"Robert Moore"
As can be seen, Vb, the speed for the maximum gust has nothing to do with Va. How does one find Vb for most of the GA fleet?.....simple...just look for the top of the green arc on the airspeed indicator. By flying at Va during turbulence, one is flying un-necessarily close to stall and a possible upset. At Va, it would take a full, instaneous deflection of the controls to stall the aircraft. How is that un-necessarily close to stall? The aircraft can be loaded to a much higher value with the controls than by a 50 fps gust. Whicih is why it is recommended to fly at Va in turbulent conditions. That is, 1) because a full deflection of the controls, presumably commanded to recover from a turbulence induced upset, will result in a stall instead of a breakup, and 2) incidently because it is conservatively lower than Vb and therefore well within any expected maximum gust. I sense this is going to be a long one... |
"Maule Driver" wrote
At Va, it would take a full, instaneous deflection of the controls to stall the aircraft. How is that un-necessarily close to stall? A gust of sufficient value will also stall the a/c at Va. Whicih is why it is recommended to fly at Va in turbulent conditions. With the FAA saying that Vb is the speed for maximum gust intensity, who do find suggesting otherwise. 2) incidently because it is conservatively lower than Vb and therefore well within any expected maximum gust. This is true, but also closer to a stall I sense this is going to be a long one... Just post the documentation. :-) Bob Moore |
![]() "Robert Moore" wrote in message . 6... "Maule Driver" wrote At Va, it would take a full, instaneous deflection of the controls to stall the aircraft. How is that un-necessarily close to stall? A gust of sufficient value will also stall the a/c at Va. Whicih is why it is recommended to fly at Va in turbulent conditions. With the FAA saying that Vb is the speed for maximum gust intensity, who do find suggesting otherwise. 2) incidently because it is conservatively lower than Vb and therefore well within any expected maximum gust. This is true, but also closer to a stall I sense this is going to be a long one... Just post the documentation. :-) Bob Moore How about you post an example of an airplane with a published Vb that is the same as Vmo (or Vno)? Mike MU-2 |
On Thu, 08 Jan 2004 22:28:48 GMT, Robert Moore
wrote: By flying at Va during turbulence, one is flying un-necessarily close to stall and a possible upset. Which in my plane (SR20) is also 60% power at 50 degrees LOP, my normal cruise (120 IAS) and I am nowhere near stall which is 65 IAS. |
ArtP wrote
Which in my plane (SR20) is also 60% power at 50 degrees LOP, my normal cruise (120 IAS) and I am nowhere near stall which is 65 IAS And I thought that every private pilot was taught that an airplane can be stalled at any airspeed and any attitude. I assure you that I, or a gust of sufficient value can stall your SR20 at 120 kts. Bob Moore |
On Fri, 09 Jan 2004 01:29:05 GMT, Robert Moore
wrote: And I thought that every private pilot was taught that an airplane can be stalled at any airspeed and any attitude. I assure you that I, or a gust of sufficient value can stall your SR20 at 120 kts. By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. I suspect that would fall in the category of sever turbulence and I don't think there is any airspeed that would be safe under those conditions in a single engine normal category aircraft. In any case a stall at cruise altitude should not be a problem but parts (like the engine or the wings) falling off the aircraft would be. |
ArtP wrote
By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. That's not the type of gust being discussed, try "vertical" gust. Bob Moore |
ArtP wrote:
By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. Arrrgghhhh! No, that's not what's going on at all. You stall when you exceed the critial angle of attack. One way to do that is to slowly reduce airspeed under 1g conditions (i.e. straight and level flight in non-turbulent air) until you reach Vs. At Vs and 1g, the wing has to be operating at the critical AOA to generate lift equal to the plane's weight, so you stall. This is your standard private pilot power-off stall demo. But, there are many other ways to reach critical AOA. One way is to instantaneously change the direction the relative wind is coming from. Let's say you're in straight and level flight at 120 KTAS. That's just about 200 ft/s (feet per second). I'm going to pull two plausable numbers out of my butt for the sake of argument: 1) At 120 KTAS, 1g, and whatever you weigh at the moment, the wing is operating at an AOA of 5 degrees. 2) The critial AOA for your wing is 18 degrees. The relative wind is coming from straight ahead and the wing is tilted up at an angle of 5 degrees from the horizontal. This gives you your 5 degree AOA. NOTE: this doesn't mean your nose is pitched up 5 degrees, because the wing has a built-in angle of incidence, i.e. the chord line of the wing is not parallel with the longitudinal axis of the plane. Now, let's say you hit a vertical gust of 50 ft/s. That means the relative wind is now 200 ft/sec straight back plus 50 ft/sec up. If I did my vector sums right, that means it's now 206 ft/sec coming from an angle of 14 degrees below the horizontal. Since your wing is tilted up at 5 degrees, the AOA is suddenly 5 + 14 = 19 degrees, which is greater than the critical AOA. Presto, you are suddenly stalled! If the gust were just a little bit weaker, you would only reach an AOA of, say, 17 degrees. This is below the critcial AOA so you're not stalled. But, the AOA has suddenly gone up by a factor of 3.4. Since you're still going at the same airspeed (actually, a little bit more, 206 instead of 200 ft/s), you're suddenly generating 3.4 times as much lift, and you will find yourself being accelerated upward at 3.4 g's, which is enough to make your socks droop down around your ankles. Well endowed men or women will be wishing they had worn more supportive underwear about now. But, since your wings were probably designed to withstand 3.8 g's (plus 150% safety factor), they should stay on and not even get bent or wrinkled. Here's the mantra; repeat after me: "Stall is when you exceed the critial AOA. You can do this in any flight attitude, at any airspeed" |
ArtP wrote:
By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. Wings don't stall because of a lack of airspeed. Hilton |
Druine Turbulent | Stealth Pilot | Home Built | 0 | August 30th 04 05:05 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
