Jim Weir wrote:
I usually expect to see 112-115 knots depending on temperature and loading. Jim Javier Henderson shared these priceless pearls of wisdom: -Jim Weir writes: - - Depends entirely on how hard you run the engine. I prefer 20" and 2300 RPM - (makes for a very smooth ride) and get just under 11 gph by the clock. - -What average TAS do you get at, say, 7500' with those settings? - --jav Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Jim, is that TAS or IAS? Seems low for TAS at that altitude. Matt |
![]() Matt Whiting writes: Jim Weir wrote: I usually expect to see 112-115 knots depending on temperature and loading. Jim, is that TAS or IAS? Seems low for TAS at that altitude. I think the power settings he mentioned are equivalent to about 60% power, so those speeds seem OK, no? -jav |
TAS. And a correction. That's 20" and 2200 RPM, not 2300. I didn't notice
that typo until I went back to see why you might think this a bit low. Jim Matt Whiting shared these priceless pearls of wisdom: -Jim Weir wrote: - - I usually expect to see 112-115 knots depending on temperature and loading. - - Jim -Jim, is that TAS or IAS? Seems low for TAS at that altitude. - -Matt Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Rob Timmerman wrote:
Can someone tell me what the fuel burn numbers are on a typical older c182 with the Continental 230hp carbed engine. I am trying to do a comparison with a Cherokee 6/300 and can't find numbers for the C182. Thanks, RT My 67 burned between 11.5 and 13 depending on how hard I was pushing it. I typically ran 22 square at 6-8,000 feet. Matt |
On Mon, 05 Jul 2004 09:21:31 -0400, Rob Timmerman wrote:
Can someone tell me what the fuel burn numbers are on a typical older c182 with the Continental 230hp carbed engine. I am trying to do a comparison with a Cherokee 6/300 and can't find numbers for the C182. Thanks, RT http://www.risingup.com/planespecs/i...plane268.shtml I'm not sure that's the right one, but look around. You might find what you're looking for. Greg |
![]() Rob 5/07/2004 9:21:31 pm Can someone tell me what the fuel burn numbers are on a typical older c182 with the Continental 230hp carbed engine. I am trying to do a comparison with a Cherokee 6/300 and can't find numbers for the C182. Thanks, RT My 182R (230Hp/O-470-U, factory reman) burns 53 litres/hr (~14.0 US gal/hr) at 23/2350 at 3500'. Down to 48 l/hr (12.68 US gal/hr) at 21/2200. Consistently. Measured by a very accurate JPI fuel flow meter. Top-up is within 1 or 2 litres of JPI reading, out of 250/260 litres. Everyone tells me it should be lower..... It is at 6500', with settings 20/2350 (WOFO) ~ 48l/hr. |
Our 1979 C182RG burns on average 13.5 gph in cruise flight (based on our JPI
EDM-800) "Rob Timmerman" wrote in message ... Can someone tell me what the fuel burn numbers are on a typical older c182 with the Continental 230hp carbed engine. I am trying to do a comparison with a Cherokee 6/300 and can't find numbers for the C182. Thanks, RT |
This is based on my 1970 N model with an O470R engine thats
about 100 hours beyond TBO (1500hr on R). I have plugged in to my various flight planning programs pretty close to what the manual says, and on refuel rarely off by a couple gallons. I use one of those universal dipsticks and I find that at the lower values is where I find the most errors. Anyway, below 8,000' it seems to be around 12.5-13gph and recently back east staying below 4,000' it was at least 13gph. Where it shines is heading west (well, I guess direction doesn't matter)and in the O2 altitudes, I'll get 10 to 10.5. This is always at full throttle and 2400-2450 RPM, trueing out at 130k with the wheel pants on, 127k with them off. EGT around 1550, burn around a quart of oil every 13-15 hours. Although I'd love the room of a 206/PA32, I've been very happy with this engine and airplane. Chris "Rob Timmerman" wrote in message ... Can someone tell me what the fuel burn numbers are on a typical older c182 with the Continental 230hp carbed engine. I am trying to do a comparison with a Cherokee 6/300 and can't find numbers for the C182. Thanks, RT |
Can someone tell me what the fuel burn numbers are on a typical older c182 with the Continental 230hp carbed engine. I am trying to do a comparison with a Cherokee 6/300 and can't find numbers for the C182. Thanks, RT I have a 1978 182Q with an 0-470-U (new ECI cylinders 75 hours ago) and I flight plan 137kts @ 8,000 feet. 22" MP @ 2,200 rpm and it burns just about 12 gph. At lower altitudes and lower power settings, I burn about 11 gph. At faster cruise power in the lower than 6,000 foot range, I burn about 13 gallons or so. I checked out both types prior to purchasing and these few items put me on the side of the 182. 1. Doors on both sides (under the wing) which keeps you in the shade and out of the rain during loading. 2. If I ever had an off airport landing and I nosed over, I can open the doors to get out of the 182. In the 6/300 you may get trapped. 3. I rarely need more than 3 passenger capacity. I learned to fly in Warriors (Low wing lover) and really wanted an Archer/Arrow/ or Six...but for the money and performance I chose the 182. (It took a long time to find the right one though) Good Luck and whatever decision you make, it will cost more than you expected. KC C182Q - PP ASEL IA |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Repairing Plastic Instrument Panel Overlay | Jeff P | Owning | 22 | January 29th 04 06:42 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
