Engine Analyzers
Old June 4th 04, 03:15 PM
M.E. Borner
Default Engine Analyzers
I am seriously thinking about installing an Engine Analyzer in my
plane and am looking at options. I think I have narrowed the choice to
J.P. Instruments or Electronics International. My mechanic has more
experience with JPI and feels their probes have a longer life. My
research has me leaning slightly towards EI for price, function and
design features. Really I am on the fence and am looking for something
substantive to sway me. If it matters, this will be installed in a
1999 Seneca V with Continental TSIO-360-RB (220HP Turbocharged)
engines. Does anyone have any experience, recommendations or
suggestions? Maybe I should do 1 of each (just kidding).
Old June 4th 04, 03:38 PM
Dave Butler
I don't have a dog in this fight, but there's this:
http://home.earthlink.net/~timrv6a/jpi.html
Dave
Remove SHIRT to reply directly.
Old June 4th 04, 04:10 PM
MikeM
I put a EI UBG-16 in my Skylane in 2000. (6 chts, 6 egts, oil temp,
bus voltage, alternator load current). Works great, no problems with
probes.
Biggest technical challenge was getting the brightness of the display
to track the main dimmer bus.
It sure shows what a ****TY job Cessna did when they "designed" the
cowling/baffling in my L model Skylane. I have improved the cht
balance greatly with some added baffling. Front two chts are still
40 deg F colder than the back four.
It also shows how POOR the mass-flow balance between the front and
rear cyclinders is on the Continental O470R. Due to the brain-dead
induction plumbing, the front two cyl get much less fuel/air than the
other four.
MikeM
Skylane '1MM
Old June 4th 04, 05:09 PM
Kyler Laird
That's what convinced me to get a GEM (Insight). I've been quite
happy with it.
*Do* get an engine analyzer. They're a good investment. My plane
just came out of annual when I flew it to PJY last month. On the
descent, I noticed that both temps on one of my cylinders had
dropped.
With some great help from Michael, I learned that both plugs had
fouled. I'm sure I wouldn't have noticed it without the analyzer.
--kyler
Old June 4th 04, 06:06 PM
Michelle P
Hi,
I have had a Insight GEM in my Maule for the past nine years. no
problems with the unit. It did help me locate a bridged plug quickly though.
Michelle
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old June 4th 04, 07:49 PM
Dan Luke
suggestions?
My JPI EDM-700 has been flawless for the 18 mos. it's been in the
airplane. It has the fuel flow option which I highly recommend. An
engine analyzer is a great trouble shooting and mixture setting tool;
I'd hate to do without one now.
Dan
C172RG at BFM
Old June 4th 04, 08:45 PM
Victor J. Osborne, Jr.
Had both (now have EDM JPI-700.) Check out JPI's new series (legal
replacement for steam gauges in a few planes.) I like the operation of the
JPI better. User interface seems better to me, FWIW.
Had good support with both. Although, I did have to replace two probes from
the EI.
If you need (or plan) a block heater, get this sorted out beforehand. The
EI or JPI probes will need to co-exist with the CHT/heater probes. For this
reason I have a Reiff system (bands, no probes)
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
take off my shoes to reply
Old June 4th 04, 09:11 PM
Ray Andraka
If you put LASAR ignition on, you'll also need to share the probe port with the
CHT probe for the LASAR controller, as well as if you have a factory CHT, you
may need to keep that in it's probe well.
the EI.
Thx, {|;-)
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old June 4th 04, 10:38 PM
jls
"Victor J. Osborne, Jr." wrote in message
from
the EI.
this
Thx, {|;-)
Thanks for your input and I like JPI too. But, what I need costs over
$5,000 and that's a little hefty when you consider that Rocky Mountain
Instruments, a very reputable company with a good track record, provides
quality monitoring for much less money. Of course, the system I would be
purchasing is for an experimental.
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
