Tiny vacuum pump
Old January 21st 04, 03:44 AM
clare @ snyder.on .ca
On Mon, 19 Jan 2004 17:45:27 -0500, Mike Patterson
On Sat, 17 Jan 2004 19:03:40 GMT, Tom Pappano
Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
110, but I can rig up a 12 volt supply if necessary.
Just get a little "mityVac" hand pump used for testing vac advance etc
on cars.
Or if you really need it mechanized, make an adapter for your vacuum
cleaner with an adjustable bleed
The reason I say this is that I'm getting ready to pack a fairly large number of
bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like
to put each part in a "baggie" (sandwich bag or equivalent) along with a little
preservative oil, and then suck the baggie down with a football needle stuck
into the top closing mechanism just before sealing.
Thoughts?
http://www.rst-engr.com
Those aquarium air pumps pull air from around the case.
How about placing one inside a cheapo tupperware-type container with a
"suck" port mounted on the container, you'd also need to run a "blow"
port from the pump's normal output through the container wall.
HTH
Mike Patterson
Please remove the spamtrap to email me.
Old January 18th 04, 07:54 AM
Phil Sisson, Litchfield Aerobatic Club
Try using warm oil, not hot enough to melt through, roll the air out of
the baggie, seal it and as the oil cools, maybe it will pull it own
vaccuum...
Old January 18th 04, 12:24 PM
James R. Freeman
Jimmy:
Use an old compressor from a freg. I have a high dollar Freon pump but
use the old G.M. compressor more.
"Jim Weir" wrote in message
order
Preferably
number of
I'd like
little
stuck
Thoughts?
Old January 18th 04, 05:36 PM
In rec.aviation.owning Jim Weir wrote:
: Does anybody have an idea on how to make a tiny little vacuum pump on the order
: of an aquarium pump or so that will draw just a few inches of water? Preferably
: 110, but I can rig up a 12 volt supply if necessary.
I've actually got one of these at home. I found it from a pile of
surplus equipment. It doesn't pull much vacuum, but it basically is an
aquarium pump. I'll try to find a model number on it and report back.
-Cory
* The prime directive of Linux: * * - learn what you don't know, * * -
teach what you do. * * (Just my 20 USm$) *
Old January 19th 04, 07:36 PM
Blueskies
Take one of these apart:
http://www.ballsonline.com/details.a...t=136&path=136
then reverse the little flapper valve to make it suck instead of blow...
Dan D.
"Jim Weir" wrote in message ...
Thoughts?
Old January 20th 04, 02:36 AM
GeorgeB
Thoughts?
When I was in college, the chem labs used a venturi on water faucets
to create a vacuum for filtration. I've tried Google to show where to
get them, and failed.
Just a little attachment with a side barbed fitting ... good vacuum
levels, CHEAP, and appropriate for one who utilizes Bernoulli in other
ways ...
now where do I get it?
Old January 20th 04, 04:28 AM
John Ammeter
I built a few of those for a hot tub several years ago.
Being a frugal and saving kind of guy, I've still got most
of them tucked away. Simple construction really and capable
of several inches of mercury.
John
On Mon, 19 Jan 2004 21:36:37 -0500, GeorgeB
Thoughts?
ways ...
Old January 20th 04, 04:56 PM
Ron Natalie
"GeorgeB" wrote in message ...
They sell them at WAL*MART and other pet stores for draining aquariums.
Also had a similar device to drain the waterbed back when those things were
fashionable.
Old January 21st 04, 03:08 AM
Greg Milligan
Check Fisher Scientific under "aspirator".
order
Preferably
Thoughts?
ways ...
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
