Garmin 296 and FliteStar
Old June 17th 04, 03:15 PM
Rich Raine
You have to buy the Garmin Serial cable for $38. However this will still
not work properly with Flitestar/Flitemap. It will upload a route from
Flitestar but it will not substitute the waypoints with the actual items.
In other words if you plan a route KFOK-CCC-KHTO you will find is has
uploaded those custom user waypoints that will apprear over the airports and
vor. This of course makes the upload worthless. The Garmin 295 would
upload perfectly, leading me to think they have changed something in the
protocol with the 296.
Because the interaction between these two tools is some important, I have
been sending emails and calling each manufacturer attempting to see if there
is a resolution. Each one says its the other ones fault. Because this
formerly worked fine with the 295 I assume the problem is with the 296.
It sure would be nice if there was more competition in this arena.
Rich Raine
remove ----- for email
www.eRaine.com
"Bill Padley" wrote in message
Dave..
I didnt explain well..g
There was a thread here previously to say that Flitestar did not work well
with USB gps connections, only serial ..A serial to USB converter
(theIOGEAR) was recommended ..all good so far...
However garmins output from the 296 is on a very small connector (like a
camera firewire connector) -on the other end is a usb plug ..how can the
serial to USB converter be used when there is no serial connector on the
garmin?
How does the serial to usb converter actually get to the garmin?
that was my question...I believe some people have it working with
Flitestar
, but I have no idea how!
cheers
Bill Padley
london
"Dave Butler" wrote in message
Bill Padley wrote:
I have just received my Garmin 296 , and also have the IOgear usb to
serial
adapter
However , the cable provided by Garmin is a small connector on one end
and
a usb on the other..the usb to serial adapter is expecting a the
serial
end
to be plugged ito the GPS, which of course it cant...(no serial female
socket)
I didn't quite follow that description, but if what you need is a serial
gender-changer, they are quite inexpensive and available. Check your
local
computer supply store.
