Complex / High Performance / Low Performance
Old June 29th 04, 02:46 PM
EDR
In article , R.T. wrote:
For my needs a decent payload is going to be important, so I am considering
purchasing a 182 or possibly a Cherokee 6 (which would suit me even better).
Any opinions on either of these aircraft good or bad would be appreciated.
Six seats vice four seats gives you more flexibility, leg room and
cargo space.
The Cherokee Six has a ten knot speed advantage in cruise (135 kts vice
125 kts).
For off airport/non-paved surface operations, the 182 will be less
succeptible to FOD damage (high wing and higher horizontal stabilizer)
Typical Cessna vice Piper arguements:
High wing vice low wing
Both have two doors, in this case!
I fly both and I think the 182 will get in and out of shorter fields.
Then again, the Cherokee Six has 300 higher gross (3400 lbs vice 3100
lbs)
The 1978 Cherokee Six has 84 gallons usable
The 1986 Cessna 182R has 88 gallons usable
The Cherokee Six consumes 16 gph in cruise
The 182 consumes 12 gph in cruise
My observations and experiences.
Old June 29th 04, 06:09 PM
Newps
"EDR" wrote in message
Especially as you run your wings thru the bushes as you taxi in on some two
track road to a cabin. The 182 lets you skim thru the tops, the Cherokee
make you tear up the wing.
lbs)
Gross is irrelavant. You want the lowest gross available with the highest
HP available. What you really want is the highest useful load. That 3100
gross 182 is a dog. I have a 182 with a 2800 gross which will vastly
outperform a newer 182 with the higher gross weights. Has to. Same
horsepower lifting less weight.
Old July 6th 04, 08:04 AM
R.T.
Thanks for all your insights. I test flew a 182 last week and I'm hoping to
get up in a six this week.
RT
considering
better).
appreciated.
cargo space.
125 kts).
lbs)
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
High Performance Single Engine Choices O. Sami Saydjari Owning 82 January 6th 04 07:32 PM
More on High Performance Insurance Jay Honeck Owning 25 December 15th 03 03:24 AM
High performance homebuilt in the UK NigelPocock Home Built 0 August 18th 03 08:35 PM
FAR:Safety Pilot & High Performance/Complex? Jim General Aviation 51 August 18th 03 03:08 PM
