Nice Surprize During Pre Flight, And A Few Odd Questions
Old March 23rd 04, 02:04 AM
MRQB
Went in to the mechanic this morning it was not any thing major no parts
needed he just took some slack out of the cable's and made sure it was
strait. boy can I feel a difference in the rudder peddles nice and firm no
major slop. Every thing is all bolted, pined and safety wired back together
& working great. We even go the ARC RT-308 radio to come out.
"One's Too Many" wrote in message
om...
"MRQB" wrote in message
The airplane I just bought gave me a nice little surprise went out to do
my
pre flight and noticed that my right rudder cable had some slop in it I
did
not feel comfortable flying it with the lack of tension on it so the
mechanic is going to look at it tomorrow. Also what holds tension on the
rudder cables? I know the cost of a new cable is only $80.00 + labor. Is
there any source on the net ware I can find out how the cable system
works
on a later model Cessna 150M kinda curious and would like to know my
airplane inside and out. Ware do I find me a factory service manual? I
want
to learn every thing about this little 150.
Every 150 I ever flew seems to have a lot of "slop" in the rudder
cables when sitting on the ground. It's usually due to the way the
nosewheel steering is spring-linked to the rudder controls, and the
nosewheel not being centered when the plane was parked. Twist the
nosewheel so it's pointing straight ahead and see if your "slop"
disappears. Even our 172 does this, but the phenominon doesn't seem so
pronounced as on the 150.
Old March 24th 04, 11:00 PM
Dan Thomas
"MRQB" wrote in message ...
Let us know how it flies. If the mechanic doesn't follow the
rigging procedure laid out in the maintenance manual, the airplane
might pull to one side or the other. The centering device for the
Cessna 150's (and 172's) rudder system is the nosewheel centering cam.
It forces the nosewheel to a straight-ahead position when the aircraft
is off the ground, and if the rudder cables aren't adjusted with the
nosewheel off the floor the rudder might not be centered in flight.
That centering system is why the nosewheel steering in one of these
airplanes is so springy and imprecise; the steering rods have internal
springs to allow rudder movement when the nosewheel is locked.
Every used Cessna we have bought and put into service has had
misrigged flight controls. Rudder, aileron, elevator, everything.
Maintenance manuals are expensive, so many shops don't have them and
don't seem to know the proper order of adjustment.
And as Dale Falk pointed out, a broken rudder pedal return spring
can leave cables slack. It'll also make the airplane pull to one side.
Check your rudder stops to see if they are the new, large types.
The older ones can get caught behind the rudder stop bolt head and
lock the rudder full over, especially if hinges are worn. In Canada we
had an AD to force installation of the new stops to prevent this after
a 150 crashed and killed an instructor and student. They had been
practicing spins and spin recoveries, and on the last spin the rudder
locked. If you can't stop the spin, you can't get the nose down to
break the stall.
Dan
Old March 24th 04, 11:26 PM
MRQB
That's why I want a maintance manual so when they do things I can verify for
my self that they have been done with the manufactures guidelines was going
to go fly today but we are getting thunder storms and hail.
"Dan Thomas" wrote in message
om...
no
together
break the stall.
Dan
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
