 TR-182 150 TAS at 10,000, about 165 at FL180.
I'm thinking of buying a 182 or 182 RG.
I like cessnas and the 182 is such an honest airplane it's hard to beat.
I'd just like it to be a bit faster.
If all of the speed mods are done to a normal C-182 , Good wheel pants,
speed fairings, gap seals etc.....
how fast is it?
For comparision how fast is the C-182 RG or a normall 210? (Not turbo)
Paul
Old December 5th 03, 12:26 AM
Michael 182
Are fixed gear 182's bigger? My TR 182 actually has a bit more storage than
the '67 fixed gear 182 I had before it since the fixed didn't have a shelf
in the baggage compartment.
"JerryK" wrote in message
fixed gear 182.
Old December 5th 03, 02:17 AM
john smith
Later models (Q and R) have the hat shelf.
TR182 lose baggage volume because of the main landing gear stowage.
Old December 5th 03, 02:25 AM
Mike Adams
My 67 182 fixed gear has the Horton speed mods and will do an honest 150 KT
TAS with a higher power setting at lower altitudes. I flight plan 145 KT at
higher altitudes, say 10K, where we're at around 65% and about 11.5 gal/hr.
This airplane has an O470-U, 230 HP. And as stated below, no hat shelf in the
baggage area. Useful load is 1020 lb, with 120 max in the baggage area.
Mike
In article OgQzb.304501$275.1045781@attbi_s53, "Michael 182"
fixed gear 182.
Old December 4th 03, 08:01 PM
Max T, CFI
I used to own a T210--great plane, but I wouldn't recommend a 210 just to get
more speed, unless you need the extra seats and hauling ability, and are willing
to pay the higher insurance rates (6 seats means more potential liability so rates are higher).
The difference in speed probably wouldn't save a lot of time vs. a 182RG on a typical trip.
I'd run it at around 60% power, 13 gph, lean of peak, and it was always 150 kts between 6 and 8000 feet.
We had the Flint tip tanks and Horton STOL, which together probably trimmed a few knots
off of what it might otherwise have flown at.
Max T, MCFI
wrote in message ...
If all of the speed mods are done to a normal C-182 , Good wheel pants, speed fairings, gap seals etc.....
how fast is it?
Paul
