![]() "Ray Andraka" wrote in message ... I'm very happy with my Reiff System. I've had it on my Six since 1997. Made it easy to add the JPI EDM700 last summer...all the CHT wells were still open. The heaters will get teh engine up to around 50 deg in a few hours with just cowl plugs on. Tom Sixkiller wrote: reason I have a Reiff system (bands, no probes) How's that Reiff system worked for you? I'm about to go from needing extra cooling baffles (Arizona) to a engine heater (Colo. Springs). My F33A already has an JPI-700. What are your temperatures like during winter? Though the plane will be hangared (non-heated, but with 120V power), the Springs can get down well below zero. I was wondering if a thermal blanket of soe sort would help (ie, what kind? I'm sure one of my wife quilts would not be appropriate, for various reasons). Thanks, Tom |
Typically it goes down to the mid teens. An insulated cover improves things (I
have an insulated cowl cover, but usually don't use it). The prop is a huge heat sink too, and should also be insulated if you are leaving the heater plugged in all the time. Tom Sixkiller wrote: "Ray Andraka" wrote in message ... I'm very happy with my Reiff System. I've had it on my Six since 1997. Made it easy to add the JPI EDM700 last summer...all the CHT wells were still open. The heaters will get teh engine up to around 50 deg in a few hours with just cowl plugs on. Tom Sixkiller wrote: reason I have a Reiff system (bands, no probes) How's that Reiff system worked for you? I'm about to go from needing extra cooling baffles (Arizona) to a engine heater (Colo. Springs). My F33A already has an JPI-700. What are your temperatures like during winter? Though the plane will be hangared (non-heated, but with 120V power), the Springs can get down well below zero. I was wondering if a thermal blanket of soe sort would help (ie, what kind? I'm sure one of my wife quilts would not be appropriate, for various reasons). Thanks, Tom -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Ditto the voltage and fuel flow. FF works great with a GPS although you may
have to bump the fuel flow (pressure) because of the restriction of the transducer. My fuel flow when from 25+ at sea level to 22. After adjusting the pressure, we were back to good flow at takeoff and climb. The voltage is redundant with a panel gauge but the alarm feature lets you know if the alternator drops off. You will quickly add the JPI to your normal scan. -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
"Victor J. Osborne, Jr." wrote in message ...
Ditto the voltage and fuel flow. FF works great with a GPS although you may have to bump the fuel flow (pressure) because of the restriction of the transducer. My fuel flow when from 25+ at sea level to 22. After adjusting the pressure, we were back to good flow at takeoff and climb. The voltage is redundant with a panel gauge but the alarm feature lets you know if the alternator drops off. You will quickly add the JPI to your normal scan. I plugged my EDM into my voice annunicator. That way if the EDM thinks anything is wrong the annunicator says, "Check engine monitor". I didn't have any noticable change in pressure with the transducer but I fly a Mooney and sip my gas slowly. ![]() -Robert |
![]() "M.E. Borner" wrote in message om... I am seriously thinking about installing an Engine Analyzer in my plane and am looking at options. I think I have narrowed the choice to J.P. Instruments or Electronics International. My mechanic has more experience with JPI and feels their probes have a longer life. My research has me leaning slightly towards EI for price, function and design features. I have an EDM-760 and am quite happy with the unit. When you do your brand comparision be sure you are comparing apples to apples. Ensure both units have memory and the same probe sets. Also, shopping at a show such as Oshkosh can save a lot of money. I got my unit for 60% of the list price by going between vendors and seeing if they could beat the other guy's price. I ended up buy from Pacific Coast Avionics, whom I highly recommend. At Oshkosh, JPI was also throwing in free additional probes. I got sets for oil, TIT, and a second TIT readings. When you get the unit make a habit of dumping and analyzing the memory. If you know what you are doing you can see things like exhaust valves and plugs going bad many hours (and dollars) before they make their appearance known. jerry |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
Engine... Overhaul? / Replace? advice please | text news | Owning | 11 | February 17th 04 04:44 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
