On Fri, 09 Jan 2004 01:29:05 GMT, Robert Moore
wrote: And I thought that every private pilot was taught that an airplane can be stalled at any airspeed and any attitude. I assure you that I, or a gust of sufficient value can stall your SR20 at 120 kts. By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. I suspect that would fall in the category of sever turbulence and I don't think there is any airspeed that would be safe under those conditions in a single engine normal category aircraft. In any case a stall at cruise altitude should not be a problem but parts (like the engine or the wings) falling off the aircraft would be. |
Art..
With all due respect.. you really need to go and review the section on angle of attack and accelerated stalls.. I've been able to intentionally stall a light (ASEL) aircraft in smooth air at Va.. its called a steep turn with extra back pressure. It has nothing to do with "tailwind gusts".. it has EVERYTHING to do with angle of attack. Dave ArtP wrote: On Fri, 09 Jan 2004 01:29:05 GMT, Robert Moore wrote: And I thought that every private pilot was taught that an airplane can be stalled at any airspeed and any attitude. I assure you that I, or a gust of sufficient value can stall your SR20 at 120 kts. By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. I suspect that would fall in the category of sever turbulence and I don't think there is any airspeed that would be safe under those conditions in a single engine normal category aircraft. In any case a stall at cruise altitude should not be a problem but parts (like the engine or the wings) falling off the aircraft would be. |
"Doug"
Va - The maneuvering speed. This is the maxiumu speed at a particular weight at which the controls may be fully deflected without overstressing the airplane. Now, Va is commonly taught as turbulent air penetration speed. But nowhere in the definition does it say that Va will protect the airframe from damage due to turbulence. Does slowing down even slower than Va protect the airframe from even more severe turbulence? Or is Va the best speed for turbulence penetration? Or is Va just used as a turbulence air penetration speed becauase of tradition or some other non-technically correct reason. There should be no reason to go slower than Va for turbulence penetration. The case is made later in this thread for using the faster Vb for such conditions (I disagree but can be convinced). However, one point that is often overlooked is that the published Va is usally/always stated for max gross weight. At lesser weights, Va is lower and can be significantly lower. Va isn't marked on the airspeed indicator but it is an indicated airspeed. |
Kershner's "The Advanced Pilot's Flight Manual" has the following
definition for Va. Va - The maneuvering speed. This is the maxiumum speed at a particular weight at which the controls may be fully deflected without overstressing the airplane. Note that this definition DOES NOT say that the airplane will stall before it breaks due to turbulence. Now, Va is commonly taught as turbulent air penetration speed. But nowhere in the definition does it say that Va will protect the airframe from damage due to turbulence. Does slowing down even slower than Va protect the airframe from even more severe turbulence? Or is Va the best speed for turbulence penetration? Or is Va just used as a turbulence air penetration speed becauase of tradition or some other non-technically correct reason. |
The desired effect is to have the airfoil stall before breaking but at the
same time that the pilot not lose control. Gusts may increase indicated airspeeds and consequently produce more stress on the airplane, so from this standpoint slower is always better. On the issue of controlablity, faster is better. Vb is the speed that is supposed to provide the best compromise. There was an article in Business and Commercial Aviation a few years ago that had a comprehensive explanation but I no longer have the issue. I seem to recall that for swept wing jets Vb is greater than Va and may even be greater than normal cruise. Of course jets are also concerned with mach exceedances and upsets so the issue is more complicated for them Mike MU-2 "Doug" wrote in message om... Kershner's "The Advanced Pilot's Flight Manual" has the following definition for Va. Va - The maneuvering speed. This is the maxiumum speed at a particular weight at which the controls may be fully deflected without overstressing the airplane. Note that this definition DOES NOT say that the airplane will stall before it breaks due to turbulence. Now, Va is commonly taught as turbulent air penetration speed. But nowhere in the definition does it say that Va will protect the airframe from damage due to turbulence. Does slowing down even slower than Va protect the airframe from even more severe turbulence? Or is Va the best speed for turbulence penetration? Or is Va just used as a turbulence air penetration speed becauase of tradition or some other non-technically correct reason. |
Roger Halstead wrote
IF you are cruising at Va and encounter a vertical gust that causes a stall right at the design limit you survive. What happens when you hit a vertical gust of twice the velocity of the first? According to the ABS and Airsafety Foundation, you are going to break your airplane. Again referencing a couple of previous posts: ------------------------------------------------------- Quoted from Aerodynamics for Naval Aviators: "As a general requirement, all airplanes must be capable of withstanding an approximate effective +/- 30 foot per second gust when at maximum level flight speed for normal rated power. Such a gust intensity has relatively low frequency of occurrence in ordinary flying operations. The highest reasonable gust velocity that may be anticipated is an actual veritical velocity, U, of 50 feet per second." ------------------------------------------------------- And from FAR 23 Section 23.333: Flight envelope (c) Gust envelope. (1) The airplane is assumed to be subjected to symmetrical vertical gusts in level flight. The resulting limit load factors must correspond to the conditions determined as follows: (i) Positive (up) and negative (down) gusts of 50 f.p.s. at VC must be considered......... (ii) Positive and negative gusts of 25 f.p.s. at VD must be considered........... -------------------------------------------------------- Now since 50 fps is the highest reasonable gust that may be anticipated, and all aircraft are designed to withstand this gust all the way up to Vc, what causes the wings to come off? As Dana has posted: VFR pilot entering IMC and losing control. He pops out of the overcast at 400 feet in a screaming spiral dive, and promptly pulls up hard. The stabilizer fails downward, then the airplane pitches forward onto its back and the wings fail downward (negative Gs). Yes, I understand that older aircraft may have been certificated to only a 30 fps gust value, but as pointed out in AFNA above, that will be encountered very infrequently and in my opinion, never outside of a thunderstorm. In fact, the aiframe must withstand the 25 fps gust (not far from 30 fps) all the way to the maximum demonstrated dive speed. The aircraft is already designed for the maximum anticipated gust. There is no gust "twice the velocity" for which the aircraft is designed. Is there some reason that you don't copy/paste or at least provide a url for the material that you have referenced? Who is (are) the ABS and what engineering credentials are possesed by members of the AOPA's Airsafety Foundation? Bob Moore |
Ok... all you closet aeronautical engineers... I'm asking for someone to
help do my work for me.. with regards to Va.. I have an Excel Spreadsheet application that does W&B and plots it on a graph... The form also lists certain speeds that are "static": Vx/Vy, Vne, etc.. I would like to modify this form to list Va dependent on the given calculated gross weight, and perhaps even doctor it up to do density altitude computations.. If anyone HAS or KNOWS (or has the formulas)how to do this in Excel, please feel free to pass it on.. I'm sure I will figure out or find what I need sooner or later, but I'm not wanting to reinvent the wheel if I dont have to.. this is for myself and some flying club members (and for anyone else who happens to see it on here).. not a school project or work assignment of any kind. Dave PP-ASEL Doug wrote: Kershner's "The Advanced Pilot's Flight Manual" has the following definition for Va. Va - The maneuvering speed. This is the maxiumu speed at a particular weight at which the controls may be fully deflected without overstressing the airplane. Now, Va is commonly taught as turbulent air penetration speed. But nowhere in the definition does it say that Va will protect the airframe from damage due to turbulence. Does slowing down even slower than Va protect the airframe from even more severe turbulence? Or is Va the best speed for turbulence penetration? Or is Va just used as a turbulence air penetration speed becauase of tradition or some other non-technically correct reason. |
Dave S wrote:
I have an Excel Spreadsheet application that does W&B and plots it on a graph... The form also lists certain speeds that are "static": Vx/Vy, Vne, etc.. I would like to modify this form to list Va dependent on the given calculated gross weight Easy. Va as published is for max gross weight, and goes down with the square root of weight. So: MGW = Max Gross Weight W = Weight of the aircraft at a given moment Va = Maneuvering speed as published in the POH Va,w = Maneuvering speed for a given weight Va,w = Va * sqrt (W / MGW) Stall speeds (Vs0 and Vs1) both follow the same formula, and so does your final approach speed, which is usually calculated as 1.3 * Vs0. So, if you really want to do landings right, you should calculate your weight at the end of the flight (taking into account fuel burn), calculate a Vs0 based on that, and multiply by 1.3 to get your proper final approach speed (keeping in mind that the multiplication needs to be done in CAS, not IAS). It turns out that for the majority of light airplanes, the difference between max gross and a reasonable minimum landing weight (pilot and minimum fuel) is a small enough percentage of max gross that stall speed only varies a few knots between the upper and lower limits. As a result, most people don't bother with this (nor is it often taught in a private pilot course), and they never have a problem. On a bigger plane where half the takeoff weight can be fuel, it's a much more significant issue and these calculations are done for every takeoff and landing. If you were really paranoid, you could calculate Vfinal and Va for three loadings: pilot and minimum fuel, max gross, and halfway in between, then keep these on your cheat sheet. In flight, just take a WAG which of those you are closest to and use the appropriate number. |
Druine Turbulent | Stealth Pilot | Home Built | 0 | August 30th 04 05:05 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
