taxi in reverse?
Old February 6th 04, 03:08 AM
Ernest Christley
arcwi wrote:
What one should use is to replace the front weel hub wtih a hub-motor
http://www.goldenmotor.com/ .
I am sure that this would not add that much weight and if the hub-motor is
selected corectly, the original tyre used, one could not distinguish it form
original.
Now, I wander if this could be installed on a certified aicraft with some
field approval as a minor modification...
The largest one is 500W, a little less than 1Hp. (Is that right?) Just
barely enough power to push a light aircraft out of the hanger? Now how
much does it weigh (along with the 500W voltage converter to go from 12
to 36V)?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Things you don't want to hear on a taxi test. Dave Hyde Home Built 18 December 11th 03 08:36 PM
Reverse NACA duct Chris W Home Built 22 October 28th 03 10:59 PM
