Building chasing airport lights -- Attn: Jim Weir?
Old January 23rd 04, 03:08 AM
Tom Pappano
Jim Weir wrote:
I missed the original post on this one...can anybody repost it for me?
And to those of you who want to use microcontrollers and fancy
logic...THWPPTTTTT. One fifty cent CMOS chip and a fe bipolar transistor
drivers will do just fine, thank you.
http://www.rst-engr.com
Basically, Jay wants to implement a "rabbit" in his hotel
with some small bulbs in the ceiling.
Well, ok but the little mcu I'm thinking of will run at 8 mips,
needs no xtal, has 16 i/o lines, has an 8 chan 10 bit a/d,
2 high speed pwm channels, timers, power supply monitoring,
is a 20 pin dip, costs $1.50,
can be programmed "in situ", and will support high level
language!
Even for really simple devices, it seems the days of
discrete logic are over! 8-)
(Not to mention the relative ease of making changes in
software vs. hardware)
Tom Pappano, PP-ASEL-IA
Old January 23rd 04, 04:21 AM
Jay Honeck
language!
You call this "relative ease," Tom? I don't even know what the hell you're
talking about!
Tell you what -- you build this thing, and when you bring it to Iowa City,
your night in any suite (whichever era you prefer) is free!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 23rd 04, 05:05 AM
Jim Weir
WAIT A MINNITT...
I just told them how to do it. Somebody said they can follow my plans and they
can do it.
And you give THEM a free room?
What is wrong with this picture?
"Jay Honeck"
-Tell you what -- you build this thing, and when you bring it to Iowa City,
-your night in any suite (whichever era you prefer) is free!
Old January 23rd 04, 06:03 AM
Tom Pappano
language!
talking about!
Whoo Hoo! Methinks I'll have to take you up on that! If you would,
drop me an email with the Radio Shack part# of the lamps you bought
so I can check one out, and we can work out some technical details
of the MRALS configuration.
Old January 23rd 04, 03:35 AM
Roy Smith
language!
Sounds cool. Is that price for Qty 1? Got a part number?
Old January 23rd 04, 07:00 PM
Tom Pappano
language!
Hi Roy,
This particular one is an Atmel ATTINY26, 1pc $2.58 from
Digi-Key. Much less in quantity from more major suppliers.
Atmel has a large family of these things in 8 pin to 64
pin packages, with internal flash memory from 1 to 128k.
They call them "AVR" RISC controllers. Atmel provides free
development software, really cheap development and programming
hardware, and freeware "C" compiler suites are available that
support the devices and the programmers. These things are
much faster while requiring less power than 8031 products.
They can be programmed "in system" so the devices do not need
to be socketed to allow program development or upgrading.
Check them out at www.atmel.com
Old January 22nd 04, 06:01 PM
Ray Andraka
Jay,
There are inexpensive christmas light sequencers available. They generally use
3 circuits with every third bulb on the same circuit. I had one a few years ago
that had a switch to select chase, random or all on, and a knob to vary the
rate. Cost no more than 3 or 4 bucks and came with the lights.
That is a little bit different than the rabbit, which has only one light on at a
time, so it may not achieve the effect you are looking for. A possible low
tech solution would be a motor driving a cam that closes a series of
microswitches in sequence...easy enough to produce by someone with a little bit
of mechanical talent and not much electrical know-how. A higher tech solution
would be to use electronics consisting of a programable logic device and a set
of solid state switches to switch the current. Could also be done with a
computer with a relay card plugged into it, but would need a little bit of
programming to make it work (such relay cards are available from electronics
firms like Jameco). The computer solution would be a bit of overkill, but could
be done with off the shelf stuff.
Jay Honeck wrote:
Today a pilot-guest had the coolest idea for the side-entrance to our lobby:
"Chasing" lights recessed in the drop-ceiling tiles, leading to the main
lobby area, that look just like the "rabbit" lights that lead to the
approach end of a runway!
(Background: Over half of our guests come in the "wrong" door to our lobby,
which leads more directly to the pilot's lounge than to the reservation
desk. As a result, we've often got people milling around looking "lost" in
the pilot's lounge. These chasing lights would "lead" them to the correct
area, and be really cool looking, too.)
So, I stopped at the local Rat Shack, and found the perfect little 12 volt
blue lights, 1/2 inch in diameter. (Blue would be a bit toned-down from
white strobes!) It would be a simple matter to drill 1/2 inch holes in the
ceiling tiles, every 12 inches or so, and push them through the tiles from
above so that only the blue "dome" was sticking out through the hole. I
think 12 volt lighting would be safer in the ceiling than 120 volt Christmas
lights, as a couple of people have suggested...
Here's the problem: How to sequence them? The guys at Radio Shack had NO
advice at all -- they were all stumped. The lights should flash
sequentially pretty fast, but I think they'd look pretty stupid if they
weren't coordinated properly. I'd also want to incorporate a motion
detector on/off switch, so that they weren't running all the time.
Anyone got any ideas? Are there affordable electronic "sequencers"
available? Is this something RST Engineering could build for me, Jim?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old January 23rd 04, 09:46 PM
Maurice Givens
Ray, I'm shocked!! 1 timer, 2 16-bit shift registers, and 32 LED's
Maurice
Ray Andraka wrote in message ...
Jay,
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
--Ray Andraka, P.E.
email
Old January 23rd 04, 11:26 PM
Ray Andraka
I was basically thinking of that very circuit in a small PLD (you wield a hammer long
enough and everything starts to look like a nail). You also need at least an inverter to
realize a counter. For one light on at a time, which I think is what the 'rabbit' does,
you'd need a little bit more, especially if you wanted it to recover should it hiccup. A
johnson counter (last register output inverted and fed back to the first) would make the
all the lights go on in sequence before any started going off. So, to your timer and
shift registers, add a package with a gate. For the cost and circuit board complexity,
you'd probably come out ahead using a small PLD (there are several in the $1-2 range that
would suffice) , assuming you had a way to program it. You could also use a 4 bit
counter, timer and 16 line decoder (7493, 74154 and 555). 16 Leds is probaby enough for a
Rabbit, I think most only have about 10 strobes. I'd be tempted to use white LEDs.
In any event, since he was asking, I presumed that working with logic chips was probably
beyond his capability, so I was trying to come up with solutions that would not require
any logic design. (I guess that means a CPLD would be even further out of reach of
course).
If he could live with orange lights(or perhaps green if you can still find the green neon
lamps), you could also do it with NE-2 bulbs and resistor and capacitor for each bulb. It
is a ladder network of relaxation oscillators that depends on the neon lamp's high off
resistance and low on resistance to make it flash, and the ladder network makes them flash
in sequence.
Maurice
Jay,
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
--Ray Andraka, P.E.
email
--Ray Andraka, P.E.
email
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
