"Michael" wrote in message om... I think you're dramatically different from experienced IFR pilots on the Gulf Coast. I suspect you're no different from the pilots in your neck of the woods. All the Gulf Coast IFR pilots I know who have equipment and experience comparable to mine have spherics and use it agressively. Do you think this is a function of the weather patterns in our geographic areas (i.e. scattered airmass storms vs. frontal storms)? In other words, if you were to move to Pennsylvania do you think you would retain more or less the same summer utilization of your airplane? My guess is that your thunderstorm philosophy would shift to that of Northeast pilots while you were flying here. I think part of this relates though to a definition of "cancelling" a flight. I fly to Florida fairly often and I do not think I have ever had to cancel a morning flight, yet more than once I have diverted somewhere due to afternoon thunderstorms. When I have had to divert and then I do some hangar flying with local pilots, usually the reply is, "You know down here you have to plan to get your flying done by 2PM" -- I've heard that from newly minted private pilots and from CFIIs who are "local" in Florida. Even in Pennsylvania I guess we need to consider what it means to "cancel" a flight. Earlier this week I returned from Mackinac Island Michigan to my home base in Western Pennsylvania with a stop in Eastern Ohio to drop off a passenger. There were thunderstorms enroute over the Great Lakes but I was able to use my radar/spherics/datalink to reroute myself about 50 miles out of the way on the first leg, thus completing the segment to Ohio by about 2PM. Yet by the time I was ready to complete the final 100-mile segment home there were storms building enroute and near by destination as the trailing edge of a frontal system. I "canceled" the flight until the following AM, although I suppose I could have just "delayed" it until 11PM when the storms had cleared -- clearly departing in the afternoon was not an option because it turned out that a group of cells was right over my departure airport between 6PM and 9PM. So I think in part it depends on our definition of "cancelling" a flight. If I lived in Florida and never "scheduled" a flight from 2PM to 8PM, then I guess I might never "cancel" a flight in Florida. -------------------- Richard Kaplan, CFII www.flyimc.com |
Andrew Gideon wrote:
But it does have me wondering. The system would not be "known icing" compliant. So...what difference in utilization would it make? I'm curious what others - esp. that fly with de-ice - would reply. Andrew, I am flying a Bonanza with a "not known icing" TKS system out of Syracuse, NY. From what I understand about the system, the difference between the not known icing and the known icing TKS system has to do with redundancy, not functionality. In other words, known ice TKS system has a backup pump and, IIRC, requires backup electrical. During flights this past winter when I have encountered unplanned ice, the system was extremely effective. -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
"Peter R." wrote in message
... Andrew, I am flying a Bonanza with a "not known icing" TKS system out of Syracuse, NY. From what I understand about the system, the difference between the not known icing and the known icing TKS system has to do with redundancy, not functionality. There may be functional differences, in that known-ice certification requires a laundry list of protected surfaces (in addition to the redundancy requirements), some of which may not be included in a "not known-ice" certification. Some "non known-ice" installations meet all the requirements except redundancy, but many do not. That said, I'm not aware of any de-ice system on a single-engine piston aircraft, known-ice or not, that is suitable for allowing a flight to be made into reported non-trace icing. All of the systems should be used as a "get out of jail free" card, to allow a pilot to take the plane out of the icing with less hazard than would otherwise be had. From what I understand, even on many (all?) light twins, the same is true. Of course, that's not to say that a de-ice system wouldn't translate into a higher wintertime dispatch rate. Just that pilots should be careful to not think that having de-ice on their airplane means they can just cruise along ignoring existing icing conditions. Pete |
No de-icing system allows a pilot to continue flight in icing conditions
when encountered...they provide a safety margin while escaping from the conditions. The exposure to icing required for known-icing certification doesn't amount to much...Appendix C to Part 25 (which applies to Part 23 by reference) requires quite a bit of interpretation, but for convective clouds it is something like 3.8 miles and for stratus clouds it is something like 17 miles. If the droplets are larger than 40 microns or you stay in the clouds longer than the distances laid out in the reg, you have exceeded the known icing requirements and are on your own. Bob Gardner "Peter Duniho" wrote in message ... "Peter R." wrote in message ... Andrew, I am flying a Bonanza with a "not known icing" TKS system out of Syracuse, NY. From what I understand about the system, the difference between the not known icing and the known icing TKS system has to do with redundancy, not functionality. There may be functional differences, in that known-ice certification requires a laundry list of protected surfaces (in addition to the redundancy requirements), some of which may not be included in a "not known-ice" certification. Some "non known-ice" installations meet all the requirements except redundancy, but many do not. That said, I'm not aware of any de-ice system on a single-engine piston aircraft, known-ice or not, that is suitable for allowing a flight to be made into reported non-trace icing. All of the systems should be used as a "get out of jail free" card, to allow a pilot to take the plane out of the icing with less hazard than would otherwise be had. From what I understand, even on many (all?) light twins, the same is true. Of course, that's not to say that a de-ice system wouldn't translate into a higher wintertime dispatch rate. Just that pilots should be careful to not think that having de-ice on their airplane means they can just cruise along ignoring existing icing conditions. Pete |
"Bob Gardner" wrote in message
... No de-icing system allows a pilot to continue flight in icing conditions when encountered Really? I had been under the impression that airline systems did allow continued flight in icing conditions. That's not true, eh? Okay...well, in any case, I think that there are pilots out there that don't understand that de-ice doesn't mean you can just bomb on through icing conditions as if they weren't there. If not, so much the better. But if so, it might be helpful to dissuade someone of that idea. ![]() Pete |
What you say is true about propellor planes. Airline jets on the other hand
are designed to fly through most icing conditions all day long. This is because excess hot bleed air from the compressor sections is routed through the wings and empennage, the so-called "hot wing" system. Nacelle inlets and other critical areas are heated also. It is a matter of degree (pun intended). Enough heat is available and provided to deice a jet in all but the most extreme conditions. No one has figured out how to deice a prop plane to the same degree. "Peter Duniho" wrote in message ... "Bob Gardner" wrote in message ... No de-icing system allows a pilot to continue flight in icing conditions when encountered Really? I had been under the impression that airline systems did allow continued flight in icing conditions. That's not true, eh? Okay...well, in any case, I think that there are pilots out there that don't understand that de-ice doesn't mean you can just bomb on through icing conditions as if they weren't there. If not, so much the better. But if so, it might be helpful to dissuade someone of that idea. ![]() Pete |
Turbine-powered transport category airplanes are a different kettle of
fish...but even they are prohibited from flying into forecast severe icing. In my brief experience flying Part 91 corporate jets we took icing very seriously in spite of having all the goodies...a chunk of ice can put a turbine out of action. The regs I cited all say something to the effect of "..except for those meeting Appendix C of Part 25...", but those regs were written back in the 40s, when supercooled liquid droplets had not yet been discovered. Forty microns is less than the size of a pencil lead; the many turboprop ADs that followed the Roselawn accident tell pilots that any precip that runs back on side windows are far larger and exceed Part 25 certification standards. Bob Gardner "Peter Duniho" wrote in message ... "Bob Gardner" wrote in message ... No de-icing system allows a pilot to continue flight in icing conditions when encountered Really? I had been under the impression that airline systems did allow continued flight in icing conditions. That's not true, eh? Okay...well, in any case, I think that there are pilots out there that don't understand that de-ice doesn't mean you can just bomb on through icing conditions as if they weren't there. If not, so much the better. But if so, it might be helpful to dissuade someone of that idea. ![]() Pete |
Bob Gardner wrote:
No de-icing system allows a pilot to continue flight in icing conditions when encountered...they provide a safety margin while escaping from the conditions. That's how I use it. The problem is that the TKS system is so effective when functioning, there might be a moment when it is difficult to know whether the aircraft is picking up ice or not. -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
"Peter Duniho" wrote in message ... "Peter R." wrote in message That said, I'm not aware of any de-ice system on a single-engine piston aircraft, known-ice or not, that is suitable for allowing a flight to be made into reported non-trace icing. All of the systems should be used as a Have you tried TKS? On a Cessna 210? It is certified for and does just fine in light to moderate icing... in fact, I've never seen the airspeed needle decay even when the few unprotected areas accumulated 1/4" to 1/2" rime. -------------------- Richard Kaplan, CFII www.flyimc.com |
| Air Force issues ‘stop movement’ for Patrick, Cape Canaveral | Otis Willie | Military Aviation | 0 | September 25th 04 10:30 PM |
| Back issues of Naval Aviation News | Steve Tobey | Naval Aviation | 0 | April 23rd 04 10:50 PM |
| Article: GPS Vehicle Tracking System Issues for the Buyer | Johann Blake | Military Aviation | 0 | January 16th 04 12:26 PM |
| How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 01:07 PM |
| ISO back issues Combat Aircraft magazine | mark e digby | Military Aviation | 0 | August 12th 03 06:39 PM |
